Mid-Atlantic Region Regional board for all of the Mid-Atlantic states. Discuss gatherings and get togethers.
My New Camaro!
Old Nov 5, 2007 | 01:36 PM
Avernus's Avatar
Car: 1988 Iroc-z28
Engine: 5.7 350
Axle/Gears: 2.77
My New Camaro!
well I've been around the boards asking questions, stating opinions, and soaking in information so that I could make an educated decision of if I should buy one of these or not. Well I made my decision and her name Is Josie.
Gotta start making it legal ya know..
Before:
After:
Thanks for looking. Opinions comments whatever are welcome.
Camaro Work
[]Difuser for right turn signal
[]Trans fluid
[]Seat belts
[]Catalitic converter
[]Muffler (flowmaster)
[]Odometer
[]Dome light
[X]Reverse light
[]Lock/unlock
[1/2]Tint
[X]Hatch light
Old Nov 5, 2007 | 01:49 PM
MdFormula350's Avatar
Re: My New Camaro!
looks good, I started out in thirdgens with a 88 iroc-z 5.7 t-tops.
Old Nov 5, 2007 | 11:20 PM
mike_c's Avatar
Car: 1989 Trans Am GTA
Axle/Gears: 9 Bolt 3.70
Re: My New Camaro!
Nice looking Iroc. Where are you located?
Old Nov 6, 2007 | 12:07 AM
Avernus's Avatar
Car: 1988 Iroc-z28
Engine: 5.7 350
Axle/Gears: 2.77
Re: My New Camaro!
I'm about a mile from Springfield Mall. I think I'm going to have this be my work zone for Josie. It's got a lot to fix and I'm going to start small. The switch for the light in the hatch was broken so I took the panel off and spliced some wires for a new switch. Here is the light in the trunk fix:
If I get some time I think I'll take care of some of this tomorrow:
Old Nov 7, 2007 | 04:30 PM
BlueBeast's Avatar
Car: 1985 Camaro
Engine: 565 BBC
Transmission: Glide
Axle/Gears: 9 inch/spool/3.70
Re: My New Camaro!
Nice looking car.
Old Nov 8, 2007 | 03:38 PM
FIRECHICKEN's Avatar
Car: '89 Formula 350
Engine: 5.7L L98 TPI
Transmission: 700-R4 Automatic
Axle/Gears: 7.5 disc posi 3.23
Re: My New Camaro!
So you got it huh? I hope I was helpful and Steveo didn't steer you to far wrong.
Welcome to the Fbody playland. Hope to see you and your car around the local cruises and meets we have.
L8R
Junk Yards are your best friend!!!
Old Nov 8, 2007 | 04:36 PM
Avernus's Avatar
Car: 1988 Iroc-z28
Engine: 5.7 350
Axle/Gears: 2.77
Re: My New Camaro!
L8R
Thanks!! Yea it was a while coming but it's now sitting in my driveway!
So the horn did something funny the other day. It fell off... I went to go shut the door and when It slammed shut the horn came on and didn't turn off. I had to jump in and basically rip the thing off. So now I needed to fix it. Heres how I did it. I noticed thats a common problem so heres a "write up" even though it's really easy.
This is where the rivetts went that broke:
Here is the metal piece that the rivets go threw:
Together:
Drill out the old rivetts, scratch up the surface with sandpaper so the epoxy can hold to something. Apply plastic Epoxy:
Set it near some heat to have it cure faster:
Make sure it's totally cured and put it on the car.
Old Nov 13, 2007 | 09:26 PM
Avernus's Avatar
Car: 1988 Iroc-z28
Engine: 5.7 350
Axle/Gears: 2.77
Re: My New Camaro!
Ok so I have a theory as to why my car smokes so bad. See it HERE. I believe that my piston rings are worn out. I also have a theory as to why it stops smoking when I drive the car for 5 minutes. I think that everything heats up and the rings expand to give better compression. Make sense? I got the car registered and titled today so I can drive it now =).I also got this in the mail
I plan on painting the louvers flat black and then mounting it somewhere in the car so It can be seen from the outside. Passing emissions is next. Wish me luck...
