oil pan!
Car: '02 Z06
Engine: L33 5.7
Axle/Gears: Stock IRS
oil pan!
ordered myself a christmas present
anyone need a stock oil pan? it works fine and has been clearanced for stroker applications.
For my blower that is not self contained, I am going to tap this pan for the fittings and have them welded in to prevent any leakage from happening. Yay for AN fittings.
Car: '92 Z03
Engine: LSX
Transmission: M12
Re: oil pan!
I bought a chrome Moroso pan for my Poncho and now I know the true meaning of "leaks like a sieve"
Is that the plain steel one?
Hopefully with the SBC 1pc gasket you will avoid all the trouble I had with mine, I know others with the SBC one that have had fun too. IMO stock GM pan seals better.
Hope your feelin' better bro
Car: '02 Z06
Engine: L33 5.7
Re: oil pan!
it is a one peice gasket, one peice rear main seal, and its actually just a steal pan, zinc according to the description, picture is a little off.
I agree, had to stay away from chrome.
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
Re: oil pan!
Keep the stock pan around for a while. The aftermarket pans are notorious for not fitting with the thirdgen y-pipe and the k-member. You might have to do some clearancing.
