buy my stuff instead!
Car: '02 Z06
Engine: L33 5.7
Axle/Gears: Stock IRS
stock l98 heads, need rebuild - 50 bux
comp cams xr276hr, -150. less then 2k miles. hasnt been pulled and checked yet, ill throw in all the lifters too!
pete jackson gear drive, quite cut, 75 bux. does not effect knock sensor.
another cam thats a step up from stock l98, 50 bux with flat tappet lifters, can use rollers too if you want. ran once for a few minutes is all. 204/214 duration .420/.443 lift
some crazy good 1.55" valve springs, they are the dual style. less then 2k on them as well. ill take best offer. these should not be used on a hydraulic valvetrain, leave them to the solids.
Car: '02 Z06
Engine: L33 5.7
112lsa, its the 503 part #. exact specs are .503/.510 lift 224/230 duration @ .050 and 112lsa
Car: 89 IrocZ
Engine: L98-ish
Re: buy my stuff instead!
Car: 89 iroc-z 5.7tpi 350,
Engine: 5.7tpi 350,
ill take the hyd flat tappet cam...
for $50
BumpaD82
Feb 26, 2016 02:57 PM