Old Nov 16, 2007 | 03:40 PM
BlueBeast's Avatar
Car: 1985 Camaro
Engine: 565 BBC
Transmission: Glide
Re: My New Camaro!
it could be your valve seals to. My dad had a 85 vette and it did the same thing, we replaced the seals and it was fine.
Old Nov 23, 2007 | 12:07 AM
1991 Formula's Avatar
Car: 1991 GTA
Engine: L98 5.7 (TPI)
Transmission: 700R4 Automatic
Axle/Gears: 3.23 Posi
Re: My New Camaro!
mine only smokes on start up but only after u drive it then turn it off let it sit for like 20 min go to start and then u see smoke im thinking valve guids dunno mine is a gta 5.7 tpi
Old Nov 23, 2007 | 12:22 AM
toxik IROC's Avatar
Car: 1987 Camaro
Engine: 350 hsr
Transmission: 700R4(blown)
Axle/Gears: 3:73
Re: My New Camaro!
welcome man nice project, you could rig up your hatch that the light comes on when the hatch is open, its pretty simple. What are your plans for this car?
Old Nov 23, 2007 | 06:04 PM
Avernus's Avatar
Car: 1988 Iroc-z28
Engine: 5.7 350
Axle/Gears: 2.77
Re: My New Camaro!
That is exactly what it does. maybe you andI have the same problem(s).
I found a play that does the "door style" swtiches so i was thinking about going back to do that. I hope to make it sort of a luxury/sports car. Hopefully get some new paint on it by the end of march. Then with all my tax return money I'm thinking about either
1. New interior
or
2. new speaker system
or
3. Carputer - which will most likely be what I do of the 3.
I really want to get my heat working and some heated seats in it soon because It's COOOLLLDDD in the mornings now.
Old Nov 23, 2007 | 10:18 PM
Car: 1991 GTA
Re: My New Camaro!
i guess we do have the same prob lol
Old Nov 24, 2007 | 04:47 PM
TomScott's Avatar
Car: 88 Camaro sport coupe & 90 3.1L RS
Engine: 305 v-8
Re: My New Camaro!
She's a great looking car. How did you get it..eBay motors, newspapers?
Old Nov 25, 2007 | 11:14 PM
Avernus's Avatar
Car: 1988 Iroc-z28
Engine: 5.7 350
Axle/Gears: 2.77
Re: My New Camaro!
Craigslist baby haha.
Old Nov 27, 2007 | 09:48 PM
mcgarnicle's Avatar
Car: 1991 Z28 1LE
Re: My New Camaro!
Me too in fact I started out with that exact car! That was the most reliable car I ever owned and loved it very much it was hard to let it go. You can see in the pic the same 94 insp sticker If you have any questions on some of the history on the car feel free to contact me.
Old Nov 27, 2007 | 09:50 PM
Car: 1991 GTA
Re: My New Camaro!
nice DOD stickers lol
Old Nov 27, 2007 | 10:48 PM
mcgarnicle's Avatar
Car: 1991 Z28 1LE
Re: My New Camaro!
thanks, there pretty sweet.
Old Nov 27, 2007 | 10:51 PM
Avernus's Avatar
Car: 1988 Iroc-z28
Engine: 5.7 350
Axle/Gears: 2.77
Re: My New Camaro!
OH MY GOD! Does that make you my baby's Daddy?!!? hahah! Never thought I would get to say that. Wow thanks for letting me know man! It has a stolen VIN so there is NO history on it. 1 thing that has really bothered me is the mileage. It says it has 91,xxx but it stopped working any idea on how many it really has? Has it ever been in a wreck. and lastly how did it get the scar on it's passenger front headlight?
