Northern California Discussion board for Northern and Central California.
Winter plans? + Summit = retarded, but makes good.
Old Nov 20, 2006 | 01:12 AM
  #51
porkyzilla's Avatar
Car: 89 iroc-z 5.7tpi 350,
Engine: 5.7tpi 350,
Originally Posted by TraviZ
Well plans are still pretty straight forward, All forged, low compression, about eight and a half dynamic. supercharged, either Jeremy's unit or I'll get one elsewhere. Kinda blew him off for now and bought other stuff instead. AFR heads, same cam but on a 113 LSA and 4/7 swap. tubular k member/ A arms on order. I have the new wheels with fat tires for traction, When I get it running, 4.10's in the rear. I shooting for 15psi, with 100shot nitrous on top of it, I think I can't find reasonably priced pistons to lower my CR enough to run the 20psi Del recommended, but I am open to suggestions. In fact, I am going to go build me a new sig
than youll just need a cage and paint first time at the track youll get kicked out
sounds friggin awesome traviz
Old Nov 20, 2006 | 01:19 AM
  #52
OUTATIME GTA's Avatar
Car: '89 GTA
Axle/Gears: 3.27/9-bolt
Did I recommend running 20psi? haha, not so much.
Lofty goals man, just take it a step at a time, plans will change as you go along I'm sure.
Old Nov 20, 2006 | 01:34 AM
  #53
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
Axle/Gears: Stock IRS
Seems they change daily. Worst part is figuring out what dynamic/static compression I will have, and what I need for what I can handle. If I can figure this out, I should have all parts bookmarked for order.
Hey, I updated my sig to show all parts I will have/do have as I see fit right now, Left out the S/C cuz I'm not sure what model i will end up with or what psi I will be running, but thats my parts list for anyones reference.
Old Nov 20, 2006 | 11:55 PM
  #54
valencia1z's Avatar
Car: 1986 IROC-Z
Engine: 350 5.7 TPI
Transmission: 700R4 2500 stall
traviz if ure still trying to figure it out for parts or rotating assembly look up speedomotive.com or just give them a call and tell them what ure trying to do theyl set u up just tell them what heads and gasket and he will get u in the right direction
traviz if ure still trying to figure it out for parts or rotating assembly look up speedomotive.com there in southern cali or just give them a call and tell them what ure trying to do theyl set u up just tell them what heads and gasket and he will get u in the right direction there prices are real good u might just get a complete short block from them and there fast couple days
Last edited by valencia1z; Nov 20, 2006 at 11:58 PM. Reason: Automerged Doublepost
Frozer!!!
Jan 19, 2024 04:55 PM
PestilenceIV
Aug 20, 2015 03:32 PM
86White_T/A305
Aug 17, 2015 12:16 AM
MustangEater82
Brakes
Aug 11, 2015 07:52 AM
