Mid-Atlantic Region Regional board for all of the Mid-Atlantic states. Discuss gatherings and get togethers.
winter plans?????????
Old Nov 1, 2004 | 10:36 PM
twysted87's Avatar
Car: 87 gta 89 ta
Engine: 5.0 5.7
Transmission: 700r4 x2
so what's everyone planning to get into this winter? any malor projects goin on... myself i'm gonna repaint the iroc again... hoefully it'll turn out better this time... so how about yall?
Old Nov 2, 2004 | 03:25 AM
z28kindaguy's Avatar
Car: 2004 Pontiac GTO
Transmission: M12
Find a way for my Camaro to keep traction in the snow.
Seriously, I might replace the t top headliner... order it from Hawks. Mine is looking pretty bad. I'm also going to get a set of wheels for it as well... I hope.
I may even be getting an LS1 4th Gen.... I hope for that as well.
If I bought the paint, would you paint my car for me? There would be $$ involved of course.
Old Nov 2, 2004 | 09:19 AM
ES87iroc's Avatar
Car: 1987 Camaro Z28 IROC-Z
Engine: 5.7L TPI
Axle/Gears: 3.42:1
Nothing big planned yet, I am going to put a borla on the t/a as soon as I get some spare time. Hopefully it won't be too frosty.
If you guys need some paint pointers lemme know, I have been down that painful road a few times now.
Joe, what wheels were you looking at?
Old Nov 2, 2004 | 02:02 PM
iroc87matt's Avatar
Car: 87 GMC Sierra
Transmission: auto
i plan on working on my car since it needs some work.
Old Nov 2, 2004 | 02:05 PM
ES87iroc's Avatar
Engine: 5.7L TPI
Axle/Gears: 3.42:1
Put some floors in that thing!
Old Nov 2, 2004 | 03:08 PM
MdFormula350's Avatar
nothing, daily driving as usual.
Old Nov 3, 2004 | 02:19 AM
Transmission: M12
Erik, not exacty sure yet. Any suggestions?
Old Nov 3, 2004 | 09:17 AM
exotikcamaro's Avatar
Car: 1989 Camaro RS
i have something big in the works that people on this board have been talking about for a while but no one has done. Whether i get it done depends on the amount of $$$ i can scrounge together. The car will be at World of Wheels in Baltimore the first weekend in Feb, hopefully looking really crazy
Old Nov 3, 2004 | 09:33 AM
ES87iroc's Avatar
Engine: 5.7L TPI
Axle/Gears: 3.42:1
Depends, wheels pretty much revolve around budget constraints and personal style.
Also, what sizing are you looking at? I would assume you are planning on going 17" as you have 16's now?
The thirdgen zr1 style wheel is a great looking wheel in person, also very daily driver friendly as your car is. (i.e. no adapter maintainence, is a direct fit, and it's 8" wide instead of 9.5 so turning full lock is easier)
If you don't mind running adapters (safe and easy, just extra steps in maintainence) your choices open up considerably. If you really want to go wild on a budget, zr1's in 17x9 and 17x11 are smoooooth. I wish I could have gone with that, but requires some minor reworking in the rear metal of the car. It looks absolutly killer though. That, and you can't beat the traction/look of a 315 tire in the back! You can get a set from AFS for around $550-600 or so, then adapters should run you around $175-300 depending on where you get them. Tires are completly subjective, depends on what you are looking for and where you go.
For example, I bought four bfgoodrich gforce t/a 275/40/17 with about 4k miles on them for around $320 shipped from ebay. (For the WS6, the camaro has comp t/a's) You can get some killer deals on used tires, or you could just buy new. If new, I would recommend www.tirerack.com , their prices simply can't be beat. :hail:
Alternativly, the SLP zr1 wheels are a direct fit, altough you will have to run less tire as the wheels are more narrow. A 245 or 255 series tire is what you would want to run on an 8" wheel. On my 9.5's, I have 285's all around, which rub slighty in the front with the wheels hard over. I have 2" adapters in the front, and 1.25" in the rear.
Also, if you are unhappy with your gear ratio, then that opens up some other possibilites. You can score a used fourth gen rear for cheap, typically with disc brakes/posi/good gears, and then not have to buy rear spacers. The 4th gen rear is a direct fit.
