Thirdgen Accomplishments
Car: '02 Z06
Engine: L33 5.7
Axle/Gears: Stock IRS
What lists can you guys come up with that you have been able to do yourself with your thirdgen?
I have done everything from building engines/swapping engines. A/c delete, Transmission swaps, Helped with T56 conversions, Driveshaft swaps, Axle swaps, Spring/shock/strut install, Dropped the gas tank for fuel pump, removed and installed exhaust piping, Recently doing a k-member/A arm swap, Repinned an ecm from maf to speed density. Replaced a window in a door, changed door panels, all interior plastics. And did a h4 conversion to the headlights complete with relays.
What list can you guys come up with?
Car: '89 GTA
Axle/Gears: 3.27/9-bolt
Don't forget blowin' up a couple of those engines and rollin' a 3rd gen.
Those are big accomplishments that you did yourself.
Hmm, pretty minor stuff in my list, but I've done a lot of maintenance and part swaps since I've owned 2 thirdgens over 9+ years, most on my 'ol v6.
Bennie has done most of the good stuff on the GTA.
front bumper
fenders
hood
shocks
brakes
rebuilt pop-up headlight motors
rear hatch motor
hood/trunk struts
window motors
underbody neon
headlamps/misclights/bulbs
stereo/speakers/decks
minor tuning
oil changes
front bumper
fenders
hood
shocks
brakes
rear hatch motor
hood/trunk struts
window motors
underbody neon
minor tuning
oil changes
Car: C230 Kompressor
Engine: 2.3L Supercharged I-4
Transmission: 5-Spd Tiptronic
Car: '89 GTA
I used the rebuild kit that Lon @ TDS makes (sponsor on the right).
~$20.00 and takes couple hours tops.
99% of the time, the motors are fine and the 3 gel bushings inside the gears crumble to pieces over time.
You put the new bushings in, grease, seal and they'll last another decade or 2.
Car: '72 Chevy Nova
Engine: Solid roller 355
Transmission: TH350
Axle/Gears: 8.5" 10-bolt 3.73 Posi
i've done everything on my own cars except exhaust welding (dont have a welder), body work/paint and rear gear setup.
i've never built a motor/put one in for my own car but i've done plenty of other people's cars.
Car: '82 Z28
The list would be too long. The major stuff though is basicly, a whole new drivetrain, new paint job twice over when I finish the current one, windows that go up and down with doors that close nice.
Car: Camaro RS/SS
Engine: 5.7 LS1
Transmission: 4L60E Transgo shift kit, 3500 stall
Axle/Gears: 4th Gen Rear 3:42
MY LIST:
Buy My 89 camaro
2000 camaro leather seats
New head liner
stereo system
LS1 brakes All the way around
2000 LS1 Motor swap/Tranny
2000 SS Camaro rear end (3:42)
Transgo Shift kit
New tires
New rims
New Paint
SS Hood
AIR BAG's!! (all the way around)
SFC
I think thats it??? LOL
Buy My 89 camaro
New head liner
stereo system
Transgo Shift kit
New tires
New rims
New Paint
SS Hood
SFC
Car: 1988 GTA Black notchback
Engine: 1991 L98 355 TWIN Superchagred
Transmission: 700r4 shift kit 2500 stall
Axle/Gears: www.cardomain.com/id/gtafanatic
This thread would be two pages long if i listed all i have done but i will list a few things.
Body and paint this year new hood, door hinges gaskets freshly powred rims
Last year all sup work rear end 373 adjustable rear sup front end worked
The year before Eng work you name it i did it all the way up to the blower down to the headers and tips. I did all the work myself if you want to know more info feel free to ask.
Car: 91 Formula WS6
Transmission: five speed
Car: '72 Chevy Nova
Transmission: TH350
Car: '88 Camaro
Engine: 5.7 L98
Axle/Gears: Borg Warner 9 bolt w/3.27 lim. slip
TraviZ, you are the MAN! All joking aside, I respect your ambition to learn and do things yourself!
I have to say, not growing up around a shop/tools, I didn't learn anything until I went to high school and took Auto class. There I learned basic maintanence(plugs,wires,oil/air filter,etc.). I rebuilt my '54 Chevy's single barrel carb there as well as a water pump on my parents '77 Oldsmobile. As far as my thirdgen accomplishments go, when I have time I do as much as I can. I had my cat flanged(as well as a straight pipe), but did the install myself. I took the body fx and spoiler off for the painter and re-assembled it. I gutted the air box and de-screened the MAF. I replaced the alternator. I removed my A/C and put in the delete pulley(heater box in the mail). I recently did the rear latch motor and struts. In the near future I need to replace my headliner, install an amp/rear subs, re-route my battery to the rear, and eventually put an alum. motor/heads, T-5, carbon fiber driveshaft, tubular K member w/ A arms,etc. RU-QWIK has helped me with a number of things(polished intake, replace head gasket, etc.) Camaero has helped me learn about PROM stuff. TraviZ, you have always been there to answers 3rd gen ?'s for me as well. Thanks
I have to say, not growing up around a shop/tools, I didn't learn anything until I went to high school and took Auto class. There I learned basic maintanence(plugs,wires,oil/air filter,etc.). I rebuilt my '54 Chevy's single barrel carb there as well as a water pump on my parents '77 Oldsmobile. As far as my thirdgen accomplishments go, when I have time I do as much as I can. I had my cat flanged(as well as a straight pipe), but did the install myself. I took the body fx and spoiler off for the painter and re-assembled it. I gutted the air box and de-screened the MAF. I replaced the alternator. I removed my A/C and put in the delete pulley(heater box in the mail). I recently did the rear latch motor and struts. In the near future I need to replace my headliner, install an amp/rear subs, re-route my battery to the rear, and eventually put an alum. motor/heads, T-5, carbon fiber driveshaft, tubular K member w/ A arms,etc. RU-QWIK has helped me with a number of things(polished intake, replace head gasket, etc.) Camaero has helped me learn about PROM stuff. TraviZ, you have always been there to answers 3rd gen ?'s for me as well. Thanks Thread
Terrell351
Jun 13, 2021 01:13 PM
