Lost igintion key
Old Aug 11, 2018 | 06:30 PM
GtaAustin's Avatar
Lost igintion key
Problem: So a couple of days ago I drove my 1988 Pontiac Trans Am GTA to a festival. At that festival I lost my key. Now I had just bought the car and hadn't had time to make a copy of the key.
I have already gone and replaced the ignition cylinder with a key without a Vats sensor. Thinking that it would just fix itself. I was wrong.
the vehicle will turn on but wont turn over.
I am in deep trouble. Please is there anyone put there with a cure to my problem?
Old Aug 11, 2018 | 06:46 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: Lost igintion key
There are 15 different resistors available. You might need to try a few until you get the right one then get a key cut with that resistance.
https://m.ebay.com/itm/GM-VATS-Bypas....H0.Xvats.TRS0
Old Aug 11, 2018 | 06:47 PM
GtaAustin's Avatar
Where do I test these resistors?
Old Aug 11, 2018 | 07:10 PM
Engine: Lb9
Transmission: M20
At the bottom orf the column. There are two white wires in a orange sheath.
Old Aug 11, 2018 | 07:11 PM
GtaAustin's Avatar
So where the ignition cylinder connection goes. Thanks
Old Aug 11, 2018 | 08:19 PM
Engine: Lb9
Transmission: M20
Old Aug 11, 2018 | 08:20 PM
GtaAustin's Avatar
Thank you so much
84KYSS
Jul 4, 2008 09:15 AM
Paipe90GTA
Sep 11, 2004 08:28 PM
Timbo89GTA
Dec 20, 2003 08:19 PM
Coop89RS
Jun 9, 2002 03:54 PM
Randy92Z
Sep 28, 2001 09:44 AM
