Mid-West Region Regional message board for WI, IL, IA, MI, MO, and MN to organize gatherings, meetings, and to help each other out.
Old car back on the streets (video)
Old Aug 12, 2008 | 09:56 PM
Speed Racer's Avatar
Car: '87 Camaro Sport Coupe
Engine: 383
Axle/Gears: Ford 9, Detroit Locker, 35 sp, 4.11
This is my first car, and I've had it for 17 years. It used to roam the streets of East KC everyday, but it's been in the barn for the past 10 years or so while I've been replacing everything with go-fast parts. I finally got it running and all cleaned up. Here's a little sneek peek so those of you in the Kansas City area know what to look out for.
StreetFire Video ---> My Camaro Intro Teaser
Old Aug 13, 2008 | 08:33 PM
Confuzed1's Avatar
Car: 83Z28 HO
Transmission: G Force 5 speed
Re: Old car back on the streets (video)
That's a sweet ride Speed Racer! Body looks straight as can be! I could NEVER run duals like that around here....it'd last an hour before both mufflers would be on the ground.
But after looking at your weld wheels, I may just get a set for mine.
Old Aug 13, 2008 | 10:23 PM
Engine: 383
Thanks, man. Yeah, I hit a big pot hole one time and knocked off one side of the exhaust. I had to crawl under there in my new Tommy shirt and fix it on the side of the road. And a cop pulled up and told me to "move it along." What a douche-bag.
Anyway, those are Centerline Convo ET wheels. I've never seen some on another car, so do it!
Old Sep 21, 2008 | 07:07 PM
88bird?'s Avatar
Car: 1988 Pontiac firebird
Engine: built 350
Transmission: 700r4 built up to 600hp
Axle/Gears: stock for now
I think i just came.
Got any more videos?
Old Sep 25, 2008 | 07:32 PM
firebird896's Avatar
Car: '89 GTA/'86 TA/98 TA
Engine: 350/350/LS1
Transmission: R4/T5/4L60E
Axle/Gears: 3.23/2.77/3.73
I want to know your engine specs
Old Oct 1, 2008 | 12:56 PM
Frozer!!!'s Avatar
Car: '90 RS
Engine: Vortec 350
Axle/Gears: 3.23 non posi
Sweet ride. Nice work
Old Nov 11, 2008 | 10:46 PM
Engine: 383
Some specs.....
Short Block
1990 Corvette 4 bolt main
Bored to 4.030"
Decked to 9.00"
Ported and polished oil returns
ARP Pro Series main studs
ARP oil pump stud
Melling high volume oil pump
Milodon pickup (bolted, braced and welded to pump)
Milodon 7 quart stroker oil pan
Custom Milodon windage tray welded to pan
Eagle ESP 4340 forged steel stroker crank 3.75"
Eagle ESP 4340 3D H-Beam connecting rods 5.7"
Wiseco forged aluminum flat top pistons (10.5:1)
ATI SFI 29.1 153 tooth flexplate
ARP flexplate bolts
Fluidampr 6.25" harmonic balancer
ARP harmonic balancer bolt
SCE one piece oil pan gasket
K&N 10 micron oil filter
Balanced
Induction and Fuel
Dart Pro 1 215 CC aluminum heads (ported/polished)
Edelbrock Super Victor intake (ported/port matched)
Barry Grant Mighty Demon 750 mech. secondary carb
Barry Grant carb inlet kit
Barry Grant 220HR Electric Fuel Pump and bypass regulator
Barry Grant BG5000 fuel filter
Russell -8AN and -10AN steel braided fuel line
Russell AN fittings
Competition Engineering fuel tank sump (1/2" fittings)
Custom built fuel tank
Moroso 11.5" high rise air cleaner
K&N 11.5" x 2" air filter
Valvetrain
Lunati solid roller cam
Lunati valve springs/locks/retainers
Edelbrock timing set (champfered to prevent block wear)
Cloyes cast aluminum timing set cover w/ cam lash adjustment
Comp Cams Bow Tie Block solid roller lifters
Comp Cams Hi Tech custom length push rods
Comp Cams Pro Magum 1.6 roller rockers
Comp Cams 2 piece aluminum stud girdle
ARP Pro Series 7/16" studs
Valves (2.05 intake/1.6 exhaust)
Summit polished cast aluminum valve covers (plain)
Summit black annodized aluminum adjustable timing tab
Guideplates
Old Nov 12, 2008 | 06:45 AM
Trans Am#5's Avatar
Car: 1987 Trans Am
Engine: Lt1
Nice....good luck with it.
Old Nov 12, 2008 | 07:13 AM
markymarco's Avatar
Car: 89 Camaro Convert,89 Camaro hardtop
Engine: 305 and a 357
Transmission: 700R4,T5
Axle/Gears: 4.10's and 3.43's
beautiful car my friend
Old Nov 12, 2008 | 02:00 PM
Engine: 350/350/LS1
i just want to say wow again, i am very jeolous. Nice job
Old Nov 24, 2008 | 09:17 PM
84 camaro z28's Avatar
Car: 84 camaro z28
Engine: 5.7 carbed
Transmission: turbo 350
[quote=Speed Racer;3856882]Thanks, man. Yeah, I hit a big pot hole one time and knocked off one side of the exhaust. I had to crawl under there in my new Tommy shirt and fix it on the side of the road. And a cop pulled up and told me to "move it along." What a douche-bag.
lol wow that guy must have had a bad day im surprised he didn't give you a fix it ticket then cite you for noise pollution l
Old Nov 25, 2008 | 03:54 AM
BlkBird408's Avatar
Car: 89 Firebird
Engine: 408
Axle/Gears: 12 bolt/4.11
Wow man thats very nice!! Hopefully I will see you around next summer!!
9192camaro
16
Feb 3, 2019 12:21 AM
CRFred
Feb 7, 2016 11:39 PM
Reborn756
Sep 4, 2015 03:42 AM
87iroctheo
Wheels and Tires
Aug 29, 2015 09:44 PM
Dan Hubbard
Aug 12, 2015 09:05 PM
