Northern California Discussion board for Northern and Central California.
most of an LT1, make reasonable offer.
Old Apr 5, 2009 | 10:27 PM
Slouch's Avatar
So like the title says, I have an LT1 that had two cracked heads = junk...
Its disassembled and I have decided to go for an LS1 swap so I need to make this go away.
Block looks good, have the intake manifold, injectors, crankshaft, rods, wire harness ect, pretty much the whole motor w/sensors except the heads.
I am open to offers but I would like to get $300 for it.
Old Apr 7, 2009 | 01:46 AM
Slouch's Avatar
Re: most of an LT1, make reasonable offer.
Open to offers?
No one need a roller block?
Complete Lt1 intake setup?
Old Apr 7, 2009 | 09:35 PM
Tpx's Avatar
Tpx
Car: 1982+1988 Z28 Camaros
Engine: 1982=350 carb 1988=383 Carb
Transmission: 1982=4 speed T-10 1988=6 speed T56
Axle/Gears: 1982=stock
I guess we're thinking if the heads were both cracked what else is wrong with the motor
Old Apr 7, 2009 | 09:50 PM
Slouch's Avatar
Well, there is nothing wrong with the intake...
The block checked out ok, the heads were cracked because its an LT1 and it had bad electrolysis (Which only affects the aluminum portion) and then cracked. All the cracks were around heavily pitted areas, was going to have them welded but then decided I would just pick up some AFR's my machinist welded them up and used them. Then I thought "You know, if Im going to spend 2K on a set of heads I might as well just get an LS motor" and so this thread was born...
I hope that clarifies everything?
Old Apr 20, 2009 | 01:29 AM
Slouch's Avatar
$200... Take it away (not shipping @ that price) I need the cash.
Its a good roller block with all the hardware and intake, I believe you can use the LT1 intake on a 350 tpi?
Old Apr 20, 2009 | 10:19 AM
Tpx's Avatar
Tpx
that sounds like a pretty low price. Almost makes it unreasonable not to buy it, where are you located
Old Apr 20, 2009 | 10:42 AM
Slouch's Avatar
I'm in Livermore, I would be willing to meet you within reason (Not driving more than an hour though)
Damn, I see you live in Arcata, I used to live there... Its about a 5-6 hour drive if your smashing.
Old Apr 20, 2009 | 07:22 PM
Tpx's Avatar
Tpx
Aw, well that's a shame. I don't have a truck up here only my camaro, and if you were a few hundred miles closer I'd be able to borrow a friends truck, but I'll have to let this one pass due to distance. Good luck with the sale though.
Old Apr 20, 2009 | 08:04 PM
Slouch's Avatar
I'll take some pics and post them up.
midge54
Dec 27, 2019 04:14 PM
fastrs1891
South Central Region
Oct 20, 2015 09:24 AM
TheExaminer
Aug 19, 2015 10:07 PM
sreZ28
Aug 14, 2015 07:48 PM
mcquigg
Aug 13, 2015 02:26 PM
