Northern California Discussion board for Northern and Central California.
Got some leads now...
Old Jun 1, 2005 | 02:06 PM
irocdaddy's Avatar
Car: 89 iroc,2012 eco 150,roadglide
Engine: zz4
Transmission: t56
Thanks to this board, Porkyzilla (and myself) have hooked up via email/phone and will wade thru the diagnostic pool and get my Iroc out of the garage. Eric's first sugg. pull the battery and alternator to check for proper operation...will do
Old Jun 1, 2005 | 02:08 PM
irocdaddy's Avatar
Engine: zz4
Transmission: t56
Scanner was showing 11.4 volts for battery as well as f.p.
I am pretty sure tpi's don't like low voltage.
Old Jun 1, 2005 | 08:25 PM
OUTATIME GTA's Avatar
Car: '89 GTA
Axle/Gears: 3.27/9-bolt
I wasn't aware your 'maro was stuck in the garage.
What's the main problem?
Old Jun 2, 2005 | 10:14 AM
irocdaddy's Avatar
Engine: zz4
Transmission: t56
Del-
Well, it used to run. Before I had a smog inspect about two months ago, I used T.B. cleaner and might of messed it up. After driving on the freeway too downtown Sac, the idle started a severe hunting problem; rev's swinging from 500 rpm to like 2500 rpm...no codes. Then, while troubleshooting; decided to stab in my first cam and rockers. Been in the garage since. It will start up though....
Old Jun 2, 2005 | 12:40 PM
irocdaddy's Avatar
Engine: zz4
Transmission: t56
Battery and Alternator checked out o.k.
next will be maf.
Old Jun 2, 2005 | 01:56 PM
kairles's Avatar
Car: 89 IrocZ/17 LS 1LE
Engine: 383/LGX
Transmission: 400/TR-3160
Axle/Gears: 3.08/3.27
before you cleaned the tb was it running ok? how did you clean it on or off the car? other than idle does it drive ok
what Im thinking is your tb may have been real dirty and when you cleaned it it through off the IAC that had adjusted to the dirty tb
Old Jun 2, 2005 | 03:17 PM
irocdaddy's Avatar
Engine: zz4
Transmission: t56
The car ran good before the throttlebody cleaner. I cleaned it while the motor was running...didn't seem very dirty. since this fiasco, I have a new tps,iac,plugs,cap,rotor,afpr.
tested:
module
injectors
f.p.
fuel pressure
car will not throw codes. has not left the garage since the cam install which went o.k., but the rockers need more adj.
still thinking it is maf. I hope Eric will have some ideas once we gwet into it.
Old Jun 2, 2005 | 03:19 PM
irocdaddy's Avatar
Engine: zz4
Transmission: t56
The car will run, even idle w/maf disconnected. my scanner showed only 11.4 volts for battery and fuel pump voltage while the idle oscillated from 500rpm-2500rpm. Took in the battery and alternator...both passed tests.
Old Jun 2, 2005 | 08:21 PM
Car: '89 GTA
Ohh I see.
What about these. ..
PCV?
O2 sensor?
Ignition coil?
Vaccuum leaks?
If you haven't disconnected and reset your ECM that would be a good thing to do too.
Maybe the computer is whack.
I'm sure a scantool would help.
Running really lean?
I woulda thought fuel pump/injectors or MAF, but I'm no mechanic, just taking some educated guesses.
Good luck and keep us posted.
Old Jun 5, 2005 | 11:11 PM
porkyzilla's Avatar
Car: 89 iroc-z 5.7tpi 350,
Engine: 5.7tpi 350,
well david when ever you need ill come over and we will diagnose
Old Jun 8, 2005 | 04:09 AM
wills83z28cfi's Avatar
Car: 07 Silverado
Engine: 5.3L V8, flexfuel E85
Transmission: 4spd. Auto
Axle/Gears: 3.73 locking diff.
Although I don't have TPI, here is my 2 cents anyway. My car was doing the same idle hunting, I changed everything, even put in a new motor since the old one crapped out, still had the same problems when I fired up the new motor. Finally put in a new computer and prom chip and everything is fine and runs like new. The O2 is another thing I replaced and seemed to really help smooth the idle out, just a few thoughts for you, hope it works out.
