91-92 GTA Tail Lights, How Much Are They Worth?
Old Jul 17, 2015 | 05:38 AM
BBSDesigns's Avatar
Car: GTA
Engine: Bone Stock 350ci HSR T-76 Turbo
Transmission: T56 6-speed
Axle/Gears: Stock
I have a set of 91-92 GTA tail lights I've been planning to swap for my 89's, but I am honestly thinking just to sell them.
I would like to know how much they are worth before posting them at ebay. The tail lights are in very good shape with no cracks nor scratches. They are the ones that have the amber corners and they do have two spots where apparently suffered from sun fading, but easily repairable because the spots are located in the black portions of the lenses. The PONTIAC lettering is also worn.
I will post pics later today.
Thanks!
Old Jul 17, 2015 | 07:24 AM
BBSDesigns's Avatar
Car: GTA
Axle/Gears: Stock
Re: 91-92 GTA Tail Lights, How Much Are They Worth?
Pics
Old Jul 17, 2015 | 08:54 AM
Street Lethal's Avatar
Car: 1990 Trans Am GTA
Engine: Turbo 305 w/MS2
Originally Posted by BBSDesigns
The tail lights are in very good shape with no cracks nor scratches. They are the ones that have the amber corners and they do have two spots where apparently suffered from sun fading, but easily repairable...
Delamination, as well as scratches (not that you have scratches) are easy to fix, even if the delamination was in the center, very easy. I'm surprised nobody else figured out how to fix delamination yet. Scratches are easily sanded out, it's the cracks that are pain in the rear to fix, but doable. That said, Ed, don't take less than two hundred each for them the way they are, at a minimum, so four hundred for the pair as is, no less. If you correct the delamination, wet sand them down and polish them, you should get well over five hundred for the pair, perhaps more as they are getting hard to find. I'm debating if I should just remove the tint from my current set that the former owner put on, and just polish them. I only have one upper red reflector, so I took off the other one to make them match for the time being until I came across the one I need...
Old Aug 2, 2015 | 09:59 AM
scooter's Avatar
Car: 92 Firebird
Engine: 4.8 LR4
Axle/Gears: 3.45 9 Bolt
How do you fix the delamination?
Old Aug 2, 2015 | 10:17 AM
But, but... what about those companies that charge an arm and a leg to do it for you, or those companies that buy delaminated ones for cheap, correct them, and then sell them for way more than they bought them for? I'm afraid that if I tell ya this highly classified information, then I just might have to kill ya lol. j/k
I'm going to make a video for everyone and will have it up shortly, I promise...
Old Aug 2, 2015 | 10:35 AM
scooter's Avatar
Car: 92 Firebird
Engine: 4.8 LR4
People do that? I haven't heard that before
Old Aug 2, 2015 | 12:19 PM
Eric-86sc's Avatar
Car: 90 formula, 89 formula 350 vert
Engine: 305, 355
Transmission: T5, t56
Axle/Gears: 3:45 9 bolt, 8.8 3:73
With the delaminating your lights have, they should bring in the 300 range shipped. I had a set in the exact same shape and got nothing but people complaining when I had them at 325 shipped.
Old Aug 14, 2015 | 04:39 AM
Sdi1000's Avatar
Car: 1980 Pace Car, 1987 Trans Am
Engine: 4.9 Turbo, 5.0 TPI
Hey, Street Lethal - did you do a video yet ? If not, could you please just explain how to fix this delamination, as i have some major delam on both tail lights. I know the clear part of lens can be masked with a template/vinyl stickers, and just spray paint over the grid pattern, but just wondering what your fix is....
Frozer!!!
Jan 19, 2024 04:55 PM
LittleFranks
Aug 20, 2015 03:55 PM
Fronzizzle
Aug 19, 2015 01:36 PM
LilHot
Aug 19, 2015 10:02 AM
Omega
Aug 10, 2015 12:46 PM
