Mid-Atlantic Region Regional board for all of the Mid-Atlantic states. Discuss gatherings and get togethers.
HELP!!!1984 firebird ac delete now power steering is messed up
Old Sep 1, 2022 | 10:18 PM
1984firebird616's Avatar
Car: 1984 firebird
Hello all! I am new here. Recently bought a 84 firebird all original besides tranny. Ac pump was disconnected (no belt) so I figured it was shot and ripped it all out. After doing so I started it and went to move it and my steering is very very stiff. Under pressure right or left it makes a squealing noise but still does not turn. Ac pump and steering are not linked together in Any way correct? This wasn't a gradual issue. It was sudden. I used car ramps as I was doing some exhaust work as well. Probably not a needed note but figured the off chance the ramps had something to do with it I'd say it. Any help is appreciated!
Old Sep 1, 2022 | 10:33 PM
Komet's Avatar
Car: 1989 IROC-Z
Engine: L98 350 TPI
Re: HELP!!!1984 firebird ac delete now power steering is messed up
Check your belt tension, squealing is typically a slipping belt.
Old Sep 1, 2022 | 11:02 PM
Car: 1984 firebird
I will check it in the morning! I tend to overthink and not check simple things first lol.
Old Sep 2, 2022 | 03:00 PM
Car: 1984 firebird
@Komet you were right. Belt is loose as hell. Removing the ac compresser did I loosen a bolt to the power steering pump and cause slop?
Old Sep 2, 2022 | 05:35 PM
Komet's Avatar
Car: 1989 IROC-Z
Engine: L98 350 TPI
Dunno, I have been blessed with a serpentine belt because I'm not about the manual belt tension life anymore. There should be a bolt somewhere on one of the brackets holding your accessories that you can loosen which should allow said accessory to swing out and tighten up the belt.
RWO3
Dec 9, 2012 04:47 PM
1986mirage
Jul 28, 2012 10:04 PM
Cebas(13)
Apr 19, 2012 11:21 AM
HCR13
May 1, 2007 04:29 PM
87DeathBird
Apr 20, 2004 05:30 PM
