Mid-West Region Regional message board for WI, IL, IA, MI, MO, and MN to organize gatherings, meetings, and to help each other out.
IL people where you at?
Old Aug 23, 2010 | 11:16 PM
  #151
diy_zman's Avatar
Re: IL people where you at?
Not sure where else to put this, so here goes.
It's in the genes !
Shortly after finally getting my IROC Z licensed, the grand kids wanted to go for a ride ( as grandma calls it ) in my hot rod. So I put the car seat in and buckled up the grandson ( he is 5 but really into cars trucks and trains ) and went about 2 miles outside of town and turned around. And went up to about 55 using just the first 3 gears, I look over at my grandson and his eyes are about as big as they could get and he is smiling from ear to ear, I asked if he liked that and he said YEH can we do it again ! Next time , its your sisters turn. So we pull up in front of the house and load up the grand daughter and take the same route out of town. Now I repeat the same thing for her go out turn around and go through the gears to 55. I look over at her and she senses me looking at her and turns to me ( blank look on her face ) and says " whyed you do that "
It's gotta be in their GENES lol
File Type: txt
genes.txt (973 Bytes, 98 views)
Old Aug 24, 2010 | 02:46 AM
  #152
401kfirebird's Avatar
Car: 1992 Firebird
Engine: LO3 305
Transmission: 5 speed
Axle/Gears: 3.08 limited slip
think youre on to something...my 4 yr old daughter thinks my firebird is cool and all but couldnt really care less. my 6yr old nephew absolutely loves it as well as my parents fox body convertably stang. im not saying all girls dont get it cause my fiance loves nothing more thatn crising around town in the bird with the ttops out.
Old Sep 8, 2010 | 05:36 PM
  #153
donmeca007's Avatar
Car: 1985 Z/28
Engine: Dual carbed 357
Palmyra area, have 1985 Z-28 running a tunnel ram
Old Sep 15, 2010 | 06:52 PM
  #154
RavenTA's Avatar
Car: 87 Trans am
i'm from kankakee IL
Old Oct 22, 2010 | 12:17 AM
  #155
Myiroc1's Avatar
Car: 1988 iroc-z
Engine: 383 stroker
hello here in st louis area of southern il i have a fan page on facebook i would love it if you all could to it and become a fan and post your third gens on there thanks!!!
Old Oct 22, 2010 | 06:46 PM
  #156
hartman's Avatar
Car: 1992 firebird
Engine: SBC 350
Transmission: TH350
Mount carroll, il way northwest ill over hour west of rockford about 10 mins from mississippi and hour from wisconsin line
Old Oct 23, 2010 | 06:16 PM
  #157
bigj350's Avatar
Car: 88Fbird,88Formula,04 GP,04 Durango
Engine: LO3,L98,3800,HEMI
Transmission: 700r4, 4l60e, 545rfe
Henry,IL. 30 miles north of Peoria
Old Oct 23, 2010 | 09:20 PM
  #158
diy_zman's Avatar
Hey I grew up in Henry ( the home of the Mallards lol ) graduated in 1968
Old Oct 27, 2010 | 07:16 PM
  #159
91rsmike's Avatar
Car: 91 camaro rs
Engine: 305 tbi
Im in Park City it about 5min from Gurnee Mills
Old Nov 10, 2010 | 08:52 PM
  #160
sgtmac's Avatar
Car: 87 Fomula, bought new, October 86
Engine: 305 Quadrajet,
Axle/Gears: 9bolt now in, starting on body work
Still in South Pekin, still averaging a minute a week trying to fix up the ole bird. I used to motivate the Mopar crowd around Peoria about 30 years ago, anybody want to get together and swap lies? I've seen quite a few 3rd gens in the Peoria area, maybe they haven't discovered this website yet.
Old Nov 16, 2010 | 07:34 AM
  #161
A.Delaney's Avatar
Car: 92 camaro
Engine: 409 sbc
Transmission: TH 350
Axle/Gears: 4.10, mini spool, camaro housing
Streator, IL here. Im hoping to have the engine in my car and running by the summer.
