Northern California Discussion board for Northern and Central California.
Catch of the day
Old Feb 2, 2009 | 06:27 PM
Darkshot's Avatar
Car: 91 RS
Engine: 350 TBI
Transmission: WC T5
Axle/Gears: 3.42 Posi
Catch of the day
L98 heads! $50. Also did an oil change. Had to mutilate my damn filter to get it off by sticking a screwdriver in the side and cranking it off. I swear I didn't over tighten it...not sure why that happens.
Old Feb 3, 2009 | 11:11 AM
fryer1979's Avatar
Car: '79 Camaro; '84 Z28
Engine: 350; none
Transmission: TH-350, 2500 stall; none
Axle/Gears: posi, 3.08; disc, 3.23
Re: Catch of the day
Nice score. I may have a bare set of those laying around somewhere, I ought to dig them out and check the casting numbers. On your oil filters, do you lubricate the rubber o-ring with oil before installing? Putting a thin coat of oil or wd-40 on that seal (just enough to make it wet) will usually keep that from happening.
Old Feb 3, 2009 | 03:09 PM
Darkshot's Avatar
Car: 91 RS
Engine: 350 TBI
Transmission: WC T5
Yeah, I do that every time.
Old Feb 3, 2009 | 07:41 PM
Jeremy_84_F41's Avatar
Car: 1991 Formula L98
Axle/Gears: 3.73:1
Wow, are they worth that much? I should sell mine.
Old Feb 3, 2009 | 08:59 PM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
Axle/Gears: Stock IRS
No Jeremy they are not, I gave mine away.
Old Feb 3, 2009 | 10:24 PM
fryer1979's Avatar
Engine: 350; none
And you still have them seize up? That's odd, how long between changes, and what type of filters do you use? Beyond cheap filters or going too long between changes, you got me.
Old Feb 3, 2009 | 10:37 PM
fryer1979's Avatar
Engine: 350; none
I'm pretty sure they carry a core value around $50 each. Sooner or later someone will always be willing to pay.
Old Feb 4, 2009 | 04:28 PM
Darkshot's Avatar
Car: 91 RS
Engine: 350 TBI
Transmission: WC T5
Where were you guys when I was making my posts about wanting cast iron L98 heads?!?
Old Feb 4, 2009 | 11:46 PM
Axle/Gears: 3.73:1
I don't know, but I've had a complete L98, that I will never use, for a long time. So.... you buy L98 heads for $50, then spend money freshening them up... and then you have heads that don't flow very well, and have an ancient chamber design. Why?
Old Feb 5, 2009 | 12:03 AM
Darkshot's Avatar
Car: 91 RS
Engine: 350 TBI
Transmission: WC T5
If you have a better alternative for me for the price, I'd love to hear it.
Old Feb 5, 2009 | 08:06 AM
Drinkmorebeer's Avatar
Car: 1989 Iroc Z T-Topin
Engine: 5.7L TPI
Axle/Gears: 9 bolt
you can always try walmart
Old Feb 8, 2009 | 03:29 PM
fryer1979's Avatar
Engine: 350; none
I don't think I was a member yet, or I just missed it. Sorry. Yes the port design is old, but with a little massaging on the ports from a good machine shop, a little valve work, and some descent parts, you ought to have a descent set of heads for less than $500. I know you can't get cheaper than that with aftermarket heads, and by then they ought to flow great.
RedLeader289
May 28, 2019 01:47 PM
bjpotter
Oct 4, 2015 07:48 PM
gord327
Oct 3, 2015 01:25 PM
Luigytico09
Oct 1, 2015 08:46 AM
