l69 305 h.o top end rebuild
Old Oct 21, 2012 | 05:17 PM
86'sportcoupe's Avatar
Car: '86 Sport Coupe
Engine: 310"
Axle/Gears: Stock 10 bolt. 2.73's
when i got this car the previous owner said it overheated i thought the cylinder head was cracked but thankfully it wasnt it ended up being a combination of things the radiator was junk, the fan didnt work, and the timing was way too retarded, so heres my build
the previous owner had a torker 2 intake on it witch is ridiculous, it didnt have enough vacuum to work the power brakes and it had NO bottom end power i ended up changing it to a performer intake witch helped it alot
theres the pics heres what was done
the cylinder heads got a valve job, put on dz 302 valve springs, and some porting
a new cam 272-282 adv. duration .442- .465 lift
edelbrock peformer intake
holley 650 spreadbore carb
accell distributor
weiand alm. water pump
and originally i put on a set of vintage mickey thompson valve covers but they didnt have a baffle inside for the pcv so i chanded them out for edelbrocks
Old Oct 22, 2012 | 11:49 AM
Gsoleski's Avatar
Car: 1984 Z28
Engine: Vortec 350, hotcam
Re: l69 305 h.o top end rebuild
Nice job. How does it perform now? Also in your last picture, what's the line coming out of the intake and over the valve cover for?
Old Oct 22, 2012 | 12:12 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Looks like a capillary tube for a mechanical temperature gauge.
Old Oct 22, 2012 | 12:55 PM
InfernalVortex's Avatar
Car: 1992 Camaro RS
Axle/Gears: 9-bolt 3.70
Why did you put dished pistons into a flat-top piston L69? The main difference between the LG4 and L69 was the L69 got a slightly better cam and flat top pistons for higher compression.
Regardless, the Torkers are a terrible match for a mostly stock engine, you did good by ditching it.
Old Oct 22, 2012 | 01:46 PM
Engine: 310"
I dont know yet, still tuning and i need to get tags for it, and the line is the temp sending unit for the water temp gauge
Old Oct 22, 2012 | 01:52 PM
Engine: 310"
the previous owner had the engine rebuilt and thats what he put in there for some stupid reason the guy i bought the car from didnt know what he was doing when he "fixed" up the car, the car looked good and thats about it we had to basically do a mechanical resto on the car because he trashed it
Old Oct 23, 2012 | 06:07 PM
kmcn47's Avatar
Car: 84 Trans Am, 84 Fiero, 86 944
Engine: 5.0, 2.5, 2.5
Transmission: 5spd
great build so far, glad to see someone rebuild an l69 for a change rather the swap it for a "better" tree fiddy
Old Oct 23, 2012 | 06:16 PM
Engine: 310"
Thanks, i built the 305 because its my first car and my parents are just trying to keep me safe, plus this was a copo car and it was ordered with an l69 but my dad has enough parts to build a pretty sweet 355 down the road, but the 305 will do for now plus it will rev to like 6,000-6,300 rpm with those dz302 z/28 valve springs lol
Old Oct 23, 2012 | 06:41 PM
kmcn47's Avatar
Transmission: 5spd
well that or your tach is wrong, mine says i do 6700 rpm on the interstate at 1/4 throttle and i dont think anyones factory tachometer is right given the failure rate of them
Old Oct 23, 2012 | 06:50 PM
Engine: 310"
wow, i do have an aftermarket tach though and i haven't tested it yet but those old dz engines reved to like 7500 and the stiff valve springs had alot to do with it
Old Oct 23, 2012 | 06:55 PM
kmcn47's Avatar
Transmission: 5spd
yeah that much i know, its a respectable (very) 5.0 but honestly you could probably save those dz 302 parts and sell them to someone doing a resto for big $$$$
Old Oct 23, 2012 | 07:07 PM
Engine: 310"
well they went original they were an exact copy made by manely, but my dad has an original dz 780 holley carb and i think he used to have the intake too but i think he sold it
Old Oct 23, 2012 | 08:10 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Originally Posted by 86'sportcoupe
this was a copo car
The COPO option was unavailable over a decade before your car was built.