Hope this helps some and lemme know if you have any other questions!
Old Nov 3, 2004 | 09:41 AM
ES87iroc's Avatar
Engine: 5.7L TPI
Axle/Gears: 3.42:1
Here's a link for the slp zr1 wheels from Hawk's...
http://www.hawksthirdgenparts.com/in...?v=1&pid=13964
Old Nov 3, 2004 | 10:50 AM
megaracerx's Avatar
well..hopefully the $$ will start flowing in...and if it does watch out...my plans for the next winter/spring goes as follows:
1. switch form carb to TPI (maybe)
2. wheels...just TT2's
3. engines mods...anything i can afford..
4. RA II hood..
so i pray i get some money!
edit: i forgot about a big project...my drag 79 T/A thats in the works...
Old Nov 3, 2004 | 02:01 PM
camarogirl18's Avatar
Car: 1991 Chevy Camaro RS
Engine: 283
Transmission: 700r4 Auto
my plans for the RS are:
1-get the rust & minor things fixed on it
2-new carpet
3-new seats
in the spring:
1-new paint job
2-windows tinted @ 5%
for the SC:
1-get this one little rust spot fixed
hopefully Santa will help me out in the bling-bling area
Old Nov 3, 2004 | 02:48 PM
iroc87matt's Avatar
Car: 87 GMC Sierra
Transmission: auto
yes erik, floor is first on the list. then the interior once i get some money cause my funds are low as hell, $3 right now. i need a job
Old Nov 3, 2004 | 02:49 PM
N8PHU's Avatar
Car: 82 Camaro
Engine: 2.8L V-6
Transmission: 4 speed
Well, looks like I will be collecting parts to be installed in the spring, right after I have it in a frame shop...
Unfortunately, I don't have a garage, so any outside work is going to be limited. I don't think the wife wants a 2.8L to 3.4 L swap going on in the middle of the living room.....
Old Nov 3, 2004 | 05:39 PM
Steve86TA's Avatar
Car: To many to list
Fix the damage,and paint the 86.Fix the trans and tuning issues on the TTA. And to think that those 2 weren't even the winter project..Busy winter.
Old Nov 3, 2004 | 09:55 PM
Engine: 283
time to get rid of her then!
LMAO J/K!!
Old Nov 3, 2004 | 10:23 PM
twysted87's Avatar
Car: 87 gta 89 ta
Engine: 5.0 5.7
thats the understatement of the year!!!!!
Old Nov 3, 2004 | 10:30 PM
twysted87's Avatar
Car: 87 gta 89 ta
Engine: 5.0 5.7
mine has just learned to live with it.... it's better than spending all my $$ at the bar , or on other bad habits, she complains a little than gets over it.... so far
Old Nov 3, 2004 | 10:43 PM
twysted87's Avatar
Car: 87 gta 89 ta
Engine: 5.0 5.7
i have trouble painting other peoples cars ,i;d like to but i'm not that confident yet in my abilitys. theres alot that can go wrong, and usually does.. i can't possibly do any other cars til next summer when i put an addition onto my garage, but i can help you find a professional shop who won't charge you to much... yes they are out there,
good idea with the hawk headliner, thats where i got mine,kinda tricky tho if you got the overhead console in your car.
asfor wheels there's plenty that look good on iroc's, i have got my eye on th new cragar s/s , one piece all aluminum,comes in bling bling sizes to,
my plans for gettin a fourth gen got shot down when the wife decided to keep the 600 a month suv,ouch, also half my project plans went out the window
Old Nov 4, 2004 | 12:27 AM
Transmission: M12
Sounds good. I'm like that when I fix other people's computers sometimes, so I completely understand. As soon as I find out some stuff with some finances, I'll hit you up for those cheap pro shops that can paint my car.
