Any carb gurus gonna be at the meet??
Car: 2002 Formula Firebird
Transmission: 4l60e
I need a carb tuned in a bad way. Any expert carb guys gonna be there to help a youngster out?
Transmission: 4l60e
Im thinking about grabbing one. I also have a holley jet kit with #64-#99.
Factory were 65 primaries and 68 secondaries. Went down 1 step (as far as possible) on the primaries and 66s on secondaries..didnt help much. I also lowered my fuel pressure with no luck.
I figure someone will be able to help.
Car: Camaro Vert
Engine: 355 HSR
Transmission: A4
Axle/Gears: 3.73 S60
Well with the vac gauge you can ajust the idle screws to lean it out a bit and playing arround with the float level will help that out a bit
BTW have any back fires recently with it?
Kat
Kat
Transmission: 4l60e
I dont recall ever having a backfire with this carb. Except it dieseled a couple times bcause the idle was sky high. I dont think it has ever been backfired so the power valve in theory should be ok. Maybe I should go ahead and try another one and see what happens.
Car: 79 Camaro RS
Engine: 355, carb, alum heads, XE262
Transmission: TH350
I'm sure I'll get punched later on for telling people this.....BUT there is going to be this guy there with a black LT4 powered 86' Z that knows his way around carbs
His name is Jim, he posts on some boards as JimW! I dont think he posts here though!
His name is Jim, he posts on some boards as JimW! I dont think he posts here though! Thread Starter
Transmission: 4l60e
I work at advance auto parts. We have one but its big...runs about 30$. It does more than just read vaccum tho.
If someone at the meet can make my car run strong and stop running so rich Id give them like 20$ or something. Im tired of fouling plugs and running so rich that you can see black smoke at idle even.
Its funny because it still does miss or hesitate lol. Must be a chevy thing.
Transmission: 4l60e
sweet ill bum yours off you Mark. I never picked one up. Ill see you tomorrow at the fairgrounds I guess.
