Local Maryland's, Emissions help needed! :)
yup thats right my car sucked with hydrocarbons and carbon monoxide, hey but i did pass the fuel cap pressure test
State standards:
Hydrocarbons 220 PPM
Carbon Monoxide 1.20 PCT
My test:
398 PPM
1.36 PCT
slp 1 3/4 headers non air, no smog pump, no cats, slp catback, i turned my fans off and was running 220 temp at least when being tested.
maybe having cats right now would be a good thing, any cheap methods to get me to pass?
thanks for your help.
State standards:
My test:
398 PPM
1.36 PCT
yeah dual cats have been deleted with pipes, but i guess i have no choice, i should of just stayed home and lowered the front end alittle more, but i still would like to pass emissions, i didnt know my numbers would be this bad.
anyone have any numbers like mine and then put a cat(s) on or did something else and then pass? thx
Car: 2005 Subaru STI
Engine: 153ci of Turbo Power!
Transmission: 6-Speed
Count me as somebody who had very high HC and then installed cats (dual cats) and watched those counts drop dramatically.
HC limit = 220ppm
BEFORE Cats: 871ppm
AFTER Cats: 310ppm
This was with the MiniRam, no EGR, no AIR, and a 230/245 cam.
The only way I was able to pass was to force open loop and run really really lean. I ended up passing with 17ppm
... that wasn't a typo. It was 17ppm. But that was very very dangerous because the car was running crazy lean.
Cats make a huge difference. If you put cats on then you will pass the HCs.
Tim
HC limit = 220ppm
BEFORE Cats: 871ppm
AFTER Cats: 310ppm
... that wasn't a typo. It was 17ppm. But that was very very dangerous because the car was running crazy lean.Cats make a huge difference. If you put cats on then you will pass the HCs.
Tim
so 2 way cats with the air pipe fitting will work then?
i think not having these cats is causing me to run ruch also, i lost about 30 miles to a tank now, i wonder since my erg is broke it migh be causing a problem also, to many things are going wrong and my emission numbers show it.
plus i let my engine run hot like over 220 or so and the damn car was almost stalling in the lanes waiting for testing.
darn Maryland for having emissions, why cant we just donate 20 bucks a year to the wildlife fund
Car: 1982 Z28
Engine: LC9
Transmission: AR5
I failed emissions twice and replaced:
- Cats
- Spark plugs
- Spark plug wires
- Coil
- Distributor cap and rotor
- PCV valve
And STILL failed.
Too much HC. However, the guy at the testing station said that if I did all the work myself, it's worth $175 toward the $450 waiver fee.
Pat, who is really close to "selling" my Firebird to my dad in emissions-free Nebraska
- Cats
- Spark plugs
- Spark plug wires
- Coil
- PCV valve
And STILL failed.
I am brining this back.
why didnt they test for NOx ?
they tested for CO2 6.0 PCT State Standard
13.13 PCT results
things i plan to replace.
egr crap, two cats 2 way. i cant really add air tubes in anymore.
fuel vapor canister might help, and air filter.
13.13 PCT results
Car: 91z28
Engine: 5.7 l98
Transmission: AT :(
if you are not on the roller they have you tach the motor upt to about 2k-2.5k. I got a waiver last time i was therre because i had a low profile tire on the front (flat) and they told me i could not go in to the bay because of the 4x4 "hump" would make my radiator air dam scrape. they will not allow a car in to the bay and have them back out when you are done. so if the bottom will scrape they will give a pass. little hint .. 2 years and running.....
just want to say i tired it again and did nothing but take off my air box and unhooked the battery for a few seconds, passed the test this time.
they said my car is in the computer now as "idle only" and the person last time should of never had it on the roller to begin with.
anyway my carbon went down quite a but and my hydrocarbons barely passed
what a good friday the 13th.
Car: 1987 Camaro Z28 IROC-Z
Engine: 5.7L TPI
Axle/Gears: 3.42:1
) Senior Member
Car: 87 Vette 85 TA 82 Z/28
Engine: 3 - 350's 388 400
Transmission: 2-700R4's 1 T56 Setup!
Axle/Gears: 2.59's 3.42's 3.73's
thats good Jim!
tell me exactly what you did to pass?
i'm hoping i get the too low stuff this time around in GB. when i first got the car they ran in thru in annapolis.
don't think i'd pass this go around unless i pull some tricks
if ur too low then they will do the "idle test" still.
which means they dont put u on the roller u just drive over it some and then they hook u up to the smog things on the tail pipes and just test for like 2 minutes or so. i kept the idle up some.
i just put in a full tank of 93, got it to around 220 degrees, reset the computer, and pulled the air intake going to my air filter
it worked, i went to the one up in Glen Burnie.