After thinking about it, the IROC needs paint more than wheels, so when I get some extra money, I'll get it painted first. Lots to do..... :lala:
Old Nov 4, 2004 | 09:00 AM
iroc87matt's Avatar
Car: 87 GMC Sierra
Transmission: auto
i need the funds to fix my car and a way down to it
Old Nov 4, 2004 | 09:07 AM
ES87iroc's Avatar
Engine: 5.7L TPI
Axle/Gears: 3.42:1
Hmm, paint looked okay to me, but I guess I didn't look too close. I guess being the owner you tend to notice all the little things, I know that feeling. Anyways, you could always strip and polish your existing wheels if you want to do paint first. It sucks, is not fun, takes forstinkingever but looks great and is next to free.
Old Nov 4, 2004 | 10:27 AM
MDv6man's Avatar
Car: 1983, 1986
Engine: 2.8 2bbl, 2.8 MPFI
Transmission: 200C 3 speed, 700R4
Axle/Gears: 3.08, 3.42
Gee winter's here already?
Let's see -- start off by selling the 85 -- that will provide the funds to paint the 83 and get the original seats recovered. After that it's getting sold. Then I'll try to get the 86 running and tagged and fix the GTO's brakes.
Also need to fix the Geo and replace the tie rod ends and ball Joint on the Buick
Old Nov 5, 2004 | 01:40 AM
Transmission: M12
I'll let you take a closer look next Saturday. Trust me... it needs paint badly.
Strip and polish eh? I suppose I could try that.
*goes on google*
lol oh yeah, you forgot my cd book.
Old Nov 5, 2004 | 01:41 AM
92 Formula's Avatar
From: Avatar: My 34' 1989 Scarab III w/ twin 454's (502's Started!)
Car: 1989 Wellcraft Scarab III
Engine: Twin 454's
Axle/Gears: Twin Mercruiser Bravo I's
Either begin collecting parts for the eventual 427 build up (whattup Tim! ) for the IROC or create a fund for a new Pro-Built 700R4 built specifically for the IROC's final incarnation. Either way it will be slow collecting as I don't think Santa Claus is going to be too good to me...
Old Nov 5, 2004 | 09:13 AM
N8PHU's Avatar
Car: 82 Camaro
Engine: 2.8L V-6
LMAO J/K!!
Naw, she's ok, just doesn't want the kids running off with the pistons!
Old Nov 5, 2004 | 02:19 PM
iroc87matt's Avatar
Car: 87 GMC Sierra
Transmission: auto
thats why when i have kids my garage will be locked up
Old Nov 5, 2004 | 02:27 PM
megaracerx's Avatar
Old Nov 5, 2004 | 05:27 PM
Engine: 283
LMAO!
Old Nov 5, 2004 | 09:46 PM
twysted87's Avatar
Car: 87 gta 89 ta
Engine: 5.0 5.7
you selling off the collection? i'm gettin a nice 3.1 rs in dec that would look great in your collection
Old Nov 6, 2004 | 09:09 PM
twysted87's Avatar
Car: 87 gta 89 ta
Engine: 5.0 5.7
another winter plan that i got is to get a 87-90 trans am gta. i'e had 9 other fbodys but thatis the unicorn i can't never seem to catch.... i wanna get one thats in sad shape to build how i want, ex. crate motor maybe six speed , or auto not sure on that, i like doin body work so that isnt an issue. i got a spare interior in the garage, all i need is a body, not stripped of course, i'm thinkin about black or gunmetal grey with purple graffix on the front, .. if any of yall know someone whos got one or if you got one lying around gimme the 411 on it.. i got approval from the wife so thats the biggest hrtle to cross... i'm pretty satisfied with the camaro so now i need a new project to keep me outta trouble.. :werd:
Old Nov 7, 2004 | 07:28 AM
ES87iroc's Avatar
Engine: 5.7L TPI
Axle/Gears: 3.42:1
LoL.
My project for the winter is putting a new interior in the malibu, along with a new motor/transmission/rear/exhuast/suspsension. Just a small project I guess.
Old Nov 7, 2004 | 07:08 PM
Steve86TA's Avatar
LoL.
