Northern California Discussion board for Northern and Central California.
cat converter
Old Jun 10, 2005 | 06:07 PM
408smallblock's Avatar
Car: 1989 Firebird
Engine: 408 stroked out to a 427
Transmission: 700 overdrive
cat converter
is it true that cats restrict horse power cause i broke mine and it makes this rateling sound but one of the guys i ride with said **** it off and weld a pipe there it will help with horses and you do not need it since you just pasted emissions... what do you all think
Old Jun 10, 2005 | 06:25 PM
vindeezl's Avatar
Car: '92 Z03
Engine: LSX
Transmission: M12
As far as a HP drain there is a minimal difference. Maybe 5.
However if it is rattling, the small "honeycomb" material inside has broken and it can potentially block your exhaust and cause a ping or other probs.
Old Jun 10, 2005 | 07:28 PM
porkyzilla's Avatar
Car: 89 iroc-z 5.7tpi 350,
Engine: 5.7tpi 350,
wrong board but ok
to be honest its not worth the power its really small amount that you gain, the hp vs the penalties for removing it is just too severe just replace it
with a medium to large size cat converter you can get a high flowing one on ebay for pretty cheap and have an exhaust shop put it on for 30 bucks usually
Old Jun 10, 2005 | 08:17 PM
kairles's Avatar
Car: 89 IrocZ/17 LS 1LE
Engine: 383/LGX
Transmission: 400/TR-3160
Axle/Gears: 3.08/3.27
no why I would get a cat off ebay, get a REAL cat(magnaflow, dynomax, etc) and a cat out flows a muffler so the HP loss will be very low
Old Jun 10, 2005 | 08:35 PM
porkyzilla's Avatar
Engine: 5.7tpi 350,
you can get a magna flow or dynomax cat for dirt cheap my brother got a full size for $60 shipped
Old Jun 10, 2005 | 09:49 PM
OUTATIME GTA's Avatar
Car: '89 GTA
Axle/Gears: 3.27/9-bolt
How did you break it?
A common rattling is just the outside protective piece that can become loose.
Old Jun 10, 2005 | 11:52 PM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
Axle/Gears: Stock IRS
maybe he flew over a speed bump to fast? heh
Old Jun 12, 2005 | 12:35 AM
Car: 1989 Firebird
oka weill i broke it when i was leaving m girl friends house and when i was backing up from the drvie way i hit my dual exhaust pipes on the asphalt and i noticed the noise like 30 seconds later at a slow speed. i am not going to fix it because i am going to put a 408 small block and change the whole exhaust system so i do not really care at this point does that make sense
92firebirdguy
Sep 1, 2016 07:53 AM
mud runner
Nov 2, 2015 07:30 PM
Camaro_383
Sep 11, 2015 11:28 PM
89fast5oh
Sep 8, 2015 09:55 AM
Stryker412
Sep 7, 2015 09:11 AM