Old Jun 8, 2005 | 08:52 AM
irocdaddy's Avatar
Engine: zz4
Transmission: t56
Sorry I haven't gotten back to this yet...I had a busy weekend and didn't touch the car. I will try to test a different maf this week. Also, I have a voltage draw because on a fully charged battery I had a voltage reading of 12.51 w/leads attached. Now, three days later it's 12.32 hmnnn. I have no stereo either.
Old Jun 13, 2005 | 01:29 PM
irocdaddy's Avatar
Engine: zz4
Transmission: t56
Iroc still broken!!
o.k., I finally had time to put on another maf sensor. Guess what? car still hunts for idle. I am done. My head is clouded with different test procedures on just about everything. I am giving up. I will call Eric (Porkyzilla) and see if he can come over and take a look.
Old Jun 13, 2005 | 04:11 PM
vindeezl's Avatar
Car: '92 Z03
Engine: LSX
Transmission: M12
Don't just up and give up on her, I've been in your situation quite a few times and it is always something really stupid like an electrical short or something.
Getting Eric's help is a good idea, 2 drunk mechanics are better than 1
Old Jun 13, 2005 | 04:45 PM
porkyzilla's Avatar
Engine: 5.7tpi 350,
the party is afterwards
sometimes you have to think outside the box ill bring all ive got
give me a call david
Old Jun 13, 2005 | 04:52 PM
kairles's Avatar
Engine: 383/LGX
so the car is just hunting for Idle?
I would check these first
-MAF
-TPS
-IAC
-O2
-CTS/ECT
-fuel pressure
-injector(out of car)
-timing?
-IAT?
GM did have problems with the early TPI ECM's you can check that too just unbolt it but leave it all plugged up and have the car running and just sqeeze the ECM if anything changes its bad. I don't think its you ECM if all you did was clean the TB I would think its the IAC or MAF
Old Jun 13, 2005 | 09:49 PM
porkyzilla's Avatar
Engine: 5.7tpi 350,
-MAF
-TPS
-IAC
-O2
-CTS/ECT
-fuel pressure
-timing?
-IAT?
i think its unrelated just happend at the same time
Old Jun 14, 2005 | 12:05 AM
Car: 07 Silverado
As I posted in a earlier post, I had the same idle hunting problem, racked my brain forever and replaced everything. Finally we changed the computer and prom chip and it solved the problem, check them out as Terrell said. Oh, fyi, we first replaced the computer and that helped a little bit, then we did the prom chip and that's what solved all of my problems.
Old Jun 14, 2005 | 11:19 AM
irocdaddy's Avatar
Engine: zz4
Transmission: t56
At this point, it is hard to tell what happened. I have replaced the following:
tps
iac
injectors.
plugs
fpr.
I can't even tell if all 8 are firing. It sounds like it, but maybe the idle is just real lopey. only thing not replaced was the o2, but the scanner shows it cycling. BUT....THE CHARGING SYSTEM SEEMS NOT RIGHT.
Old Jun 14, 2005 | 11:24 AM
irocdaddy's Avatar
Engine: zz4
Transmission: t56
The alternator and battery have been checked out, but the gauge in the car is at like 10 volts; not it's usual 13 ?
Old Jun 14, 2005 | 11:35 AM
irocdaddy's Avatar
Engine: zz4
Transmission: t56
I
Old Jun 14, 2005 | 11:47 AM
irocdaddy's Avatar
Engine: zz4
Transmission: t56
Another weird thing has shown up during this idle hunting...when grounding the aldl for service mode, my primary fan would not come on. I
Old Jun 14, 2005 | 11:55 AM
irocdaddy's Avatar
Engine: zz4
Transmission: t56
Sorry for the incomplete posts...can't even type right now; I keep hitting the enter key on accident.
Old Jun 14, 2005 | 12:34 PM
porkyzilla's Avatar
Engine: 5.7tpi 350,
my altenator gauge is off sometimes it shows 10 but when i get my volt meter its 14 its just a bad ground somewhere than
Old Jun 14, 2005 | 07:41 PM
Car: '89 GTA
You said the problem happened before the cam right?
