Northern California Discussion board for Northern and Central California.
Huge new purchase
Old Oct 5, 2006 | 02:48 PM
MiTHRiL's Avatar
Car: 93 TA, 92 GTA, 91 TA
Engine: LT1, L98
Transmission: T-56, 700R4
Axle/Gears: 3:23
Huge new purchase
Buying a lot of the parts as referenced here: https://www.thirdgen.org/forums/engi...ercharged.html
Ok, got a killer deal on the following:
The zz4 setup does have provisions for an egr valve. I will even include the valve too. All you need is a block off plate if you choose not to run egr. the block off plate is $15 from tpisor cheaper on ebay.
For the $1050 shipped you will get:
-The tpis bigmouth base
-intake bolts for the base
-checkered flag polished valve covers
-counter-sunk bolts for the valve covers
-zz4 aluminum heads
-head bolts (though I would suggest new ones and not re-use these)
-comp cams 1.6 roller tip rocker arms
-hardened pushrods
-roller lifters
-retainer plate that holds the lifters in place
-ZZ4 camshaft
All parts have 12,000 miles on them and are working correctly.
Good deal?
So, looks like I'll be able to keep the car street legal
All that, plus my MSD 6A Box, MSD coil, cap, rotor, & plugs. Also a 52 MM TB and AS&M LTR. Bought a couple carbide bits for my rotary tool, going to port match the plenum. Also have all equipment to tune and burn a new chip
Car coming together nicely....
Now, since the engine has 190K miles on it... what other internals would you guys recommend me upgrading / replacing?
Old Oct 5, 2006 | 03:24 PM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
Axle/Gears: Stock IRS
The bottom end?
Otherwise, Good price for all those goodies.
Old Oct 5, 2006 | 04:32 PM
PHAT89TA's Avatar
Car: 02 ws-6
Engine: 5.7 liter
Transmission: t56
forged shortblock. my friend knows a place that does awesome work for a hell of a price. So far that shop had done 3 of my friends 3gen motors. One that is currently in the works is a fully forged full roller 355 built for nitrous.
Old Oct 5, 2006 | 05:13 PM
MiTHRiL's Avatar
Engine: LT1, L98
Axle/Gears: 3:23
So I'd drive the car there and they'd do all my bottom end? That sounds good to me, would like some more info
Old Oct 5, 2006 | 05:37 PM
87tpi's Avatar
Car: 00 Camaro SS
Engine: 5.7
Transmission: 6 speed
Having it pulled and rebuilt would be bank. Just the labor would probably be $1,500 - $2,000. The shortblock would probably be around $2,000 for a build with good parts. You could pull the motor take it to a shop and have them build it and then you could drop it back in and save big money, if you have the know how.
Old Oct 5, 2006 | 06:39 PM
PHAT89TA's Avatar
Car: 02 ws-6
Engine: 5.7 liter
Transmission: t56
that same shop did my friends g/f forged vortec 355 tbi long block for 1300 parts labor. OF course my friend took out the engine. Parts include stock regrounded 350 crank, eagle forged rods, forged alum piston, custom cam, federal mogul bearings, ported/polished vortec heads, the block was bored .030 over, and been balanced. All my friend had to do is drop the engine in, hook up all the electrical, waterpump, headers, slap his edelbrock tbi intake and started it up.
Old Oct 5, 2006 | 06:45 PM
87tpi's Avatar
Car: 00 Camaro SS
Engine: 5.7
Well Harjeet, looks like I will be contacting you for more info on this. That's a good deal!
MiTHRiL's Avatar
Engine: LT1, L98
Axle/Gears: 3:23
Ya, that's what I'm probably looking for. Except I have the heads, cam, rockers, lifters and rods. To me, I'd need to figure a way to pull the engine and transport it. Guess I could buy a cherry picker.... but how do you transport an engine? Throw it in the back of a truck i suppose...
Old Oct 6, 2006 | 02:22 AM
PHAT89TA's Avatar
Car: 02 ws-6
Engine: 5.7 liter
Transmission: t56
thats no problem. Plus u seen the car first hand. At the bbq that omcrider threw in alameda. U met and talked to jason (his gf has the vortec 355tbi) and he brought the car.
Well my friend bought a cherry picker for $150 at harbour freight. works great. To transport the engine, throw a old tire on the bed of the truck and plop the engine on top of it.
Old Oct 6, 2006 | 11:53 AM
MiTHRiL's Avatar
Engine: LT1, L98
Axle/Gears: 3:23
I think my buddy in the city has a cherry picker
And I'm sure I could find a truck somewhere....
So can you give me some details on this shop?
Old Oct 6, 2006 | 12:01 PM
PHAT89TA's Avatar
Car: 02 ws-6
Engine: 5.7 liter
Transmission: t56
i believe its called rob machine shop in hayward. I'll get more info when i'm at my friends house. They have done awesome work on my friends car.
Old Oct 6, 2006 | 03:13 PM
MiTHRiL's Avatar
Engine: LT1, L98
Axle/Gears: 3:23
Rob's Automotive Machine
27515 Industrial Blvd
Hayward, CA 94545
(510) 732-1909
That looks like it. Also, found a kick-*** article about them here
Old Oct 6, 2006 | 04:08 PM
PHAT89TA's Avatar
Car: 02 ws-6
Engine: 5.7 liter
Transmission: t56
cool. I'll talk to my friend about ur situation. maybe he could get u a hook up there. since u know me sorta. what exactly u want done? A built forged motor or just a basic/moderate rebuild?
Old Oct 6, 2006 | 04:22 PM
MiTHRiL's Avatar
Engine: LT1, L98
Axle/Gears: 3:23
Not sure exactly. Would like the nicest possible setup with the amount of $ that I can afford. Totally open for suggestions
Linson
Oct 24, 2025 02:00 PM
ZEEYAA
Apr 16, 2023 08:29 PM
Bubbajones_ya
Oct 25, 2015 08:01 PM
HoosierinWA
Oct 7, 2015 10:15 AM
HoosierinWA
Members Camaros
Sep 29, 2015 12:43 PM
