Injectors Needed
Car: 93 TA, 92 GTA, 91 TA
Engine: LT1, L98
Transmission: T-56, 700R4
Axle/Gears: 3:23
Injectors Needed
Hey guys, looks like at least 1 of my injectors is bad and hence causing a lean condition making my emissions fail. Anybody have a set of good injectors? If I had my choice I'd like Ford SVO 24# but something comparable would work. Let me know whats up
Car: 92Z28,91Z28,91Z281LE,95ZR-1,08Z06
Engine: 406, 350, 305, 350, 427
Transmission: auto, auto, 5-speed, 6spd, 6 spd
Axle/Gears: all stock
If you have an injector leaning out, the oxygen sensor will see high O2 level. The computer will compensate for the high O2 which will make it run richer. The CO level would be high and NOx will be low. If 1 of your injector is really leaning out, you car would have failed CO and possibly pass NOx.
Engine: LT1, L98
Axle/Gears: 3:23
All the info im getting from people is completely different. you're saying a faulty / plugged / leaky injector wouldn't affect my nox?
Car: '92 Z03
Engine: LSX
Transmission: M12
