new motor setup ..what will it run??
Car: 92 z28
Engine: carb'd small block
Transmission: th400
Axle/Gears: 10+2 bolt
well i got a new motor setup its a 406 with holley750dp, performer rpm intake, dart iron eagle heads, 1.6 roller rockers, crane cam with .520 lift, heddman longtubes, turbo 400 w/ 3200 non lockup converter, 3:73 gear auburn pro diff....
any suggestions on what it will run??
Car: 87 Vette 85 TA 82 Z/28
Engine: 3 - 350's 388 400
Transmission: 2-700R4's 1 T56 Setup!
Axle/Gears: 2.59's 3.42's 3.73's
whats the intake valve size?
hope you get a handle on the overheating problem cause you probably will have one.
my guess so far mid to high 12's
Car: 1992 B4C 1LE
the iron eagles are like 2.02, 2.05, and 2.08 the real question is what size iron eagles?
Car: 1986 Iroc
Engine: 454 Demon 850DP
Transmission: TH350, 3500 stall
What overheating problem?? There are lots of 400's on this board that have no trouble with heat. Drill the steam holes in the heads that is all you need to do.
Car: 1992 B4C 1LE
Im going to run a 412 (.060" over) and I wont have a cooling problem. I dont understand how people have cooling problems on a third gen. one of my old cars had a 412 in it, I had aftermarket induction so I didnt have the ECM to run the fans so I wired them on all the time and the thermostat was a 160 and the car ran so cold (like 150) even in the summer that I had to put a 180 stat in it.
Re: new motor setup ..what will it run??
Car: Bright Red 91 GTA
Engine: CARBED LT4
Transmission: MK6
if u can get it goin without smokin away the rubber then i think youll have a low 12 in the bag...probly an 11...
my buddy had a 86 z with a 406, stock ported 400 heads and a mild cam runnin low 12's
Car: 1989 Iroc Z L98
How can you guys even attempt to guess how his setup is gonna run if:
A. We know absolutely nothing about the cam that he is running except for the lift.
B. We know nothing about the compression.
C. We don't know how much his car weighs.
With 10:1 compression, a cam with at least 240/240* @ .050 on a tighter lobe separation of around 108-110* and a 3400 pound car with driver, I think 11's are definately possible on slicks.
However, with 8:1 compression, a cam with a 116* LSA and 212/222*@.050 in a car that weighs 3800 pounds with driver it could run 15's or 16's
. Thread Starter
Car: 92 z28
Transmission: th400
well compression is 10.5:1....the only thing car has deleted is heating and air conditioning stuff and no back seat....want to take more weight out but what else could i take out???
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Keep the carpet but remove all the underlay. Pull the front seats and install race buckets. 2 seats could remove close to 100 pounds. Remove the crash bumpers from behind the front and rear plastic covers. Manual steering box.
There's lots more ways to remove weight but there comes a point as to how much you want to remove and still keep it streetable. Look at it this way. If it isn't needed to go fast, remove it.
Seth
Street Lethal
Aug 13, 2015 08:28 PM
