Northern California Discussion board for Northern and Central California.
And I weep
Old Jul 18, 2009 | 05:46 PM
Darkshot's Avatar
Car: 91 RS
Engine: 350 TBI
Transmission: WC T5
Axle/Gears: 3.42 Posi
And I weep
Rounded top passenger side bellhousing bolt
I think I'm gonna end up having to pull my motor. (Trying to remove limp **** 700R4)
Old Jul 18, 2009 | 05:50 PM
tony_cogliandro's Avatar
Car: 1990
Axle/Gears: stock
Re: And I weep
use an easy out.
and quit using a mexican speed wrench.
Old Jul 18, 2009 | 05:56 PM
Darkshot's Avatar
Car: 91 RS
Engine: 350 TBI
Transmission: WC T5
Re: And I weep
Originally Posted by tony_cogliandro
use an easy out.
Next please.
Old Jul 18, 2009 | 06:01 PM
Bullydawg's Avatar
Car: 88 Formula 350
Engine: 5.7
Axle/Gears: 9" 3.89
Re: And I weep
Keep trying to get it with the power tools. Eventually it will break free. Hammer on some sockets.
Maybe try a staring contest and see if it backs out...
Or try and use my favorite tool... Vice Grips!
I got lucky and didn't strip any of my bellhousing bolts, but I do know how much of a tight fit it is. I know I can see my top bellhousing bolts from my engine bay. maybe check it out.
Old Jul 19, 2009 | 09:19 PM
vindeezl's Avatar
Car: '92 Z03
Engine: LSX
Transmission: M12
Re: And I weep
What you should do is take a propane torch / map gas and heat up the head of the bolt and the surrounding area.
Then give it a few whacks with a hammer.
Then try to slam a smaller size socket on there (if it will fit, might have to file the head a tad) or as mentioned use vise grips, but get the vise grips on as tight as you can get them, then tap it with a hammer and it should pop.
84redta
Sep 19, 2015 09:58 AM
Hollow_kmh
May 12, 2013 11:15 AM
Carmello
Apr 3, 2007 06:18 AM
Durango_Boy
Oct 20, 2006 08:20 PM
Sonix
Jul 5, 2006 03:06 PM