Old Nov 27, 2007 | 11:01 PM
ryan91rs's Avatar
Car: 1991 RS, 84 El Camino conquista RIP
Engine: 5.0 (for now)
Transmission: 4L60
Axle/Gears: 2.xx torsen limited slip & 3.42 ope
Re: My New Camaro!
wow! that's cool and weired. now you know the history. lol.
Old Nov 28, 2007 | 12:31 PM
mcgarnicle's Avatar
Car: 1991 Z28 1LE
Re: My New Camaro!
I was the third owner of the IROC, and I bought it from a guy in Upper Marlboro, MD. The car was stolen from the first owner back in 91 when the vin and rpo codes were removed and then recovered and given a serial number stamped on the driver side door jamb. The odometer stopped working last December while I was driving to Richmond, it was at 191k it sure doesn't feel like that many though I've been in a couple of cars with that high of mileage and that car felt a whooooole lot more solid. As far as I know it was never in a wreck. I don't know what happened to the front probably the paint was peeling off and the other guy tried patching it up or something.
I would have kept it but I couldn't pass up on the one I have now and I didn't want to start modding it since it was all original.
I saw in one post you did about it smoking so much I would rebuild the heads and while you have them off put a mic on the piston walls and check for warpage, if it looks good then the heads should solve the smoking problem.
I can't believe you took the tint off! that gave it a lot of attitude, you know after next month you can get registered as a classic and won't have to worry about inspections and stuff.
Also The car spent most of its life in Florida. That is why the floorpans are virtually rust free.
Old Nov 28, 2007 | 10:58 PM
Avernus's Avatar
Car: 1988 Iroc-z28
Engine: 5.7 350
Axle/Gears: 2.77
Re: My New Camaro!
I will see what I'm going to do about the heads. I just might pull the whole engine which would suck... I had to remove the tint because it is illegal in VA to spray paint your windows. <- just a joke but the cops here will pull you over for just about anything. I thought they changed the law to 25 years of age for classic. However at a time you were correct about 20 years. good idea though!
As far as the miles go, thats some bad news... When i bought the car the guy told me to the best of his knowledge it had under 100k on it. In reality it probably has more then 200K... I think I may have been ripped off at this point...
From bad to worse - my car got emissionized today. They put me on a treadmill like a little hamster =( Results:
15MPH
Type Score/tolerance
HC 125/48
CO% 0.48/0.19
NO 1961/632 - Thats more then 3x whats allowed...
25MPH
Type Score/Tolerance
HC 134/88
CO .45/.28
NO 1745/614
Bad stuff guys.. I need some help at this point. I am in a little over my head. I have a high flow cat that I need to put on, but I don't have a welder. I also need some professional (or just even well educated) advise on what to do. I have some valve stem seals but I'm guessing that there is more to this than just that... I may be hitting stevo up for that engine.. Any and all help is greatly appreciated..
P.S. Mcgarnicle: Thank you so much for your input. I owe you man. Thank you for taking your time to help me with my journey. I would still be completely in the dark about the miles if not for you! One day I'll take you for a ride in the freshly painted, well running, custom interiorized, 5.7 350 iroc-z28 t-top Camaro you once owned!
Old Nov 28, 2007 | 11:02 PM
Car: 1991 GTA
Re: My New Camaro!
dude i sent u a PM
Old Nov 29, 2007 | 07:17 AM
mcgarnicle's Avatar
Car: 1991 Z28 1LE
Re: My New Camaro!
That sounds good, but I'm moving to Germany in 3 weeks, I might be back in this part of the country someday. If I had the time you could bring it up here to my craft shop that has lifts and aall the tools you would need. Like I said though after the 1st of January you can get it classified as a classic and won't have to worry about emissions. I was lucky when I had it being in the military I had it registered in Texas and didn't have to get it inspected. Good luck with everything, Kenny.