Oh yeah,forgot about that.Add it to the ever growing list I really need to quite my day job,just to have some time.That motor/trans may be the easiest of all the projects over here
Old Nov 7, 2004 | 08:56 PM
Transmission: M12
Erik or Steve, you ever need help with your projects... call me up. I need get used to working on cars again. :lala:
Old Nov 8, 2004 | 09:55 AM
MDv6man's Avatar
Car: 1983, 1986
LOL... yeah, I'm looking to thin the ranks out and get the 86 moving under its own power. Once they're gone, a v8 fbody is in the plans. I'd l;ove to put a 400 pontiac motor in one and keep the emissions stuff. I'd like to find/fix hop up a crssfire car, put FWD heads on one of these 2.8s,
All is about time and $$$... Neither of which is on my side
Old Nov 8, 2004 | 11:26 AM
N8PHU's Avatar
Car: 82 Camaro
Engine: 2.8L V-6
Just looked at a 87 z28. Has a 350 in it, has a few freeze plugs popped out of it, and the return line neck on the radiator broken off. Might be a nice winter project for somebody......
Old Nov 8, 2004 | 07:15 PM
twysted87's Avatar
Car: 87 gta 89 ta
Engine: 5.0 5.7
LoL.
yeah piece of cake , you could get that done in a weekend...
Old Nov 8, 2004 | 07:19 PM
twysted87's Avatar
Car: 87 gta 89 ta
Engine: 5.0 5.7
ya i second that, i need to get into doin some mechanical work, i just been doin body and interior stuff lately.. let us know we could all get together , it might make the job easier with more manpower.
Old Nov 8, 2004 | 07:24 PM
ES87iroc's Avatar
Engine: 5.7L TPI
Axle/Gears: 3.42:1
Thanks guys, sounds like fun! Stay tuned...
Old Nov 8, 2004 | 08:11 PM
megaracerx's Avatar
LoL.
git'er done!!
Old Nov 9, 2004 | 07:46 AM
MDv6man's Avatar
Car: 1983, 1986
I'm also in for traveling down to someone's place to help them with a big project. Usually I find the day goes quicker even when you run into problems.
I need help getting the 86 Camaro to start (probably a distributor position issue), along with replacing the interior plastic and a couple pieces of hardware. But this weekend it's off to Conshohocken -- $35 all you can carry, $85 all you can drag!
Old Nov 9, 2004 | 12:20 PM
  #42
N8PHU's Avatar
Car: 82 Camaro
Engine: 2.8L V-6
So whats in Conshohocken? Share with the group.....Enquiring minds want to know!
Old Nov 9, 2004 | 01:02 PM
  #43
MDv6man's Avatar
Car: 1983, 1986
Shorty's u-pull it. 4 times a year they have a pull-a-thon weekend. You can either pay $35 and everything you carry out is yours or (for the pros) pay $85 and whatever you drag out is yours. Saturday and Sunday.
I recommend getting there by 7:30 am on Saturday. Them inner city Philly people can strip and drag faster than anyone I know.
Old Nov 9, 2004 | 01:12 PM
  #44
megaracerx's Avatar
is it like a junk yard type place?
Old Nov 9, 2004 | 01:14 PM
  #45
MDv6man's Avatar
Car: 1983, 1986
Yep
Old Nov 9, 2004 | 02:22 PM
  #46
N8PHU's Avatar
Car: 82 Camaro
Engine: 2.8L V-6
I recommend getting there by 7:30 am on Saturday. Them inner city Philly people can strip and drag faster than anyone I know. [/B]
That's no joke! I used to live in the Philly area. You didn't want your ride to break down and leave it beside the road. You would come back and it would be a empty shell!
Old Nov 10, 2004 | 09:20 PM
  #47
twysted87's Avatar
Car: 87 gta 89 ta
Engine: 5.0 5.7
will they let you bring a handtruck there t drag your parts out?
Old Nov 11, 2004 | 11:28 AM
  #48
iroc87matt's Avatar
Car: 87 GMC Sierra
Transmission: auto
twysted if you go keep me in mind, you know what i need
Old Nov 11, 2004 | 11:31 AM
  #49
megaracerx's Avatar
how about 2 hand trucks?? lol....i could drag two hand trucks...
Old Nov 11, 2004 | 11:49 AM
  #50
MDv6man's Avatar
Car: 1983, 1986
I think they might. Most guys will load everything on an old hood and drag the hood around the yard. I have to find another person to help with the "carry part as I now have to pull some body parts for another job.
