Happy NewYear!!!
Car: 88 IrocZ Vert
Engine: 5.0 TPI
Happy NewYear!!!
What kind of plans do you have for 08??
I leaning towards a Stealth Ram for my 88 Vert..
Re: Happy NewYear!!!
Oh, I'm going crazy this year since I'm actually employed.
By easter(about april 1st) my goals -
4L60E with 3600 RPM stall converter install but just got that about 90% done yesterday(programming and drain-plugged pan left to do), get some 17x11 rims in the rear, 315 tires in the rear, install C5 front brakes, get some aftermarket front seats. Get the rims and a few other things powered coated a "special" color.
Engine: LS1/LQ4
Transmission: 4L60E/4L80E
Camaro #1: 3.42 gears, 28 spline axles, aluminum support cover, aluminum driveshaft.
Camaro #2: LS1/T56 swap.
'57: Replace flexplate (mount bolts to crank came loose last season), get valvetrain geometry correct (pushrod length), get MSD Digital 6 repaired and reinstalled, possibly weight reduction.
Pinks All Out is coming to town in August, they've stated a minimum of 12.99 required (remember, this is 5800' elevation - that's about a 12 flat at sea level).
Probably going to have to get my left knee scoped soon. I figure the clutch pedal will be good therapy for it.
tyeo098
11-30-2015 06:27 PM
buckeyecelt
09-24-2015 05:50 AM
UMI Performance
Sponsored Vendors
09-04-2015 09:22 AM
