Engine advice
Car: 1986 Z28 Camaro
Engine: Rebuilt 82' 305
Axle/Gears: Non-Posi stock =(
Engine advice
Hey all,
I would appreciate your advice for this issue. I am restoring my 1986 z28, and I am thinking ahead. I want to put a supercharger in it, and i want the think to perform high. Currently I have a 305, and I have heard that parts for a 305 are brutal to find depending on what it is. Should I stick and work with the 305, or should I upgrade to something like this? http://cgi.ebay.com/ebaymotors/82-92...spagenameZWDVW
THANKS!!
THANKS!!
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: Engine advice
if you want to have a "higher performance" engine, go with a 350. how about emissions? the t-5 will probably blow, so you have some other upgrades to think about as well.
Car: 1991 Camaro RS
Transmission: 700R4 Auto
Axle/Gears: 1 legger 2.xx(needs upgrade)
Re: Engine advice
real question is how much are you looking to spend? wats the limit? then we can help you from there
Car: 87 Trans Am GTA
Engine: 408 LS
Transmission: LS 4L60E
Axle/Gears: 9 Bolt/3.70 Gears/TAP Girdle
Re: Engine advice
buy a 350 block, buy some internals, heads, intake, carb, build it yourself or have a shop put it together. is the current motor tpi or carb?
Car: 88 FORMULA / 88 IROC
Engine: 355 / 355
Transmission: T5 / TH400
Axle/Gears: 10 Bolt-3.73 / 9"-3.90
Re: Engine advice
haha yea, I saw some used ones that needed work for 1500. That is what I was looking for...then. I finally decided though. I went to the Summer Nationals today, saw the GM performance tent, and decided. I am going to buy a 383 from them, new and drop it in.
Do you think that would somehow be able to connect with my 5-speed or do you think ill have to buy a new tranny.
Engine: 408 LS
Re: Engine advice
Re: Engine advice
Yea thats what I thought. I am going to buy the zz383 from them, it has like 400+ hp to the flywheel, and high 300's to the wheels.
Engine: 408 LS
Re: Engine advice
man you must have came into some money, because the zz383 is wayyy over the 1500 you were talking about spending.
Re: Engine advice
haha, well my money is the same. I just figured, if I am going to do it, i might as well do it insane.. hahah so I am going to wait the extra time to gather the extra money.. and purchase that, and the new tranny, and what not.
theshackle
Mar 5, 2017 06:37 PM
