Northern California Discussion board for Northern and Central California.
swapped a motor, needed local information.
Old Jan 25, 2009 | 02:02 AM
osirus's Avatar
Car: 89' RS
Engine: 350 TBI
Axle/Gears: 2.73 posi
Okay, the motor hasn't swapped quite right now you know, but it'll be mostly done this week (knock on wood). Now, I know that the smog tech is going to know something is up when they pop the hood and this giant "5.7 liter" air cleaner sitting on top of a tbi unit is in the place of what should be a 5.0 carb.. my question would now be, where would I expect to find a smog ref? Also, i have headers on the 350 WITH a carb sticker. is that cool?
Thanks,
Eddie.
Old Jan 25, 2009 | 05:31 PM
UnderCover89TBI's Avatar
Engine: gone
Transmission: gone
Axle/Gears: gone
Re: swapped a motor, needed local information.
stockton, modesto, sacramento all have smog referees. I dont know where else. good luck.
Old Jan 25, 2009 | 08:01 PM
3rdBird's Avatar
Car: 91 Pontiac Firebird
Engine: Killer SBC, w/ RV cam
Transmission: AutoMatic, w/ shift kit
Axle/Gears: Posi-Traction
CARB sticker is ok
conatact the BAR
1800-952-5210
Old Jan 25, 2009 | 10:14 PM
3rdBird's Avatar
Let me know what you come up with, I'm looking to do a TPI or LS1 swap on a 77 Trans Am.
Old Jan 25, 2009 | 10:22 PM
Bullydawg's Avatar
Car: 88 Formula 350
Engine: 5.7
Axle/Gears: 9" 3.89
Chico also has a referee if you need.
Old Jan 25, 2009 | 11:43 PM
osirus's Avatar
Car: 89' RS
Engine: 350 TBI
I may. tbi is way noticeable
Old Mar 12, 2009 | 04:05 PM
rwolf5500's Avatar
you might want to look at the dampner 305 and 350 are totally different? 305 is much wider and if they are on there game they will notice and know something is wrong ? just something to think about?good luck!
Old Mar 12, 2009 | 04:13 PM
rwolf5500's Avatar
Old Mar 15, 2009 | 08:25 PM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
The smog ref, after going over the car with a fine tooth comb, is going to recertify the car as a 91-93 Caprice. That's a legal swap provided everything is hooked up.
MustangBeater20
Oct 29, 2022 09:20 PM
1992rs/ss
16
Jan 28, 2016 09:58 PM
IROCZ1989
Jan 24, 2016 03:55 PM
BlackphantomZ28
LSX and LTX Parts
Oct 19, 2015 06:25 PM
GEmrsn
Interior Parts Wanted
Aug 8, 2015 03:15 PM