Old Nov 16, 2010 | 12:16 PM
  #162
Camaro305SB's Avatar
Car: 87 Camaro
Engine: 305 LG4 (H)
Sounds like some cool grandkids you have!
I'm in Elgin, about 25 min north west of Chicago. My 3rd gen is a total beater at the moment but I'm fixing it up, and my girlfriend has a really nice 4th gen LS1 Trans Am, we love to go cruising.
Old Nov 16, 2010 | 02:41 PM
  #163
crazyman's Avatar
I'm in Yorkville, the car is my dad's in Newark. Doing a restoration this winter. 85 sport coupe.
Old Nov 19, 2010 | 08:42 PM
  #164
Naldo's Avatar
Roselle IL here - i just completed a 350 swap on my 85 SC. Runs good, but having some low end problems. i figured with a 350 in it it would turn the tires at will, but it dogs off the line a bit. Runs like a raped ape from second gear on tho. gogt a little hood flutter going on at 70 and 80 - makes me think i need some hood pins. It still needs a bit of body work and i'm thinkin a new hood. I got the rust cookin over the drivers side headlight. seems common as ive seen it on a couple of these.
Anyone have a drivers side door that the bottom hasnt separated from the door?
Old Nov 19, 2010 | 09:17 PM
  #165
theNMBR27's Avatar
Car: 91 Z28 / 04 GTO
Engine: GMPP 350 TPI / LS1
Transmission: WC T5 / T56
Axle/Gears: 3.23 / 3.46
Naldo. Does your car buck or jerk when trying to accelerate smoothly from a stop? Could be off timing or a bad pickup coil in the distributor.
Old Nov 20, 2010 | 08:18 AM
  #166
Naldo's Avatar
it doesn't buck - it kind of hesitates as you hit the gas, then jumps. more of a ramping up than a snap on acceleration. i hit it and no spin, but it will shift about 4500 and bark second, then scream up to 3rd gear, so far at this point ive had to shut it down since im not in a place where i can just get on it whenever. i do have the timing advanced about 8 degrees. the cam spec calls for 10 degrees advanced (lunati 300 bracket master) the plugs tell me im running rich, but leaning it out doesn't seem to make a difference other than taking some power off the upper end. the distributor parts are new with no arc flashings inside to speak of. i had to replace the ignition control module right off the bat, so thats new. i did have a wire problem, but put shorter plugs in and now all the wires are clear of the headers... i'm even running 92 octane fuel. it just wont snap when you hit the acellerator
Old Nov 20, 2010 | 08:57 AM
  #167
theNMBR27's Avatar
Sounds like the ECM may be pulling timing. Are you running the stock computer with the new cam. Check the knock sensor for good ground and double check your timing is 6-8 btdc before you adjust for the cam.
Old Nov 20, 2010 | 09:38 AM
  #168
Naldo's Avatar
i actually have the thing hardwired back to basics. the only wires to the engine are going to the water temp and oil pressure sending units and distributor. i was thinking about putting the stock Q jet back on since i had replaced the TPS and Fuel mixture control solinoids before doing the swap to the 350. I'm just not sure right now what all i need to reinstall just for the carb to work. The 350 came with a holley 750 on a high rise manifold, so i abandoned the Q jet.
Old Nov 24, 2010 | 06:51 AM
  #169
i-roc the 85's Avatar
Car: an 85 iroc-z
Engine: lb9 minus the tpi
Transmission: shift kitted 700r4
Axle/Gears: ten bolt 3.73 posi
sidney il here. my maro isn't as clean as many on this page but i'm proud of her. oh and if anyone wants some tan interior, i'm gonna pick up an almost complete interior just pm me if you need any parts at all.
Old Dec 5, 2010 | 02:59 PM
  #170
Bill B's Avatar
Car: 91 camaro convertible
Engine: 355 c.i.
