1992 RS on weight jacks
Old Mar 29, 2015 | 08:32 PM
InfernalVortex's Avatar
Car: 1992 Camaro RS
Axle/Gears: 9-bolt 3.70
I think the car is looking pretty good. Not bad for a car I saved from the parts bin back in 2007.
2007:
And the kicker.... long tubes!
After all these years, I've finally got that look I've been wanting all this time. Its always a struggle to balance aggressiveness with classiness.
Here are the race tires.... these are white ZR1's... I thought it was an interesting look in case anyone wanted to see it. They've got Nitto NT01's on them for the autocrosses.
Old Mar 29, 2015 | 08:40 PM
DynoDave43's Avatar
Axle/Gears: 10 Bolt 2.73 Open
Re: 1992 RS on weight jacks
That does sit nice. The Vette wheels look sharp too.
Old Mar 30, 2015 | 04:51 PM
Ben91z's Avatar
Want a title? Post!
Car: 91 z28
Engine: 350 tpi
Looks good. Which brand longtubes do u have seems to tuck nicely
Old Apr 1, 2015 | 12:06 PM
Car: 1992 Camaro RS
Just the cheapie Hedmans. I've had them for years, I love em. They make my car sound absolutely insane.
Old Apr 1, 2015 | 12:11 PM
BADNBLK's Avatar
COTM Editor
Needs an accent color to really make it pop... Teal... You know you want to
Old Apr 1, 2015 | 12:13 PM
Car: 1992 Camaro RS
Teal and red.... that might be a winner!
Old Apr 1, 2015 | 12:19 PM
CharcoalBird's Avatar
Car: 1991 Firebird
Engine: 3.1L V6
Looks good. What is your fender height front and rear?
Old Apr 1, 2015 | 12:52 PM
BADNBLK's Avatar
COTM Editor
I feel like I have a good eye for color combos... until teal comes in the mix
Old Mar 18, 2016 | 10:37 AM
91banditt2's Avatar
Car: 1991 BandittII Firebird
Engine: 5.7 HSR
Axle/Gears: 3.27 9 bolt
what brand of weight jacks did you use?
Old Mar 19, 2016 | 03:28 PM
Car: 1992 Camaro RS
I used Ground Control's kit... but I got it from No LImit Motorsports. They were a bit cheaper there than anywhere else at the time.
You can build your own kit but it will still cost you around $200-$250 before you buy springs.
Old Mar 19, 2016 | 08:15 PM
91banditt2's Avatar
Engine: 5.7 HSR
That's what I've been looking for, a cheaper alternative to spending $500 on s set of ground controls. I'm wanting to peice a set of bolt in weight jacks together. But I'm having a hard sourcing the individual parts.
Old Mar 20, 2016 | 05:43 AM
Car: 1992 Camaro RS
Look into adjustable spring seats/spring cups from the roundy round retailers like allstar performance.
From when I was piecing it all together the only real problem was getting the fronts done and tehres threads on here about how to do that. But they sell everything you need and nearly everyone that sells circle track parts sells various versions of everything.
The main problem, and the main innovation GC has, is that they are bolt in spring adjusters. Their adjusters fit in the factory spring pockets, which means no drilling holes in the k-member for jack bolts and so on. You can copy their design philosophy but it takes a little fabrication.
Briandrex
Oct 5, 2015 06:20 AM
z28joe2
Sep 28, 2015 05:54 PM
timbuck
Convertibles
Sep 28, 2015 12:31 PM
ironbmt
Sep 27, 2015 06:00 AM
Damon
Sep 26, 2015 04:29 PM
