How much HP/TQ for a solid mid 13 secnod run with traction?
Car: 86 firebird with 98 firebird interi
Engine: pump gas 427sbc Dart Lil M 13.5:1
Transmission: Oldani TH400 w/ BTE 9" convertor
Axle/Gears: 31 spline Moser/full spool/4.11Rich
I got a 355 w/ 350hp and only doing 13.61 best to date. 3500 stall, TH350 trans, 3.42 gear 9that's what'a killing me) and 26x9.5 Hoosiers
My dad had 212/276 at the wheels and went 13.67 with traction. Since then he has added headers, and an H-pipe and runs 13.31-13.4 all the time! Oh ya this is in a 1991 Mustang, but with the right suspension, an F-body could do it too!
Car: 1984 LG4 Camaro
Engine: 350 Roller Motor
Transmission: Level 10 700R4
Axle/Gears: Strange 12 bolt 3.42
It depends on the weight and traction more or less. If you have a 280hp motor in a 3400lb car, it'll run in the 13's. If the car weighs 3800lbs and has the same power, no.
What are you going to NJIT for? I graduated (twice) from there...
Car: 1992 Z28
Engine: Stock L98 with bolt ons.
Transmission: Stock rebuilt tranny with 2k stall and cooler.
I have no clue as to how much HP it takes to turn mid 13s but its not as high as some of the estimates so far, thats IF you have good 60fts. I havent dynoed my car, it does weigh 3688lbs with driver and ran 13.521 but it did it with bolt ons, stock L98, 2k stall and 1.76 60fts. If I ever get things in order here Id like to see what its putting down at the wheels but Id bet its not impressive except for maybe decent torque figures. If I ever get the car dynoed Ill be sure to post my results...
Car: 1990 Trans Am GTA
Engine: 5.7 TPI 350 sd
Transmission: A4
I´m hopping for high 13´s with my setup!!!!! GTA-90 350tpi map
headers +catback, AFPR, ported plenum, chip, k&n.
Or is this wishful thinking?
:lala:
:lala:
Anything's possible, but the track don't lie, alot of people, myself included, get seriously let down when they get their first timeslip after some mods. I only have factory suspension so I'm losing out on some better short times and that would help, I race my car with a full tank of fuel and I scaled it the other day in racing form and it came in at 3440. The climate of the day will also make a difference, so keep that in mind. This fall weather is near perfect cause the air is cool, humidity is usually low, and if the sun is out, the track is warm for good traction.
mdtoren
Aug 16, 2015 05:45 PM
Street Lethal
Aug 13, 2015 08:28 PM