Transmission: auto 700R4
Axle/Gears: 3.90 moser 12 bolt
Hey 91rsmike i know that parking lot my camaros been there a time or ten on old grand
i live about 3 miles east of there
Old Dec 13, 2010 | 10:16 PM
  #171
irocket87's Avatar
Car: 87 Iroc Camaro
Engine: 5.0
East moline/quad cities here
Old Dec 28, 2010 | 11:35 PM
  #172
1986chevycamaro's Avatar
Car: 92camaro,86 camaro
Engine: 355
mattoon il alot of 3rd gens here wonder if any one in this forum
Old Dec 29, 2010 | 05:31 AM
  #173
Car: an 85 iroc-z
seriously? i never see third gens. i saw a 91 z28 clone in champaign but that was it. who else is dding your thirdgen in this crappy illinois weather?
Old Dec 29, 2010 | 04:21 PM
  #174
xxKing Cottonxx's Avatar
Car: 89 Firebird
Engine: 2.8L V6
Cicero,Il (a couple mins from midway)
I drive my car in the crap weather here and there.
Old Jan 7, 2011 | 11:46 AM
  #175
KWIK84's Avatar
Car: 1984 Z28
Engine: Alky 360
Transmission: TH400, Freakshow 9.5"
Axle/Gears: 9" 4.71
Mine hasn't seen snow since 1996....
Formerly Peoria, now back around Macomb
Old Jan 8, 2011 | 07:50 AM
  #176
Car: an 85 iroc-z
you guys are lucky, i gotta drive it daily :/ hopefully my absolutely rust free shell is still as such after this winter cus it's gonna be 350 and built 700r4 time as soon as it stays above 50 for a few weeks. someone else has to live close to champaign-urbana i need 3rd genners to hang out with not riceburners.
Old Jan 19, 2011 | 01:51 AM
  #177
Engine: 355
does any one know of any groups or just where the 3gens hung out in central il (mattoon/charleston) area.
Old Jan 19, 2011 | 08:36 AM
  #178
Car: an 85 iroc-z
we can start one, i only live an hour away and hangin with 3rd genners is worth the drive lol
Old Jan 19, 2011 | 12:58 PM
  #179
Engine: 355
that be cool we just need to find out how many 3rd genners we have in the area and are willing to hung out. so lets see how many people say yes
Old Jan 19, 2011 | 03:33 PM
  #180
Car: an 85 iroc-z
i know of a guy named mason, he lives by camargo. i always see a maroon one in champaign-urbana, and a teal 91 z in savoy.
Old Jan 19, 2011 | 10:11 PM
  #181
Engine: 355
i see alot of 3 ges here in town but dont think they are members here
Old Jan 20, 2011 | 12:42 AM
  #182
IrocZ'85's Avatar
Car: '85 IrocZ
Northbrook, IL. About 10 miles north of the city, just beyond glenview. I'm always at the summer friday night shows in rolling meadows, its a pretty big show!
Old Jan 20, 2011 | 11:50 AM
  #183
Engine: 355
well some of us dont have a show car well at least i dont i just want to hung out with some 3 gen members ans swap ideas and what not
Old Jan 20, 2011 | 02:26 PM
  #184
theNMBR27's Avatar
My car isn't perfect 'show' quality either but I take it anyway. Be proud of what you have. Most car shows don't have any thirdgens.
