Failing emissions is the coolest!! :)
Subscribe
Oct 20, 2005 | 02:55 PM
Yup failed again on the first try, I knew it was going to be bad, I smell gas when idling.
State Standards Mine
Hydrocarbons 220 Failed 452
Carbons Monoxide 1.20 Passed 0.72
No other things were checked, they asked me to idle and then i had to hold 2,500 rpm's for awhile
I knew it wasnt good after seeing Second Chance Test for both test and the time running out after like 2 minutes.
O well I better get into that chip tuning very soon.
I have untill Feb 22nd
Reply 0
Oct 21, 2005 | 05:57 PM
get like 5 cats. i dont know. i got really lucky passing mine, the chart was in the red the whole time.
Reply 0
Oct 21, 2005 | 10:46 PM
yeah i think i need an o2 sensor for starters and a nice emissions chip and disable my drivers fan to heat up well over 220
Reply 0
Oct 23, 2005 | 10:34 PM
passed before didn't it? fix the O2, get'er hot and dump 2 bottles of 90% isopropyl alcohol in it and run it up there on less than a 1/4 tank. i chanced my 02 sensor out and bingo worked for me
Reply 0
Oct 24, 2005 | 01:46 AM
https://www.thirdgen.org/techbb2/sho...ight=emissions
yeah i failed last time on the roller i went back again and they didnt do roller but idle. this time i went right to idle test as well as a 2500 rpms test in park. failed by double on the hydro's passed everything else.
yeah definitely starting with a new air filter and o2 sensor, and need to tune down the timing alittle also i think i am at 8 or 9.
this is going to be fun every 2 years!
Reply 0
Oct 24, 2005 | 11:51 AM
when i passed i was at 12 degrees advanced
Reply 0
Oct 25, 2005 | 10:57 PM
emissions was a sore subject for me till i passed thanx to the lovely lady workin that morning. i have no cat a 2inch rust hole in y-pipe and numerous rust holes at every weld on the flowmaster cat back, get someone to give you a receipt for 400 dollars of work theyll give ya a waiver.
Reply 0
Oct 26, 2005 | 12:11 PM
ehh i might make that the last resort, but i would rather pass on my own.
i am data logging my car now and want to see whats going on, it might be something easy.
Reply 0
Dec 19, 2005 | 06:46 PM
Hey,
Did you ever get your car to pass? My RS keeps failing...
12/17/05... HC 278(220 limit), CO .60(1.20 limit)= Failed HC
Go home, hook up A.I.R. line to Catco cat...
12/19/05... HC 360, CO .42= Failed HC again!
Help!
Reply 0
Dec 19, 2005 | 06:57 PM
https://www.thirdgen.org/techbb2/sho...hreadid=331758
Reply 0
Dec 19, 2005 | 07:21 PM
Hell, I already have the timing set to 0!
Im wondering if my diverter valve is stuck. Imma do a full tune up and check the diverter valve and let you know what happens.
Reply 0
Dec 27, 2005 | 11:58 AM
What's the latest, Jay?
Reply 0
Dec 27, 2005 | 01:33 PM
Quote:
Hey man...
I checked the Diverter Valve (per Haynes manual) and verified that it works.
Imma do a full tune up (cap, rotor, wires, plugs, AND ignition coil just in case...) and let you all know the results. I havent been able to do any of that yet. I was sick last week PLUS I had to get a new downpipe for the GTP. I hit something and broke the flex-joint. Thats why I was driving the Camaro daily in the first place. And to add insult to injury, I have to put another T-5 in the Camaro. Its humming its a$$ off! I think its about to take a dump...
But... enough with the whining. I will keep you all posted!
Reply 0
Dec 28, 2005 | 08:11 AM
Quote:
Originally posted by JAYDUBB
Hey,
Help!
i see your running your cat still, are you still on stock manifolds and air pump? what is your water temp at when you go in? should be HOT. 220+ when they hit the rollers. full tune up would help also a O2 sensor. i'm sure your is shot and this really lowers the HC's. you already have your timing down. goto the drug store and get 2 bottles of 90% isopropyl alcohol and pour that in on a 1/4 tank of fuel next time you go.
i don't run a cat/airpump setup and at 12 degrees advanced i passed. 02 sensor did it for me.
Reply 0
Dec 28, 2005 | 01:38 PM
Well GOSH Mic, you have a VETTE. They only passed it because its a VETTE!!!
I will try the alcohol after I tune the turd up. I will be wrenching on it this weekend...
Reply 0
Dec 29, 2005 | 08:23 AM
I will try the alcohol after I tune the turd up. I will be wrnching on it this weekend...
if that was the case i would of passed LAST spring not THIS spring
Reply 0
Jan 1, 2006 | 09:08 AM
THE RS HAS BEEN TUNED UP!!!
The plugs for cylinders 4 and 6 looked like CRAP.
I will take it through on Tuesday. Wish me LUCK!!!
Reply 0
Jan 1, 2006 | 03:21 PM
Good luck!
Reply 0
Jan 3, 2006 | 09:13 PM
I PASSED!!! THANK ***!!!
HC= 98 ppm (limit 220)
CO= .53 pct (limit 1.20)
Thank *** its over (well, at least for 2 years!!!)!!!
Oh... I think I was "fast-passed"...
Reply 0
Jan 3, 2006 | 09:37 PM
Reply 0
Jan 3, 2006 | 10:08 PM
Re: I PASSED!!! THANK ***!!!
Great!
Now, in a couple of lines, what do you think did it? That's a big change in numbers!
Reply 0
Jan 4, 2006 | 05:46 AM
Full tune up including the cap, rotor, plugs, plug wires, ignition coil AND the O2 sensor. My air filter, breather filter, and PCV valve were all new. And I recently changed the oil. Notice in a previous post that I said the the number 4 and 6 plugs looked like crap.
Oh... I also ran a half bottle of SEAFOAM through the throttle body, a half bottle in the oil, and a FULL bottle in the gas tank.
Reply 0
Jan 10, 2006 | 08:52 PM
good stuff man glad you passed!
Reply 0
Subscribe
