removing cluster to put leds
Old Jan 6, 2013 | 07:29 PM
BRIAN2FAST4U's Avatar
hello there im new to this i have a 91 camaro rs had an ls1 swapped it out for a v6 for now using this small engine just to go from home to wrk n back ... but i did pretty good putting all leds around the whole entire car from under body led lights and halos in the front with halos in the fog lights also the tail lights but im havin problems with the cluster i cant take it out to put leds in my cluster also if any knows wat is underneath the dashboard is that also a light above the radio unit ... if any 1 can help that be awesome also 1 more thing need help finding thee right body skirts for my car the all crack an also front lip an rear quarter panel .. like i said im new to this so give me a chance
Old Jan 25, 2013 | 05:53 PM
cdoyle's Avatar
Re: removing cluster to put leds
I put LEDs in my 92Z cluster, when you say you can't take it out what is the problem? You should be able to remove it.
I used LED strips in mine, to get a more even color:
Old Jan 25, 2013 | 06:30 PM
I try taking it apart but the light *** on far left doesnt let me get my cluster out unless im doin something wrong i removed top panel the bezel n the bottom piece of the sterring wheel.
Urs is awesome putting led strip i c u removed ur cluster perfectly
Old Jan 25, 2013 | 06:34 PM
cdoyle's Avatar
Oh you have to remove the ****, get the bezel loose and then look up under the **** where it shaft goes into the switch. You should see a little tiny button on the bottom of the switch. Take a long screwdriver and push that button in and pull on the ****. It should come off, it's a pain but should come off.
Old Jan 25, 2013 | 07:14 PM
Ohh koo thank u very much ill have to check that out 1s i get home frm wrk so hopefully i can get iy.. One more thing did u put leds in ur tail lights
Old Jan 25, 2013 | 07:19 PM
cdoyle's Avatar
Ya I did a full out retro for the tail lights.
There is a thread on here I started that went through the build. Do a search under my name, and you should be able to find it.
If you're going to do LEDs in the tail lights, a full retro is the way to go. Don't try the plug/play things you see online. They are just not bright enough in the day, and you'll either get rear ended or pulled over.
Old Jan 26, 2013 | 03:20 PM
lordmetalz28's Avatar
Car: 1987 Z28 with iroc-z Package no.3
Engine: 350TPI
Axle/Gears: 3.73 posi
Is the speedo cable holding you up by any chance? me personally i had to drop the steering column down to get the assembly back in. P.I.T.A seriously
Old Jan 26, 2013 | 05:00 PM
cdoyle's Avatar
The 91 cluster is electronic no cable, once he gets the bezel off he should be able to get the cluster out by just tilting down the wheel. I didn't have to lower the column on mine.
Old Jan 26, 2013 | 05:19 PM
Engine: 350TPI
ah yes . electronic. no cable. forgot about that.
Frozer!!!
Jan 19, 2024 04:55 PM
Fronzizzle
Aug 19, 2015 01:36 PM
Fronzizzle
Aug 17, 2015 02:52 PM
fonzie85
Aug 13, 2015 11:50 AM
3rdgenparts
Aug 8, 2015 07:09 PM
