Out with the old in with the new(almost)
Car: 89 IrocZ/17 LS 1LE
Engine: 383/LGX
Transmission: 400/TR-3160
Axle/Gears: 3.08/3.27
started to change the starter today. after some adjustments I think its in just right. I didn't get to finish, had to get a new(longer) battery cable and some wire. I need to extend the wires because they don't bolt in the same spot on the new jegs starter.
the stock starter was smaller than most I've seen
Engine: 383/LGX
only hitachi I could find at kragass was like $300. the jegs one was $135 shipped
Car: '89 GTA
Axle/Gears: 3.27/9-bolt
That stock starter is really small.
Mine was long and about 20lbs.
Is this for the IROC?
I got this Powermaster from Summit for $155.
180 ft-lbs of torque and good for 12:1 compression.
What're the JEGS stats?
My wires were not quite long enough either as they stood, but were re-routable to extend them and make it work.
Car: '88 Camaro
Engine: 5.7 L98
Axle/Gears: Borg Warner 9 bolt w/3.27 lim. slip
Engine: 383/LGX
10.5lbs, 4.41:1 gear reduction, and cranks up to 15:1 - $125.99
and this is for my 84 Z28. the starter took a dump about a month ago
Car: '92 Z03
Engine: LSX
Transmission: M12
The starter is smaller because it is for a manual transmission.
I had a brand new AC Delco for that hot rod but that's in Big Ron's Big Bird right now because it is too fat and for a crapomatic. I was glad he could find the stocker, but hey who needs a starter when you have a stick
I have that same starter and it rocks! Forget the Hitachi, it's not worth the asking price, you're going to like it
Car: 89 IROCZ
Engine: L98 4150 carb
Transmission: Transgo 700-r4
Axle/Gears: 10 bolt/3.23
hey i got the same starter too except mine is the summit name and i love it protorque starters rock *** hitachi sounds like a honda starter
Car: '72 Chevy Nova
Engine: Solid roller 355
Transmission: TH350
Axle/Gears: 8.5" 10-bolt 3.73 Posi
the stock lt1 starter is pretty small, way smaller than a stock L98 one, it's strange.
Car: '82 Z28
Hitachi starter ftw, that thing fits much better than the gear reduction starter I had before.
Engine: 383/LGX
well worked on the 84 today. turns out the wiring was worst than I thought. didn't finish, had to do some other things. I'll finish this weekend.
some pics
some pics
Car: Camaro RS/SS
Engine: 5.7 LS1
Transmission: 4L60E Transgo shift kit, 3500 stall
Axle/Gears: 4th Gen Rear 3:42
Oh man bro... Sorry to see that... Just take your time bro... Looks great by the way
Joey
Joey
Car: '92 Z03
Engine: LSX
Transmission: M12
Looks like that thing got hot and melted off that connector. It was a real tight fit in there with those stock manifolds.
At least you can wire those more out of the way now and make them a bit longer.
On a sad note I can't come up today, but on a happy note I found the stock distributor for your C.C.C.!
Engine: 383/LGX
Engine: 383/LGX
finished up the starter today and I can say it started right up with out any problems.
this was the "fix" for the wiring. I just extended the wires and bolted them some what out of the way.
this will work for now but I will clean it up when I go to put the CCC stuff back on
Engine: 383/LGX
