Northern California Discussion board for Northern and Central California.
Got a problem guys!!
Old Jun 30, 2008 | 11:43 PM
kahless's Avatar
Car: 89 Firebird Formula
Engine: chevy 5.7 V8 TBI but carbed soon
Axle/Gears: no freakin clue lol
The HELL with this place
Hey guys i was just wondering if any of you guys have had this problem. When my car reaches 220 degrees i notice after i park that i have a few drops of oil on my garage floor. The leak seams to be coming from in between the oil pan and the tranny. I has wondering if im running to hot because my fan doesn't kick on until i reach 220 so i though that the oil might be thinning out do to the temp and seeping from the rear main seal??? So what temps do you guys run under normal driving?
Old Jul 2, 2008 | 06:59 PM
kahless's Avatar
Re: Got a problem guys!!
I cant believe my eyes!!! 35 VIEWS and not a single reply. What the hell is going on here!! So you mean to tell me that 35 of you dont have a firebird or camaro but you look at the posts any way??
Old Jul 2, 2008 | 07:33 PM
IROC350TPI's Avatar
Car: 89 IROCZ28
Engine: 350TPI
Axle/Gears: 2.77 Gears
180-200 degrees under normal driving. Fans come on at 220 as well. No oil leaks tho. Chill out!
Old Jul 2, 2008 | 07:35 PM
kahless's Avatar
Thank you that is what i was looking for!!!
Old Jul 2, 2008 | 07:41 PM
OUTATIME GTA's Avatar
Car: '89 GTA
Axle/Gears: 3.27/9-bolt
A simple bump with a "hey look at me" reply would have been more sufficient.
You've received an infraction for the above post that I cleaned up, but I'll be a nice guy and keep this open for other responses.
Usually the secondary fan, if you have dual, comes on around that temperature, probably a single as well.
Your stock thermostat is 195*, so normal driving is typically around 200* and then will then creep up to ~220-230* if hot and idling.
Old Jul 2, 2008 | 07:44 PM
vindeezl's Avatar
Car: '92 Z03
Engine: LSX
Transmission: M12
Your leak is one of two things, your rear main or oil pan gasket, neither are fun to change.
220* is normal for a stock application.
Which is too hot for me, much like your head in post #2.
Old Jul 2, 2008 | 08:17 PM
UnderCover89TBI's Avatar
Engine: gone
Transmission: gone
Axle/Gears: gone
:rofl: nice!
Old Jul 2, 2008 | 08:29 PM
Car: '89 GTA
Forgot to mention I have a 180* thermo and my fans on earlier via fan switch/tune, so I don't see temps over 190*.
Old Jul 2, 2008 | 09:34 PM
kahless's Avatar
LOL you know guys im sorry the formula is just getting on my nerves lately!!! I apologize to all. I appreciate everyone here and again im sorry. I guess i did get a little hot lol
I know how to change the rear main but the oil pan do you have to pull the motor or can i remove the front cross member?
Old Jul 2, 2008 | 09:49 PM
87tpi's Avatar
Car: 00 Camaro SS
Engine: 5.7
Transmission: 6 speed
For the oil pan, you just lift the engine up a couple of inches.
Old Jul 13, 2008 | 11:42 PM
neagan's Avatar
Car: 1988 IROC 5.7 Money Pit
Engine: (being built; modified TPI ZZ4
Transmission: 2200 stall/ stage 3 700R4
Axle/Gears: freshened 3.27 in 9.bolt/
My engine does the same thing. For me, it warms up and softens the old valve cover gaskets just enough to leak down the back of the engine and pools along the oil filter. I havn't changed them as I'm working on getting my IROC ready to drop in it's new ZZ3 & 3/4's powerplant. (should take about one more year at this rate.....) Nitro
Old Jul 15, 2008 | 08:36 AM
TransAm_85's Avatar
Car: 1985 Trans Am
Engine: built 355
Transmission: th350
Axle/Gears: Borg warner 3.08's
Have you checked ur valve covers? Mine would leak out the back when the engine was warm. It ran down the back of the block and dripped on my cat which made my car smoke like crazy.
Infested
May 22, 2018 11:56 PM
Cleotiz
Jan 6, 2018 08:56 PM
86IROC112
Apr 9, 2016 10:20 PM
Spyder_TheGamer
Dec 25, 2015 05:07 PM
Street Lethal
Aug 14, 2015 08:25 PM
