slippin 700's
Subscribe
Jan 11, 2006 | 10:40 PM
Hey, anyone had a 700r4 go out on them? How much time from when I have a NOTICEABLE slippage between shifts will this thing finally build up too much heat and die? burnout: <(that guys spun!)
Reply 0
Jan 11, 2006 | 11:02 PM
i had suddenly lost 3rd gear in a matter of minutes on the highway way outta town, i babied it 50 miles back to my house, and by the time i got home, i barely had first left lol
Reply 0
Jan 11, 2006 | 11:08 PM
Thats not what I wanted to hear! I guess the hotrod gets put on the back burner for the daily driver again.
Reply 0
Jan 11, 2006 | 11:11 PM
im just telling ya how it is.
sorry man
ive gone through two 700's like this.
Reply 0
Jan 11, 2006 | 11:16 PM
I think ill just go a th350 and be done with it. Who cares about gas milage, im rich after all
Reply 0
Jan 11, 2006 | 11:18 PM
time for a T5?
whatever, get it done by june 24th
Reply 0
Jan 11, 2006 | 11:20 PM
I thought about the manual, but that would be a waste of a t5 on an lo3
Reply 0
I drove mine without third gear for the better part of a year - just did some in town driving. After you get a new trannie, and if ever it gets towed, make sure they put your rear wheels on dollies. They didn't with my first trans and it fried it but good. They try to tell you that it's okay to tow it up to 25 miles, but it isn't true. The rear pump is designed to have torque/force thru the trans from the engine to the rearend. With mine, they towed it and the torque went backwards, from the rearend forward, and burnt up the rear pump. Anyways- drive it till it stops if you have to then do a quality rebuild. I found a great local mechanic that did mine for $1200 with a shift kit, stronger internals, a bit higher converter, and a poly trans mount. My first trans died at 60,000 and everyone I've talked with says the first trannie always goes quick. The key is change your oil regularly and keep it at the proper temp. Do a search for the proper temp, I believe it was 170. It's on my list of gauges to add as well. Good luck and good bowling.
Reply 0
Jan 11, 2006 | 11:23 PM
I like trying to build my own stuff first but thanks for the referal
Reply 0
Jan 11, 2006 | 11:34 PM
FWIW, I was getting some serious flare up between gears although the tranny didn't slip. I tried all that bullcrap Lucas tranny additive but it didn't work.
What I ended up doing was simply throwing a corvette servo in. It cost me 15 bucks off ebay and I had a good friend in Stockton (Ramair20) put it in for some games in trade.
After that, the flare up was gone. The remaining problem was evident at the dyno... some crap with WOT and the shift points (fuct if I know). Tony drove my car and would prolly say it short shifts but it works fine for my purposes. Worth a shot for 20 bucks or so? I don't know.
Reply 0
Jan 11, 2006 | 11:48 PM
i forgot, was your car downshifting on the dyno?
Reply 0
Jan 11, 2006 | 11:50 PM
Quote:
Not really. It was simply going into this neutral-type state between gears and just spun the engine.
Remember?
Well, it's really driveable now. Just not great for the track.
Reply 0
Jan 11, 2006 | 11:56 PM
i was trying to remember, thats why i asked.
Reply 0
Jan 12, 2006 | 02:17 AM
Quote:
you should have made them pay for you trans, cars should be towed by the drive wheels. I always asked for a flat bed when I had my car towed
Reply 0
Jan 12, 2006 | 02:37 AM
the camaro im getting has a 700 in it thats just about done. it still has all the gears, but it slips somethin fierce. i can brakestand on it, and itll stall all the way to 2500rpms. its pretty bad.
Reply 0
Jan 13, 2006 | 07:45 PM
Yeah, for 20 bucks its worth a shot. Thanks, Ill try and get ahold of one this weekend and find out if i gotta drop the pan and valve body or not.
Reply 0
Jan 14, 2006 | 01:14 PM
i've got a 700r4 trans out of an 89 RS, 53,000 miles on it, that you can have for 150.00 if you pick it up in bakersfield. email is ron09517@aol.com
Reply 0
Jan 15, 2006 | 01:18 PM
After i got my trans really really hot at an auto x and decided to do my last run anyways 2nd gear was gone complely. It just jumped from first to third with a big clunk. Drove fine though as long as i didnt go into 2nd or 3rd rather heavy on the gas. it was fine around town.
Reply 0
Subscribe