Old Nov 29, 2007 | 08:12 AM
Car: 1991 GTA
Re: My New Camaro!
yea i talked to him lastnight we are going to get her back into sexy shape lol
Old Nov 29, 2007 | 02:15 PM
Avernus's Avatar
Car: 1988 Iroc-z28
Engine: 5.7 350
Axle/Gears: 2.77
Re: My New Camaro!
yes, yes we are =) thanks again bud!
Old Nov 29, 2007 | 06:00 PM
Car: 1991 GTA
Re: My New Camaro!
dude its so not a prob but im so sick today u herd me lastnight today i cant talk at all but i still got my tail out of bed for the last nice day befor the real cold lol and i fixed the tranny
Old Nov 30, 2007 | 10:50 AM
mcgarnicle's Avatar
Car: 1991 Z28 1LE
Re: My New Camaro!
Yeah you're right I thought you were in Maryland. Oh well good luck with everything.
Old Dec 1, 2007 | 12:53 PM
Avernus's Avatar
Car: 1988 Iroc-z28
Engine: 5.7 350
Axle/Gears: 2.77
Re: My New Camaro!
did you tell daryll that it had over 100k on it?
Old Dec 1, 2007 | 09:53 PM
89formula350b2l's Avatar
Car: 92 Camaro
Engine: Dart SHP 406 HSR, LE heads
Transmission: Performabuilt Level 2, Vig 3200
Axle/Gears: S60 373
Re: My New Camaro!
nice to see another third gen in the area
Old Dec 10, 2007 | 08:37 PM
Avernus's Avatar
Car: 1988 Iroc-z28
Engine: 5.7 350
Axle/Gears: 2.77
Re: My New Camaro!
Update 12/10/07:
Fixed my heating system! The full thread can be found here.
It sure is nice seeing as it is starting to get really cold.
I ordered a seat heater for the drivers seat as test run and If I like how it works I'll order 3 more, 1 more for the camaro, and the other 2 go in the Honda s2000 (trisha).
Old Feb 4, 2008 | 07:26 PM
Avernus's Avatar
Car: 1988 Iroc-z28
Engine: 5.7 350
Axle/Gears: 2.77
Re: My New Camaro!
So I was having a little bit of a problem passing emissions. In fact my scores were 3 times what they should be!
Long story short:
I either need a waiver (means that the state sees that I spent money to fix the car then they will over look the polution) or I need it to actually pass emissions. I took the car into Amerigo and they diagnosed the problem for $75. He said I needed a new EGR valve, o2 sensor, and possibly a cat. I told him to go to work. He calls me up to tell me that the cat has been gutted (I'm not surprised). I said I'd get a new cat for him to put on. He installs everything and calls me today.The car passes emissions!!! WOOHOOO all the kings men rejoice. I now have her home and will continue to use her as a DD.
The whole story can be found with price breakdown HERE.
Stay tuned more to come soon I hope. =)
Old Feb 5, 2008 | 10:41 PM
Avernus's Avatar
Car: 1988 Iroc-z28
Engine: 5.7 350
Axle/Gears: 2.77
Re: My New Camaro!
Got another update:
Today I decided to put on the flowmaster muffler that came with the car but in between taking off the old and putting on the new I started it up without a muffler at all. The beautiful noise can be found HERE. This video doesn't disappoint for a free amazing sounding exhaust(or lack there of).
Old Jul 23, 2008 | 11:12 PM
Avernus's Avatar
Car: 1988 Iroc-z28
Engine: 5.7 350
Axle/Gears: 2.77
Re: My New Camaro!
Havn't said anything here in a while and we have some big progress so here goes.
350 ->355 with a cam, some headers and port work on the heads.
The thread is here.
There is a video there with it starting up.
Frozer!!!
Jan 19, 2024 04:55 PM
Vintageracer
Jan 10, 2020 05:33 PM
84z96L31vortec
Aug 20, 2017 12:16 AM
BADNBLK
Nov 16, 2016 09:12 AM
porkenstein
Convertibles
Aug 31, 2015 12:54 PM
