Northern California Discussion board for Northern and Central California.
I GIVE UP....
Old Oct 19, 2006 | 01:39 AM
porkyzilla's Avatar
Car: 89 iroc-z 5.7tpi 350,
Engine: 5.7tpi 350,
I GIVE UP....
i can not launch my car right...the best 60' i could pull was 2.3 which = a 14.3 at 99.9mph
i will launch about 3 grand it will spin just the right ammount than it will catch and bog i just dont get it...
so for this time i give up and am gonna add that stupid ram in my garage and than run it again...
and after that i dont know i will have to decide whether to get my hard top or what.
well cameron what does that say i could pull a 14.2 at 101 with stock g92 n10 dual cats, and bigger manifolds, and stock muffler.
now i have headers, y pipe, and cat delete.
Old Oct 19, 2006 | 01:42 AM
xpndbl3's Avatar
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
buy slicks...?
vindeezl's Avatar
Car: '92 Z03
Engine: LSX
Transmission: M12
If cameron had the wing he would totally be in the 13s
I think launching and you just don't mix bro.
I'm all for project Bel Air!!!
Old Oct 19, 2006 | 01:53 AM
porkyzilla's Avatar
Engine: 5.7tpi 350,
i second that...
Old Oct 19, 2006 | 01:58 AM
vindeezl's Avatar
Car: '92 Z03
Engine: LSX
Transmission: M12
Yeah then we can just drop it and crooz
Time for a 327 and a Powerglide for you haha
Old Oct 19, 2006 | 02:02 AM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
Axle/Gears: Stock IRS
Eric , out of pity I will offer up a straight trade, automatic and torque converter for your T-56. Then all you do is bring the R's up, and floor it and just pedal it so you don't spin as bad. No bogging at least!
Old Oct 19, 2006 | 02:12 AM
vindeezl's Avatar
Car: '92 Z03
Engine: LSX
Transmission: M12
I don't seem to have this "bog" when I launch...
Maybe your motor has ate another dizzy gear.
I mean they are quite tasty.
Old Oct 19, 2006 | 03:22 AM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
Mud bog? keep the thirdgens out of the dirt!
Old Oct 19, 2006 | 11:26 AM
koolctk's Avatar
Car: 1989 Trans Am GTA
well eric it still does make sense that you run better with your stock exhuast than aftermarket with no cat, and headers, but maybe its the backpressure or some **** that you lost..........
or just really crappy driving .
and your right vin, my car is a 13 second car, especially with 50 extra pounds.
Old Oct 19, 2006 | 11:32 AM
87tpi's Avatar
Car: 00 Camaro SS
Engine: 5.7
Transmission: 6 speed
What were you running with the auto Eric? Atleast you're not running 15's (damn 305) I don't even know why I keep buying them. Do you let the clutch out fast or ease it out?
Old Oct 19, 2006 | 11:47 AM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
I think Eric just drops the clutch and floors it.
Old Oct 19, 2006 | 11:56 AM
87tpi's Avatar
Car: 00 Camaro SS
Engine: 5.7
Well I think that's your problem Eric. Ease the clutch, quickly, but ease it out.
Old Oct 19, 2006 | 12:14 PM
OUTATIME GTA's Avatar
Car: '89 GTA
Axle/Gears: 3.27/9-bolt
I've been tellin' this guy for daaaays to ease into it and don't launch so high up.
You should've decreased it each time to see if it changes or reduced the bog.
No 13's for you buddy.
Old Oct 19, 2006 | 12:46 PM
porkyzilla's Avatar
Engine: 5.7tpi 350,
well i am not roasting them like i used to do, i am slippin the clutch a little bit
but its like i get the proper ammount of spin than mid to upper 1st gear it catches and than bogs its very mind boggling.
i will have video up tonight or tommorrow... it does make me feel better my brother did worse like alot worse he got a 2.8 60' but he was side steppin the clutch at like 3,500 lol he got 2 runs in ill let him have the car one night so he can get a feel for it.
and cameron youll be lucky to get a 15 the way your car is running right now lol get it fixed.
Old Oct 19, 2006 | 01:50 PM
koolctk's Avatar
yes i know i need to fix it porky, bennie said that he was focusing on theat intrepid engine swap, so let me know when i can come over to do the diag.
Old Oct 19, 2006 | 04:38 PM
porkyzilla's Avatar
Engine: 5.7tpi 350,
mon or tues should not be a prob that intrepid will be done today
Old Oct 21, 2006 | 01:59 AM
Jeremy_84_F41's Avatar
Car: 1991 Formula L98
Axle/Gears: 3.73:1
I think slicks and a 6000rpm clutch drop oughta take care of your problem. As for the bog once it hooks, well, there may be other issues with the car other than your driving style...
Old Oct 21, 2006 | 12:24 PM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
That's a given. lol
Old Oct 25, 2006 | 01:01 AM
TMoNeE's Avatar
Car: 87 Z28
i have a pair of 15x10 weld prostars w/ brand new 325.50.15 DR's that might help you
Old Oct 28, 2006 | 04:13 AM
neagan's Avatar
Car: 1988 IROC 5.7 Money Pit
Engine: (being built; modified TPI ZZ4
Transmission: 2200 stall/ stage 3 700R4
Axle/Gears: freshened 3.27 in 9.bolt/
Re: car pulling into a bog...
Out of curiousity, have you had your PROM done since you did all that work to your ride????? Sometimes it can really help everything to work in synk.
Just a quick thought, Nitro
Old Oct 29, 2006 | 12:02 PM
porkyzilla's Avatar
Engine: 5.7tpi 350,
i have a little bit done, i have a bit more aggressive timing map, and compesated for the 24lb injectors. thats it
it feels pretty good power wise.
bjpotter
Oct 4, 2015 07:48 PM
racereese
Oct 3, 2015 03:46 PM
Fanatic1074
Oct 2, 2015 03:47 PM
Spyder_TheGamer
Oct 2, 2015 12:25 PM
Linson
Oct 1, 2015 09:50 PM
