Organized Drag Racing and Autocross Drag racing and autocross discussions and questions. Techniques, tips, suggestions, and "what will I run?" questions.
How much should it improve
Old Jul 31, 2003 | 10:27 PM
Camaro305to350's Avatar
Here is my slip
R/T ... 1.499
60 ... 1.981
330 ... 5.606
1/8 ... 8.713
MPH ... 79.14
1000 ... 11.388
1/4 ... 13.672
MPH ... 95.56
This was my first pass ever. It was one hell of an experience to say the least. My friend, who has been doing it for awhile, thinks I hit the brake to early cause of my 1/4 time and MPH (the guy ran against ran a 14.5 at 96.45). This was my only pass of the night, because of some issue with my hood.
I've stalled the car up to 2200 RPM on the street before, this pass I didn't stall or **** it myself. So here is my question, if I had of stalled it and shifted it myself (it shifts at 5200 RPM I would of let it breath till 5800-6000) what kind of times should I put down.
Just some specs from the car, its a 383 stroker, it has Edelbrock performer RPM aluminum heads on it. It sports an Edelbrock performer RPM intake, and a 670 demon DP carb. I'm not sure about the rear gear (I know it was a 5 speed 305HO car 84 camaro), but it doesn't spin the tires, tires are Mickey Thompson 10.5 street slicks.
It has shorty headers, to a straight pipe, and end out in a 3 chamber flowmaster. Its a TH350 transmission with shift kit. Its a 14x10 K&N open element set up. Everything has been gutted, no air or blower motor, only battery and engine underhood, oh and overflow. The car has traction bars and I thknk thats about it. Any kind of help would be appreciated.
Old Jul 31, 2003 | 11:01 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
You say you hit the brakes at the end. From calculations based on your 1/8 mile and 1000 foot time, you should be closer to 13.5's.
The reaction time sucks but it was your first time and everyone gets nervous. Next time concentrate on the last yellow light. When you see it come on, Go! If you wait for the green, you're going to be too slow.
The mph is an indication of the amount of HP the engine is producing however depending on gearing and tire size, you can't use it to compare 2 different cars. When I still used a 383 SBC I was running 12.0's. A typical car set up properly would run 12.0 at around 108 mph. I was doing it at 117 mph.
1984 305HO with manual transmission came with 3.73 gears.
Old Aug 1, 2003 | 02:52 PM
SLP IROC-Z's Avatar
Car: 1999 Z28
Axle/Gears: 3.23 10 Bolt
looks like ur slowin down at the end notice how the 79mph 1/8th and then a 95 1/4, it should almost be 100mph at the end of the track. play with ur timing or afpr a bit.
Old Aug 1, 2003 | 08:36 PM
EvilCartman's Avatar
Car: '82 Z28
He said he hit the brakes
Old Aug 1, 2003 | 11:36 PM
SLP IROC-Z's Avatar
Car: 1999 Z28
no he said his friend thought that he hit the brakes early, he didnt say that he did. assuming that he posted an accurate description for us, i gave him an accurate reply. i trust him to have known if he had hit the brakes or not, hes yet to state that he has.
Old Aug 2, 2003 | 12:09 AM
To be quite honest, I did hit the brakes, but Im not sure if it was before or after I crossed. I wasn't sure, I know I hit the brakes and then started back up thinking it wasn't over yet. So I cant honestly say yes or no to that one.
Old Aug 2, 2003 | 12:17 AM
SLP IROC-Z's Avatar
Car: 1999 Z28
then id say ya did hit em then, judgin by the good 1/8th et and mph. helps to give all the facts
Old Aug 2, 2003 | 09:26 AM
Nic's Avatar
Nic
Car: 1993 Ford Mustang
Engine: 5.0L
Judging by the ET and mph, I'd say you did hit the brakes, but very late. You might have another tenth or so in it as is.
F-body-fan
Jan 12, 2023 01:49 PM
LiquidBlue
Wheels and Tires
32
Dec 10, 2019 04:06 PM
J-money
Jan 4, 2019 09:45 AM
86White_T/A305
Mar 6, 2016 01:48 PM
wanext
Oct 6, 2015 12:18 AM