Otherwise that's a whole 'nother can of worms to diagnose.
That is definitely going to change your idle in general, depending on the cam of course.
I believe you said zz4 which is 'sposed to be a good stock replacement, but it shouldn't be THAT lopey.
Old Jun 15, 2005 | 08:59 AM
irocdaddy's Avatar
Engine: zz4
Transmission: t56
Yes, the symptoms where before the cam install. The cam that went in was a lt4-hotcam (i already had the zz4 motor)
Old Jun 15, 2005 | 10:12 AM
87tpi's Avatar
Car: 00 Camaro SS
Engine: 5.7
Transmission: 6 speed
Don't know if it will pertain to you but when I had Alex's car it would idle at 700 then all of a sudded jump to like 2000-2500 rpm for about 5 seconds.It did that steady.I then noticed that whenever it would idle up his a/c compressor was kicking on boosting the rpm's and would shut off letting it idle back down,I unplugged the compressor and it was fixed,just something else to add to your list.
Old Jun 15, 2005 | 10:24 AM
Cadillac's Avatar
Car: '91 Firebird Convertible
Engine: 305 TBI (LO3)
Transmission: 700r4, Vette Servo
Axle/Gears: 3.27 9 Bolt, PBR disks
I always defalt to vacuum leaks for this kind of thing but then, I am a computer nerd.
Speaking of which, I have an extra (OEM) PROM for an 7747 ECM. If this is where the problem lies (Will's guess) then this may not help given we have the same ECM. However, this may help as a band aid instead:
TBI Chips
As with everything mechanical I suggest, take it for what it is worth: A Wild *** Guess.
Old Jun 15, 2005 | 01:43 PM
irocdaddy's Avatar
Engine: zz4
Transmission: t56
I'm gonna' try unplugging the a/c first.
I really don't think it's the chip or ecm. My chip is years old and made for the zz4 swap.
how much vacum should the motor be pulling at the base intake? I have a vacum gauge.
Old Jun 15, 2005 | 01:45 PM
irocdaddy's Avatar
Engine: zz4
Transmission: t56
I really feel the answer will be known through data logging.
Old Jun 15, 2005 | 01:47 PM
irocdaddy's Avatar
Engine: zz4
Transmission: t56
If you get a chance, go over to e-rip-off and see the 73' monte carlo ss I have been bidding on...sweet!!! triple black up to like 8100.00 I have bid 11k no dice yet.
Old Jun 15, 2005 | 01:48 PM
irocdaddy's Avatar
Engine: zz4
Transmission: t56
I guess for giggles I could swap in my stock prom.
Old Jun 15, 2005 | 04:27 PM
Car: 07 Silverado
I agree, try putting in the stock prom chip and let us know what happens. Oh, did you try unplugging the AC yet, how did it go?
Old Jun 15, 2005 | 05:36 PM
irocdaddy's Avatar
Engine: zz4
Transmission: t56
Hey Will-
No, haven't done the a/c unplug or chip thing yet. I am at work still. Lately it has been very hard mustering up the energy to work on the money pit. I do know a few here are following along, so to appease all of us I will trudge on. I will status after the swap and unplug.
Old Jun 17, 2005 | 09:14 AM
irocdaddy's Avatar
Engine: zz4
Transmission: t56
I've done all the above.....Erik your up to bat. I will call you this eve to see what your schedule looks like.
I really miss driving the Rock
Old Jun 18, 2005 | 06:04 PM
Car: 07 Silverado
Dang man, can't believe it's still giving you trouble, that really sucks. Hope Eric can help you out and get this issue resolved soon, keep us updated.
ZEEYAA
Apr 16, 2023 08:29 PM
89-IROCZ-5.0TPI
Feb 22, 2022 09:26 PM
ALIENhumanoid
Members Camaros
80
Apr 23, 2016 11:35 PM
69GTOby
Apr 18, 2016 02:34 PM
ZMWojnar
Interior Parts Wanted
Sep 24, 2015 08:34 PM
