New Here 92 Camaro RS
Car: 1992 Camaro RS, 2002 Eclipse GT
Engine: 305 TBI V8, 3.0 V6
Transmission: 700r4, 4 Speed Sporty
Axle/Gears: 3.42 Rear End
Hey all! I'm new to this forum as tomorrow I am picking up a 92 Camaro RS. It's a fixer upper for sure, but I'm excited to start! I've always loved the 3rd gen camaro's since I was 6. I'll post pictures of the Camaro once I get it. It's currently not running, cause there is a wire short in the coil somewhere. It's got aftermarket heads, cam, and exhaust. It's the 305 TBI v8. It's missing the front ground effects, so I'll have to find one of those somewhere. Any suggestions?
Car: 1987 T/A WS6 T-Tops/92 RS
Engine: LB9/3.1
Transmission: 700R4/700R4
Axle/Gears: 2.73/3.23
Re: New Here 92 Camaro RS
Well come to the site. I too have a fixer up 92 RS, but mine does run and drive right now. Too bad your not close as I this past weekend I found a chin in the local Pull a Part-that never happens, seems the chin is the first part to go at the yard. Good luck on the project and you can learn alot from this site as long as you read, read, and read someone.
So, I've replaced the battery and alternator, but the battery still isn't getting charged. The alternator passed with flying colors, and the battery is good, any ideas where the charge is going?
Car: 2012 F350 lariot/1991 Camaro RS
Engine: Powerstroke/6.0
Transmission: 6R100/4L80e
Axle/Gears: 3.73/3.42
welcome 91 92 RS camaros are IMO the best looking the z28s are ok but I like the lip spoiler more
TONS of info on here to help you out with just about anything
Finally got some pictures! Forgot to post them earlier! My pair of 3g's!
Car: 1989 Firebird Formula
Engine: 5.7 LS1
it looks like somebody put a 82-84 front bumper and hood on it.Not a bad project car either. good find
Car: 1991 GTA
Engine: LB9
Nice project.
Check out Hawks third gen or thirdgenranch for your missing GFX.
There haven't been many third gens in the local(Utah) wrecking yards lately, and often the GFX are already missing or trashed.
Car: 86' IROC-Z....and 5 other 3rdgens
Engine: 383 hsr
Transmission: built 700r4
Axle/Gears: stock 3.23, 10bolt
Engine: LB9/3.1
Engine: 5.7 LS1
Thanks for all the feedback!
Little update! Found myself a diamond in the rough at a local pick n pull!
Hey all! Little update, recently picked up some c5 corvette wheels. 18x9 fronts, and 19x10 rears, I know I need adapters, but am unsure of size. and I'm also lost on tire sizes. suggestions?
Heres the pictures of the wheels and the rear tires that I've gotten for the 3rd gen!
Did some work over my spring break! Here's how the Camaro is sitting currently.
Car: 1992 camaro rs
Engine: 92 350ci carbed
Transmission: 700r
Axle/Gears: Stock 10 bolt 2:73 gears 😭
Looking good man! Have you dug into that engine bay yet!? I couldn't wait, I put in a 350 and carbed it, not a beast but much more satisfying than the stock motor
Oh, I want to! But I just really don't have the know-how. My friend has a stock lt1 that I might try to get, but I wouldn't know how to drop it in!
Car: 1992 camaro rs
Transmission: 700r
350 swaps are simpler, just swap the motor and all the old accessories stay on, you can use the tbi but you need a 350 chip and injectors. For that you get a whole lot more tire burning torque 😁. Then when u get rich you can build a real beast
Ah, I see! Sadly though, I might be selling the camaro. It needs a bit to pass safety, and my DD has been having issues.
84z96L31vortec
Aug 20, 2017 12:16 AM
