Northern California Discussion board for Northern and Central California.
Need a tune up
Old Dec 9, 2011 | 01:09 PM
Z28Smitty's Avatar
Car: 1992 Camaro Z28 Z03 Vert
Engine: 5.7L Vortec TPI
Axle/Gears: 3.23 Posi
Need a tune up
My Camaro is running a little sluggish and I think it's time for a good performance tune up. Anyone have recomendations for a good auto shop in the San Jose / South Bay area?
Old Dec 9, 2011 | 01:31 PM
88gta3508's Avatar
Car: 00 SSEi / 94 C4
Engine: 231 / 383
Transmission: 4T65E / ZF 6sp
Axle/Gears: 2.93 / Dana 44 3:45
Re: Need a tune up
Why do you need a shop... Your tune up.. will only be plugs, wires, cap, rotor, maybe a new coil
Old Dec 9, 2011 | 04:25 PM
Z28Smitty's Avatar
Re: Need a tune up
I've already replaced plugs, plug wires, coil and distributor and set the timing and it's still not running real strong. All the injectors were replaced 2 years ago so they shouldn't be the problem. It passes smog with flying colors and it only has 75K but it's just doesn't have the punch it used to. I think I need to get it scoped to find out what's going on. It revs strong but sometime sputters and has slight backfire as I back off the gas. Any ideas?
Old Dec 9, 2011 | 05:55 PM
88gta3508's Avatar
Engine: 231 / 383
Re: Need a tune up
quick lesson when making a post you state need a tuneup... Correct
now you state you already did this... it's your car.. not one person here or any site knows what you did with your car...
you now state your really having issues....
this is where you should have started your post
so clue in the board what is really going on
you should check you fuel pressure with a gauge
Old Dec 9, 2011 | 07:32 PM
vindeezl's Avatar
Car: '92 Z03
Engine: LSX
Transmission: M12
Re: Need a tune up
Originally Posted by Z28Smitty
Any ideas?
Engine is toast sell me the car for salvage price
Old Dec 9, 2011 | 08:49 PM
Copchaser's Avatar
Car: 86 Trans am, 91 Camaro RS
Engine: 355 Sbc, nothin yet
Transmission: 700r4- both
Re: Need a tune up
Vin is so cynical... Hella funny tho
Old Dec 9, 2011 | 09:53 PM
Z28Smitty's Avatar
Re: Need a tune up
Your right. I should have been more specific in my initial post. I was looking for a recomendation for a good shop in the south bay so I could have it checked out.
If I was looking for help diagnosing the problem I would have listed what I've done so far to try to correct the problem. The car runs fine and just doesn't have the performance it used to. I did check the fuel rail pressure and it was within specification.
Still looking for a recommend a good shop in te San Jose area.
Old Dec 9, 2011 | 09:58 PM
Z28Smitty's Avatar
Re: Need a tune up
LOL. I can't see ever parting with my vert.
If the engine is blown I'll be looking for a 5.7 to drop in.
Old Dec 10, 2011 | 12:05 AM
vindeezl's Avatar
Car: '92 Z03
Engine: LSX
Transmission: M12
Re: Need a tune up
Cynicism or realism?
Smart man
I wish my 25th looked as clean!
Old Jan 13, 2012 | 03:35 PM
norcalz28's Avatar
Car: 1989 Camaro IROC-Z
Engine: ZZZ# 0607 of 1200 produced
Transmission: Pro-Built 700R4/Vig.2400
Axle/Gears: 3.27 BW 9 Bolt PBR Disc
Re: Need a tune up
Smitty, try adusting the TPS back to factory setting and also re-adjust for min air at the IAC. These things often go overlooked, but I have done this on a couple cars and noticed a difference right away. Also some other stuff we could try.
Will
Zell1luk
Sep 29, 2015 10:36 AM
