The first of my two major projects for the T/A
Car: 1997 Corvette
Axle/Gears: 2.73 IRS
Blew the stock 2.73 gears in my car a week and a half ago (after going to the track 2 weeks ago). After looking and looking, I finally found and picked up a 3.23 rear end out of an LS1 car ('98 Trans Am convertible) with 54k miles.
Anyways, its got all the brake parts, and some rusted 12" rotors, so I'm going to buy some new $14 rotors at Autozone.
While I'm going to have the rear-end off my car, Tim recommended that I put a new fuel pump in, and sure enough, the day after he said that, I found a deal on another forum for a couple Walbro 255lph fuel pumps, so I grabbed those. Also decided I should get an adj. prop. valve...so I did.
Oh, and I bought some new GR-2s and Gas-A-Justs the other day as well..just waiting for them to come in.
Now, I'm waiting for my fuel pump and adj. prop. valve to come in before I can swap the rear ends and everything, but its going to be sweet once I get the new stuff in.
3.23s vs 2.73s, adjustable 12" disc brakes vs. drum brakes, new fuel pump, Gas-A-Justs vs. stock 80k mile originals, etc. Its going to be a whole new car!
At the same time, I'll also be putting on new drilled/slotted rotors up front, carbon metallic pads (might return them for ceramic though), and new calipers. Might as well put the GR-2s in then as well, along with the wonderbar that should be coming in soon also.
All of these fun parts, and hopefully if everything comes in this week, it'll be driveable in 5 days or so! I've been dying without my T/A for the last week and a half so far. More info on the other project tomorrow
Moderator/TGO Supporter
Car: 1997 Z28
Hey dean, wish i was going to be around to help you out. You are making the right choice changing the pump since you all most have it out anyways. The only trick you need to knowis this: Get that rear high, the higher the better. Give yourself plenty of room to get that tank out of there. It will make you life much easier.
Keep me posted, when you working the pool again?
Car: 91 RS
Engine: 350tpi comming soon!
Transmission: fixed the 700r4 again!
I would recommend the pump swap as well. Tim helped me do mine and once the rear end is out of the way its not that bad. Gettign the tank out isnt that bad really. I have 323 gears , youll like the differance. Good luck
Car: 1989 TransAm GTA
Engine: One sweet modified 355 TPI.
Transmission: The kind that shifts....
Dean, if you can swing it, you might as well pick up some Energy Suspension sway bar endlinks. Damn they make SUCH a difference over stock ones.
Course, most of us have rotted bushings out back so new ones are a huge difference.
I've got the KYB GR-2s up front, and Gas-a-just shocks out back and I'm really happy with the ride. Very nice shocks for the money.
Car: 1997 Corvette
Originally posted by MillerTime21
Hey did you buy the rear end from a guy near east moline?
Car: 1997 Corvette
My GR-2s and Gas-A-Justs just arrived today and look a little more banged up than they did in the photos, but at least I can tell they are very new.
Car: 1997 Corvette
Should I stay with carbon metallic, or should I do an even exchange for ceramic pads? I'm not a big fan of brake dust, but is there any disadvantages to the ceramic pads? I bought the carbon metallic pads because I didn't know they had ceramic ones available as well. I'd like to avoid buying brakes online because I don't want to wait for any more parts to come in.
Also, I may be buying some LCA re-location brackets as well to weld on before we put the rear on.
Car: 85z28,
Sounds like u are oing to be haveing more fun than me. Don't u just love it when u say I'm goig to this to my car well since i'm doing that i should do this to and so on and so and so on. Heck all i was going to fix on my car was 1 dent lol. I wish i was not working on my car i have to start coming around u guys when u are to mech. work so I can learn that end of cars.
Car: 94 25th TA
Engine: 355LT1
Axle/Gears: 10bolt 3.42
I went to buy that rear end from him and when i got there it was all ready to go but it still had the the brakes and everything on there and i didnt need them so insted of just pulling them off he just gave me a rear end out of a 99 camaro SS with a 3.42 gear and only 30,000 miles on the rear end for the same price. that really made my day and everything worked great
LT1Formula
10-08-2015 08:34 PM
sjorgens
10-01-2015 07:54 PM
