Hows this for strange my car stops knocking with 89 octain?????
Car: 2011 SS/RS
Engine: LS3
Transmission: Tremic6060
Axle/Gears: good enough
Alright guys get this, Yesturday instead of just putting in 87 octain gas in my car, i put in a hole tank of the 89 octain gas, and i have no more decell after shutdown. Heres my reasoning for putting in the higher outain in my car.
Eversence i got the car running good, and pluged up all my vacume leaks, my car would continue to run on after shut down, Big old Knocks ect. Well, i was out looking for a job, and i know a guy who restores the classic mustangs (yea yea i know the dark side :P) so i went down to his shop, and asked him What could be wrong besides that it was a chevy, he said it could be because of timing (which i know its not) or it could be a Carb problem OR some one screwed with the compression, and he told me to put a higher octain in and see if that helps my problem, Guess what, 89 octain seems to be the charm for me
So either some one screwed with my compression, OR i have a serious carb problem,
Car: '72 Chevy Nova
Engine: Solid roller 355
Transmission: TH350
Axle/Gears: 8.5" 10-bolt 3.73 Posi
whatever works I guess.. I run 91 octane, anything less and I ping like a mother.
Car: 89 IrocZ/17 LS 1LE
Engine: 383/LGX
Transmission: 400/TR-3160
Axle/Gears: 3.08/3.27
wow, thats weird cause it it keeps running ofter you turn the car off thats usually the carb(or fuel injector/s on a EFI car)
Car: 2011 SS/RS
Engine: LS3
Thing is this is supposed to be a stock motor, and supposed to run on 87 octain... so, i have no clue what is going on with this engine, btw is there a fuse for the Cruise control somewhere? i have yet to locate it.
Car: 92 RS
Engine: a slow one
Transmission: a crunchy one
Axle/Gears: a whiny one
How sure are you that your timing is right?
Sounds like timing to me... Your motor would lose compression over the years if anything, not gain it.
If someone had the heads off the car at one point it shouldn't be too hard to find at least SOMETHING on the top end of the car to indicate that someones been down that far at least.
Car: 2011 SS/RS
Engine: LS3
The thing is, i have no clue to what has been done to the engine, let alone the car, the lady who i bought it from said that she took it the "dealer" to get all the work done on it, and from all the dealers ive been to only one has a record of it and it was the one who sold her the car... is it possable a Cam swap could also be to blame? The timeing also checked out so.
Car: 99 Z28
Engine: ls1
Transmission: A4
Axle/Gears: 3:42
If you set your timing to 0 tdc, you should be able to run 87 just fine. Mine is at 6 and runs ok on 87. I would be willing to bet that your timing is off. The carb or fuel injection will not cause detonation, unless it is running way to lean. If your computer is hooked up and that is happening, it is your timing.
Good luck.
Good luck.
Car: 2011 SS/RS
Engine: LS3
Car: 89 iroc-z 5.7tpi 350,
Engine: 5.7tpi 350,
well 89 is going to stop knocking it has a cooler burn temperature and is more stable
as far ias the diseling or run on that can also be caused by carbon build up inside the motor which not only raises compression but ignites the fuel inside when the motor gets hot that carbon build up heats up and causes that diseling, could also be leaky injectors in comination. i would start with a top engine cleaning not that cheap crap at kragen either have a shop do it so that the concentrate will be alot higher.
and i would put a fuel pressure gauge on prime it and see how long it holds pressure and the rate it drops
Car: '72 Chevy Nova
Transmission: TH350
Yeah, have a fuel system flush done on your car. I think we charge just over $100 for that.
Car: '92 Z03
Engine: LSX
Transmission: M12
I was thinking the exact same thing.
I used to have an old "mileage unknown" GM Goodwrench motor that had probably over 300,000 miles on it.
If you put 87 in that motor it would ping and diesel for like 10 seconds
With 91 it ran great!
Came to the conclusion that it just had so much carbon buildup inside it, that it was just picky in its old age.
I sold that engine too and it is still running today I bet
My rebuilt "Free-oh-5" a.k.a. "Wee-oh-five" will take 87 with some minor pings.
Just spend the extra $1 you cheap ****
Car: 2011 SS/RS
Engine: LS3
is there any truth to the Dribble some water down the carb and it will "Steam" clean the combustion chamber? or is it just a bunch of "hot gass" comming from the older(ie before computer controled crap) group?
because if it does do something, i might just try it, after of course i hit the Jyard to get me a "new" power break booster.
because if it does do something, i might just try it, after of course i hit the Jyard to get me a "new" power break booster. Joined: Jul 2002
Engine: 5.7tpi 350,
Car: 2011 SS/RS
Engine: LS3
Car: '72 Chevy Nova
Transmission: TH350
haha we charge 60 for that at my shop
Engine: 383/LGX
because if it does do something, i might just try it, after of course i hit the Jyard to get me a "new" power break booster. Thread Starter
Car: 2011 SS/RS
Engine: LS3
alright thanks, will do after i get this car, Safe to drive again, Just got back from the jyard, and got some interior trim and a few exterior trim pieces as well (my rear Berlinetta sticker, just need to finshesh repainting it, and i need some glue for it) got me a power break booster, so hopefully its a working one gonna put it in after it cools down a bit this eveing,
