Mid-Atlantic Region Regional board for all of the Mid-Atlantic states. Discuss gatherings and get togethers.
MD Emissions
Old Jan 1, 2006 | 08:55 PM
crrllmich's Avatar
Car: 91 Camaro RS, 99 Camaro Z28
Engine: L03, LS1
Transmission: 700R4, T56
Axle/Gears: bunch of 10 bolts how scary is that
MD Emissions
I know there is a current emmissions post going on but Id like to get a general assumption.
Will a car pass with out A.I.R./ Smog and without EGR?
It will have a Magnaflow cat.
Old Jan 1, 2006 | 09:34 PM
MdFormula350's Avatar
yes i am missing alot of things
no egr
no a.i.r
no cats
no evap canister
just headers and a slp two on the left exhaust
with me they initially wanted to throw me on the roller, i failed that way. i came back they said well it seems its hard to control ur car, so they just do the idle only test. after that i seem to almost pass or pass barely. the latest time i went with some timing adjust and i passed pretty good.
u shouldnt have a problem with the cat on it.
they dont check under the hood, so ur safe for that part.
its either roller test of idle test.
Old Jan 2, 2006 | 02:42 PM
BlueBeast's Avatar
Car: 1985 Camaro
Engine: 565 BBC
Transmission: Glide
Axle/Gears: 9 inch/spool/3.70
a friend of mine has a 98 transam and has long tubes and a loudmouth no cats nothing and passed fine. another friend of mine had a mustang with a blower and side pipes the hole works and passed fine but the kicker with his car was it would littlery make your eyes water if you stood next to it. it passed as well. it seems it is a hit or miss thing to me. i know mine wont pass it runs on cam 2 so i jsut keep getting extensions. but with a cat u should have no problem
Old Jan 2, 2006 | 11:10 PM
Der91Z's Avatar
Car: 1993 Toyota Supra
Engine: Inline 6
Transmission: 6 Speed
Axle/Gears: 3.13
OBD-2 cars are much easier to get to pass the emissions because the emissions facilties rely on the vehicle sensors to determine if it fails or passes. It does not take a actual reading from the vehicle. Basically if its not throwing a code, you can pass on a OBD-2 car. Unfortunely thirdgens aren't as fortunate and you will need to take the sniffer test. Many testing stations do not do visual inspections but some do.
Old Jan 3, 2006 | 06:35 PM
ZZ4 86 Z28's Avatar
Car: 1986 Z28 Camaro Gunmetal Gray with
Engine: GM Crate ZZZ HO 350, Edelbrock head
Transmission: Rebuilt 700r4 all TransGo and Beast
Axle/Gears: 10 bolt with 3.73 gears
i think the visual inspection is only for the emissions part of the normal inspection.
Old Jan 3, 2006 | 08:50 PM
twysted87's Avatar
Car: 87 gta 89 ta
Engine: 5.0 5.7
Transmission: 700r4 x2
my car has air and smog equip but no cat first time failed miserably 2nd time after tune up did worse double the limit in 2 categories. 3rd time money talks. thank you miss emissions operator.
Old Jan 10, 2006 | 05:44 AM
90CamaroTBI's Avatar
Car: 91 Formula, 89 IROC
Engine: LB9, LB9
Transmission: 700R4, 700R4
Axle/Gears: Posi 2.73, Posi 2.73
Uh oh, I didnt think, but my car wont pass visual inspection without the AIR pump will it? My car is not on the road yet so it has to be inspected.
Old Jan 10, 2006 | 12:47 PM
Slimjim's Avatar
Car: 1992 Firebird
Engine: Under the hood.
Transmission: Behind the engine.
Nope. But you only have to get inspected once.
Old Jan 10, 2006 | 01:00 PM
ZZ4 86 Z28's Avatar
you can buy inspection for like 100 bucks if you look around. i know i can find someone who will do it in a matter of like 2 hours.
Old Jan 11, 2006 | 05:45 AM
Engine: LB9, LB9
Wish I knew how to look around, not trying to be obvious and get in big trouble ya kno.
Old Jan 11, 2006 | 04:52 PM
ZZ4 86 Z28's Avatar
o, well im still in school. so yea i know a lot of kids who know people who can do it.
Hotrodboba400
Dec 10, 2019 07:07 PM
racereese
Oct 3, 2015 03:46 PM
mcfastestZ28
Oct 1, 2015 11:23 AM
TBRays98
Sep 6, 2015 05:05 PM
