Northern California Discussion board for Northern and Central California.
more parts ordered
Old Dec 27, 2005 | 09:05 PM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
Axle/Gears: Stock IRS
more parts ordered
one thing left to really buy, fuel injectors. theirs other miscelanious **** like gaskets/hardware/motormounts, so im not gonna count that
i just ordered my camshaft, i got tired over debating which one would i like best. so i went ahead and ordered it so i get it off my mind haha. what do u guys think?
Duration at 050 230 int./236 exh.
valve Lift w/1.5ratio int.510/exh.520
valve lift w/1.6 ratio int.544/exh.554
110 LSA
i said hey, if vin ran a 110lsa cam on stock tune, then so can I.
Old Dec 27, 2005 | 09:08 PM
OUTATIME GTA's Avatar
Car: '89 GTA
Axle/Gears: 3.27/9-bolt
What's the name/brand of it?
You crazy lopey 3rd genners.
Old Dec 27, 2005 | 09:10 PM
kairles's Avatar
Car: 89 IrocZ/17 LS 1LE
Engine: 383/LGX
Transmission: 400/TR-3160
Axle/Gears: 3.08/3.27
too small
edit: ok that looks better
Old Dec 27, 2005 | 09:11 PM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
comp cam
XR282HR-10 grind
im not in it for the lope. but for the power.
Old Dec 27, 2005 | 09:26 PM
Car: '89 GTA
Well yes of course.
What's the powerband and expected output?
Old Dec 27, 2005 | 09:33 PM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
powerband says 2200-5800
my last cam said 1800-5800
dunno why the newer also only advertises 5800 rpm, since it has more duration. oh well. we'll see how it runs.
this is what desktop dyno projects with exact specs, compression, flow. everything.
what do you think?
Old Dec 27, 2005 | 11:04 PM
Car: '89 GTA
what do you think?
Well who knows, every engine responds differently, especially when tuning is a big factor.
The powerband seems to be right for your application, seeing that losing torque down low doesn't matter due to the lack of it to start with the HSR.
If I go with a cam I'll be sticking with the 1500-5500 range to make the best of my TPI and 2400 stall.
Old Dec 27, 2005 | 11:11 PM
Cali Z's Avatar
will you be making any other modifications to the intake setup such as porting the TPI to at least give some breathing room for aftermarket heads and cam, or is the Edelbrock setup already free flowing enough for what you are looking for? Just curious. Glad to see it's coming together Travis.
Old Dec 27, 2005 | 11:38 PM
Car: '89 GTA
My TPI is already ported extremely well, thanks to Bennie the first year I got the car.
That in addition to the Edelbrock base/runners was done in the beginning to prepare for future mods.
Plenum/runners/manifold are all nicely ported and gasket matched.
Some mods I am flexible on, but I've always known I was going to keep the TPI setup on it and see how fast I can go.
Old Dec 28, 2005 | 12:23 AM
3.492rs's Avatar
Car: 89 IROCZ
Engine: L98 4150 carb
Transmission: Transgo 700-r4
Axle/Gears: 10 bolt/3.23
hahaha u blew ur motor!! stupid traviz
Old Dec 28, 2005 | 01:39 AM
porkyzilla's Avatar
Car: 89 iroc-z 5.7tpi 350,
Engine: 5.7tpi 350,
i thought hsr really shined after 5 grand
sweet that you got your cam orderd
Old Dec 28, 2005 | 11:38 AM
JesasaurusRex's Avatar
Originally posted by TraviZ
comp cam
XR282HR-10 grind
dude, you're a ****in rycer, you know you're in it for the lope, mr i want a 4.88 rear gear
Old Dec 28, 2005 | 03:46 PM
wills83z28cfi's Avatar
Car: 07 Silverado
Engine: 5.3L V8, flexfuel E85
Transmission: 4spd. Auto
Axle/Gears: 3.73 locking diff.
Hurry up and get all the parts bish. Glad to hear it's coming along, let me know if and when you need help with getting her up and running again.
Old Dec 28, 2005 | 06:32 PM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
first off, it was 4.56 gears not 4.88 because I love to do highway racing and i know these auto's really lack that. maybe ill save those gears for my next roc. lol
and will, are you serious about helping, or is it wishful thinking. cuz you know, i WILL take you up on that offer.
Old Dec 28, 2005 | 07:08 PM
kairles's Avatar
Engine: 383/LGX
get a 6-speed and some 2.56 gears
don't you have everything for the motor now
Old Dec 28, 2005 | 07:12 PM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
except for the bill from the shop, and fuel injectors. im gonna test fit the crank tonight and tomorrow i should be getting the cam so i ll put that in and check for rod clearance.
Old Dec 29, 2005 | 02:49 AM
Car: 07 Silverado
Yes bish I am serious about helping, let me know, I will do my best around my work schedule of course.
LT1Formula
20
Nov 14, 2015 12:02 AM
armybyrd
Aug 17, 2015 08:59 AM
GVMV
Exterior Parts for Sale
Aug 16, 2015 07:08 PM
Fronzizzle
Aug 9, 2015 01:15 PM
1nastygta
Aug 8, 2015 07:38 PM
