Northern California Discussion board for Northern and Central California.
Here we go again. :-)
Old Apr 21, 2008 | 07:49 PM
Cadillac's Avatar
Car: '91 Firebird Convertible
Engine: 305 TBI (LO3)
Transmission: 700r4, Vette Servo
Axle/Gears: 3.27 9 Bolt, PBR disks
I know some of you gents have been known to play around under your car:
https://www.thirdgen.org/forums/tran...ml#post3726879
I hope I didn't goof with the new rear (that drives fabulously). Did that sound gay?
Nevermind.
Old Apr 21, 2008 | 09:36 PM
Jeremy_84_F41's Avatar
Car: 1991 Formula L98
Axle/Gears: 3.73:1
Re: Here we go again. :-)
There is a speed where the driveshaft will start to make harmonic noises, but being 3" and aluminum, and with 3.27 gears, you won't have to worry about that.
The simplest way for you to eliminate the u-joints as the cause of the noise is to swap in your old, steel, known good driveshaft. Noise goes away, put in new u-joints. Noise still present... then it's something in the rear axle housing.
Old Apr 21, 2008 | 09:55 PM
Cadillac's Avatar
That was mentioned but I ditched the steel shaft years ago.
Worth a replacement to see if that is the problem? What do they go for these days? 100 bucks or so? Anybody got one on the peninsula I could borrow?
Old Apr 22, 2008 | 02:16 AM
vindeezl's Avatar
Car: '92 Z03
Engine: LSX
Transmission: M12
Mike, I got you covered with my spare bro you're welcome to try it out and see if it helps.
I'm not Peninsula though
Old Apr 22, 2008 | 07:17 PM
Ramair21's Avatar
Car: Camaro RS/SS
Engine: 5.7 LS1
Transmission: 4L60E Transgo shift kit, 3500 stall
Axle/Gears: 4th Gen Rear 3:42
I thought it was your E-Brake cable rubbing on the drive shaft??
Old Apr 22, 2008 | 09:55 PM
Cadillac's Avatar
Fixed that. Now I am afraid this rear is a dud.
Vin... I'll drop you a PM about getting in touch on the phone. Thanks!
Old Apr 22, 2008 | 10:24 PM
cooter26's Avatar
Car: 83 Camaro
Engine: 383
Axle/Gears: 4th gen 10 bolt 3:42 POSI
I would yank the driveshaft while its on the lift and first pull up and down on the pinion if it has any play your bearing is shot, if not press in some new u joints and try it, there pretty cheap. You can also take the shaft to a shop and have it balanced. While you have it off pull up and down on the transmision output shaft and see if thats your problem. Oh yea have a plastic baggie and a rubberband ready when you pull it from the tranny.
Old Apr 22, 2008 | 10:26 PM
87tpi's Avatar
Car: 00 Camaro SS
Engine: 5.7
Transmission: 6 speed
My blazer made a metal to metal sound before and the pinion bolt was loose, tightened it and it went away.
Old Apr 23, 2008 | 08:57 AM
Cadillac's Avatar
It sounds like two, circular metal rings sliding in opposite directions from each other, one inside the other. The sounds gets louder as the speed increases.
I'll check these two things: Pinion bolt, tranny output shaft.
Thanks guys!
NZKnight
Oct 15, 2015 02:47 PM
88CamZ
Oct 8, 2015 10:29 AM
TheCardinal
Exterior Parts for Sale
Oct 1, 2015 07:40 PM
FormulaEngland
Sep 30, 2015 01:50 PM