Old Oct 23, 2012 | 08:35 PM
Engine: 310"
i thought copo was around unitll the 90's? huh im probably wrong though, but still it was custom ordered with that option
Old Oct 23, 2012 | 08:39 PM
kmcn47's Avatar
Transmission: 5spd
i believe it was, but they called it the fleet program, and of course they caught on to the massive engines in muscle cars part of it lol anymore you cant even special order a vehicle form say Chevrolet with (i know there not around anymore) a Pontiac color option, you need at least 5
Old Oct 23, 2012 | 08:49 PM
Engine: 310"
here is the est. power and torque numbers based on a engine building simulator
peak hp at the flywheel is 344 at 5500 and 415lbs of torque at 3000
Old Oct 23, 2012 | 09:36 PM
Engine: 310"
here is a vid of after i got the exhaust on
Old Oct 23, 2012 | 09:40 PM
kmcn47's Avatar
Transmission: 5spd
heyi just realized it your in ohio too
Old Oct 23, 2012 | 10:15 PM
Engine: 310"
Yep im from johnstown, a small town in central ohio
Old Oct 23, 2012 | 10:24 PM
kmcn47's Avatar
Transmission: 5spd
bridgeport, on the border of WV, thank god for the river lol
Old Oct 23, 2012 | 10:35 PM
Car: 1992 Camaro RS
The camshaft was what it had to do with.
Your cam:
http://www.summitracing.com/parts/SUM-1103/
DZ302 cam (there are a few different versions around today, but this is one):
http://www.summitracing.com/parts/HRS-112192-14/
That cam is HUGE... MASSIVELY huge.
https://www.thirdgen.org/forums/tech...dz302-sbc.html
Nothing special about any of that stuff. Z28 springs were all people had for yeras before the aftermarket began to offer a huge variety of more effective springs for every application. Nowadays it's better to run whatever spring the cam company recommends for their cams.
Go to the drag strip, just get down it at wide open throttle and see what your trap speed is. Your speed in the 1/4 and your car's weight (get on the scale at the track) will give you a very accurate estimate of real world horsepower. Use any one of the numerous online calculators that compute this, most are pretty consistent. Real world numbers are going to be a lot more accurate.
Your car likely weighs between 3400 and 3600 with you in it. Go find out how fast it will go. Trap speed is pretty consistent regardless of how bad you launch so dont worry about that.
Old Oct 24, 2012 | 07:20 AM
Engine: 310"
Your cam:
That cam was huge but it didnt make for much low end power and torque
And the edelbrock perfomer rpm is highly based on the old dz intake they are worth a crap load if original
Old Oct 24, 2012 | 07:43 AM
Engine: 310"
also i cant take it to the strip yet as i only got my temps the other day but hopefully eventually i will make it to the track
Old Oct 24, 2012 | 08:38 AM
85_ZED28's Avatar
Car: '85 Z28
Nice job. Never heard of an L69 SC. Do you have the RPO label?
Old Oct 24, 2012 | 01:43 PM
Engine: 310"
the rpo says lg4 but with the research that iv done the engine was dealer installed
Old Oct 27, 2012 | 12:56 AM
kmcn47's Avatar
Transmission: 5spd
like it would have been if you ordered a 427 for a camaro back in 69, very copo lol
Old Oct 27, 2012 | 12:05 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
No, then it would have come from the factory with matching VIN and all the documentation... not to mention you would have had to order about 100 of them at the same time as part of your COPO order.
Old Nov 7, 2012 | 06:41 PM
Engine: 310"
Heres an updated pic, changed the air cleaner lid out for a jegs one that was in better shape then the edelbrock, and i painted the wing nut red
Old Mar 22, 2014 | 10:34 PM
Engine: 310"
Forgot about this old thread, here is the update, got some miles on her now, performance is much better than expected. and the engine is not a true l69. Well it could have been, it was a reman 310 crate from napa. it has the dish pistons, but with 601 heads, either way it runs very good for what it is, here is a video of it running, cam lope sounds pretty intense in it. for how mild it is. this was an open y pipe, now has a race bullet in place of the flowmaster
(btw hardly any money was spent on this thing, and it is my first car, that is why we built the 305, my dad built race engines for years, thought of the 305 as a boat anchor. He was blown away by how this thing performs, great first hot rod engine)
hectre13
Dec 11, 2023 08:14 AM
SiCkRs
Members Camaros
32
Jul 1, 2018 04:53 AM
Azrael91966669
25
Jun 20, 2017 04:04 AM
sreZ28
Aug 14, 2015 07:48 PM
3rdgenparts
Aug 6, 2015 09:03 AM
