Parting out 89 RS
Car: 91 RS
Axle/Gears: 10 bolt
Parting out 89 RS
Im parting out an 89 rs camaro. It is gunmetal grey with grey cloth interior. The body is not to good although it has a pretty good driver side door. It is a 2.8 ran and drove but may not anymore (engine has been stripped of most of its wiring). If you need anything the car will be here the 22-23 Oct. if not I will only strip the normal stuff. P.M. me or call me with any part requests. I also have tons of other parts for various 82-92s so tell me if you need somthing
Car: 1992 Camaro RS 25th Aniversarry Edition
Transmission: TH-700-R4
Axle/Gears: 10 bolt with 3.23's and SLP Posi.
kinda hard to explain. ill tear it apart again tomorrow and show ya. that or do you have an entire Plexiglass driver side t-top?
ok ill try to explain it and if you dont understand ill post a pic tomorrow.
on the rods that move in and out of the roof to hold the t-top in there is alarger plastic piece that is held on to the rod with some sort of spring and a clip. i need this spring and clip
Car: 91 RS
Axle/Gears: 10 bolt
I think I know what you are talking about but post up a pic I will see if I have a junk t-top to part out. By the way would thease peices be specific to the side of the car they were on and if so which side do you need?
not sure if it woud be specific but it would be fore the drivers side.
here is the pictures. there is suppose to be a black plastic thing over the metal rod and some sort of spring and clip is suppose to hold it on. here is the side that i need, Drivers side to the rear of the car.
Thats funny my junk ones seem to be missing them too
Car: 91 RS
Axle/Gears: 10 bolt
You totaly missed it we pulled the motor with a tow truckand it didnt want to come out so at one point all 4 wheels were off the ground and the car was sidways
Car: 83Z28 HO
Transmission: G Force 5 speed
Tsk - Tsk, torturing a poor defenseless Camaro.......you should be ashamed.
Car: 91 RS
Axle/Gears: 10 bolt
Sniff-sniff I know it was sad..............but so cool at the same time
P.S. Erica wanted to open the door on it so it would twist up (but I would not let her do it)
LT1Formula
20
Nov 14, 2015 12:02 AM
