Mid-West Region Regional message board for WI, IL, IA, MI, MO, and MN to organize gatherings, meetings, and to help each other out.
9 bolt rear for trade
Old May 4, 2004 | 03:30 PM
BLACK ICE's Avatar
Car: 91 RS
Axle/Gears: 10 bolt
I have a 9 bolt rearend with 2.77 posi rear disk out of an 89 Iroc (yes that means 28 spline axles) that I would like to trade for a 10 bolt 3.73 posi rear disk rearend. It is still on my car so it would need to be taken off I would need some help so that would also be part of the trade anybody interested? I am in Kenosha Wi.
Old May 4, 2004 | 07:27 PM
Knyghtmare's Avatar
Car: 1991 Camaro
Engine: 2000 LS1
Transmission: 4L60E SS3600
Keep the 9 bolt. Its stronger than the 7.5 10 bolt could ever be. You can get some different gears in that 9 bolt and your set.
Old May 4, 2004 | 09:38 PM
VERTIGO Z28's Avatar
Car: FBODYS
Engine: ALWAYS 8'S
Transmission: ALWAYS MENTAL
Axle/Gears: RUSTY AND BRAND NEW
Only 850 bucks for nine bolt gears.:lala:
Old May 4, 2004 | 09:59 PM
pskel350's Avatar
i've had better luck with the 10 bolts
heres a stock 9 bolt after 1 night in my car
Old May 4, 2004 | 10:13 PM
BLACK ICE's Avatar
Car: 91 RS
Axle/Gears: 10 bolt
Im looking for somthing with more available replacment parts forget a 9 bolt I want a 10 bolt.
Old May 5, 2004 | 12:18 AM
Confuzed1's Avatar
Car: 83Z28 HO
Transmission: G Force 5 speed
How about a 3.73:1 rear, 10 bolt from a 1983 (yes that's 26 spline) one-legger with an axle that vibrates slightly?? ahem......
Old May 5, 2004 | 02:08 PM
BLACK ICE's Avatar
Car: 91 RS
Axle/Gears: 10 bolt
no thanx
Old May 5, 2004 | 07:27 PM
BLACK ICE's Avatar
Car: 91 RS
Axle/Gears: 10 bolt
Alright you guys are not helping any scaring away all the interested people! 9 bolts are not that bad I just perfer the 10 bolts.
Old May 5, 2004 | 07:59 PM
Knyghtmare's Avatar
Car: 1991 Camaro
Engine: 2000 LS1
No matter what, 9 bolts are still sronger, its been proven. I have had horrible luck with 10 bolts and so do many people I know that actually make significant power. hell, If you want my old 10 I'll trade ya, but it is only 2.73 and its drums and a one wheel wonder. You can convert all that cheaply enough. Just trade your backing plates and disc brackets ect with the 10. Finding an aftermarket posi unit for a 10 bolt is better than a stocker anyway.
Old May 5, 2004 | 09:49 PM
TheNutzZ28's Avatar
Car: 89Iroc Vert, 86 Iroc/Z28
Engine: 383carb, 350 TBI
Transmission: Th350, 700R4
Axle/Gears: 3.23 posi disk, 3.42
how about my junk car, with 3.43's 1 wheel power wonder in the back yard, with hard core drum stopping power, u know u want that, Hey its even an 89, it'll match the year of your ride. You know the number...keep the 9 bolt.
Old May 6, 2004 | 07:19 AM
BLACK ICE's Avatar
Car: 91 RS
Axle/Gears: 10 bolt
I want to get rid of the 9 bolt cause I dont have the money for the new gears for it so I just figure I will trade it to somebody that wants a stronger rearend cause for now I dont need the stronger one yet and I just figured why lose the posi and disk brakes as long as Im going for the weaker rear I might as well keep my creature comforts right? Now do you guys see why I want to trade? O-yea and the 3.73s well that should explain itself!
Old May 6, 2004 | 07:59 PM
BLACK ICE's Avatar
Car: 91 RS
Axle/Gears: 10 bolt
Ummmm............ Why am I having such a hard time geting rid of this 9 bolt? Can sombody please explain!!!!
Old May 6, 2004 | 08:39 PM
myfast3rdgen's Avatar
Car: Trans Am
Engine: 305 to 350 to 383 to BOOM!!!
Transmission: 5-speed
Axle/Gears: 3.73 10-bolt
I have a 1986 Trans Am with a 9-bolt. It is also a 2.77 and I wanted to put a bigger gear it. I thought about what you were thinking, just trade someone there 10-bolt for a 9-bolt but after When I was looking for an axle I noiced that a lot of people liked there 9-bolt and it being strongher than the 10-bolt. I called summit and they told me to call Randy's Ring and Pinion. There website is www.ring-pinion.com I got a 3.73 ring and pinion for a 9-bolt for about 170 and I am having a shop put it in for 300 so thats is about 500 for a rear end so I get to keep my disc brakes, not deal with all the hasles and still get the gear I wanted. Sorry if this is not what you wanted to hear, I was just telling you what I did. You can always check out Ebay sometimes they have read ends there. But my advice to you is just buy a gear from Randy's Ring and Pinion
Old May 7, 2004 | 12:36 AM
BLACK ICE's Avatar
Car: 91 RS
Axle/Gears: 10 bolt
What about the carrier a 3 gear wont fit on a 2 carier
Old May 8, 2004 | 08:02 PM
Car: Trans Am
you can pick one up for cheap i got mine from the yunk yard for 20 bucks and there are some selling on ebay for like 5.50 and should go up a little
Old May 8, 2004 | 10:00 PM
BLACK ICE's Avatar
Car: 91 RS
Axle/Gears: 10 bolt
For a 3 series carrier that cheap? I dont know I think I would still rather trade! Thanx for the info though. Anybody out there want a 9 bolt rear?
hectre13
Dec 11, 2023 08:14 AM
sailtexas186548
Jan 19, 2016 12:21 PM
hectre13
Aug 26, 2015 08:17 AM
1nastygta
Aug 8, 2015 07:38 PM