Old Jan 21, 2011 | 03:01 PM
  #185
native1031's Avatar
Andrew from Lake Villa Il. About 15 minutes from Gurnee
84 red z28 H.O. original
Old Jan 22, 2011 | 02:32 AM
  #186
IrocZ'85's Avatar
Car: '85 IrocZ
lol oh sorry, i don't mean its a show like that, with trophys or anything. It occurs every friday night in the summer at an abandoned parking lot and anyone is allowed to bring a car. My car isn't show quality at all, and there isn't anything too special about mine either. I've seen some really nice cars there, and some average run of the mill cars as well, and then some rust buckets. It's just fun to drive to a local cruise night and not have to pay to park my car in a "show"
Old Jan 22, 2011 | 11:40 AM
  #187
Engine: 355
well just google rolling meadows and is far drive for me almost 4 hours and no overdrive ya not going to happen so i guess im going to stick to finding some 3 gens around here
Old Feb 3, 2011 | 02:57 AM
  #188
Thridgen60's Avatar
Car: 86 Camaro
Engine: 6.0L LQ4
Transmission: 4L80E
Axle/Gears: 9 inch, 3.50
Whats up guys. Im from the quad cities area but go to school in peoria. My car stays at home in the quad cities and i drive it or work on it when i get the chance. I just finished up swapping my carbureted 6.0L ls over to fuel injection. Dont see too many thirdgens around and the ones i do are usually rust buckets but there is an occasional diamond in all the rust.
Old Feb 5, 2011 | 01:48 PM
  #189
native1031's Avatar
I pulled up in a Buffalo Wild Wings car show and all the older people were just amazed seeing one that hasnt been beat to **** or covered in rust. Even more when I told them it was an 84
Old Feb 5, 2011 | 01:53 PM
  #190
Engine: 355
Where you from native??
Old Feb 6, 2011 | 12:19 PM
  #191
native1031's Avatar
Lake villa Il. Its ten minutes east from Gurnee
Old Feb 6, 2011 | 03:06 PM
  #192
Bill B's Avatar
Engine: 355 c.i.
Hey native you have one of them amphibious camaro's ?
I think your ten minutes west of Gurnee
If you see an old geezer driving around in a 91 teal vert its me
Old Feb 6, 2011 | 04:34 PM
  #193
92z28camarokid's Avatar
Car: 97 Cummins 92 CamaroZ28, 94 GSXR750
Engine: Modded 5.9 , carbed sbc358, modded
Transmission: Nv4500, 700R4 (for now)
Axle/Gears: stock
Any of you guys going to make it down for the magic dragon street
meet nationals in lake of the ozarks in Missouri? I think we got a
couple people coming down from saint louis, It's only about 3 hours from there. Don't know if it's in reach for some of you. All the info on it is in the link below.
https://www.thirdgen.org/forums/mid-...ml#post4813850
Old Feb 7, 2011 | 08:55 PM
  #194
native1031's Avatar
Hey BILL
What do you mean amphibious? haha my camaro doesnt know how to swim haha.
I havnt seen a vert around here. Just some yellow one, and a couple beat up ones.
Sorry, I meant west. I dont know how east came up
Old Feb 7, 2011 | 09:02 PM
  #195
Staged84's Avatar
Car: 84 Z28
Engine: L69
From- Carterville Illinois- 70 miles southeast of St. Louis-
84 L69 T5
91 RS V6
84 Trans-Am
Old Mar 17, 2011 | 09:37 PM
  #196
Car: 1992 Firebird
Engine: LO3 305
im still in peoria, just got the bird out of the garage. got the fenders replaced and now getting started working on the front bumper. cheaper to tryy to fix than try to locate a reasonably priced piece for a 92. anyone wanna hang out just hit me up.
Old Mar 21, 2011 | 10:34 PM
  #197
thetatoman88's Avatar
rock island here.
Old Mar 21, 2011 | 10:46 PM
  #198
chazman's Avatar
Transmission: World Class T-5
Axle/Gears: BW 3.45
Hey I've seen your car there, it's pretty nice! I'm there almost every friday too. I've heard it's been cancelled for this year though.
Old Mar 22, 2011 | 09:34 AM
  #199
IrocZ'85's Avatar
Car: '85 IrocZ
Thanks! Is it really cancelled? I hope not because i love that cruise night, and there are always tons of cars. Did you bring your car last year? I'm trying to remember if I've seen it, i usually walk around looking for other Fbodys lol
Old Mar 22, 2011 | 10:45 AM
  #200
chazman's Avatar
Axle/Gears: BW 3.45
It would have been one of these two:
