Organized Drag Racing and Autocross Drag racing and autocross discussions and questions. Techniques, tips, suggestions, and "what will I run?" questions.
1.7 on 18's
Old Oct 27, 2003 | 11:12 PM
Kandied91z's Avatar
1.7 on 18's
tried out the new bfg 18" dr's and well i was able to run a consistent amount of 1.7 60's over the weekend. not bad at all for a 18" tire, cold weather and a worn out rear. whom ever said you can't look good and go fast just doesn't know.
Old Oct 28, 2003 | 12:20 AM
brodyscamaro's Avatar
Car: 1999 Yamaha Banshee
Transmission: 6 spd manual
Axle/Gears: 14/41 tooth
what were the 1320' times and speed
nice 60'...
Old Oct 28, 2003 | 08:02 AM
MdFormula350's Avatar
that a pretty nice 60 foot, i am consistent high 1.9s; take that
Old Oct 28, 2003 | 04:29 PM
Kandied91z's Avatar
there was a vette running much lower then that on the same brand but a little wider. better rear and a tad more power.
definately need a rear but i was happy with it. had a bit lower but it wasn't consistent. we pretty much only ran 1/8's that day.
Old Oct 28, 2003 | 08:07 PM
DannyT's Avatar
Car: 89 Iroc
Engine: 383
Axle/Gears: 3.45
Are you running the G Force DRs? I'm kicking myself because I bought the Comp T/A DRs for my stock wheels because they didn't have the right size for my 18s. Nitto only has a 305/40-18
Now I findout that the G Force comes in 245/40, 265/40, 275/35 and 295/35-18.
I have the stock stall so the best 60ft I could pull was a 1.86
If I can equal that with 18" DRs and look better then I'll go with those instead
Old Oct 28, 2003 | 08:32 PM
25THRSS's Avatar
so what were your times?
Old Oct 28, 2003 | 09:11 PM
DannyT's Avatar
Car: 89 Iroc
Engine: 383
Axle/Gears: 3.45
And are you running the stock stall converter?
Old Oct 29, 2003 | 01:58 AM
BORLAZ06's Avatar
ETs please.
and trap
Old Oct 29, 2003 | 11:14 AM
Kandied91z's Avatar
they were only running 1/8's that day....
i was taking it pretty easy not to break anything pulled an average of 8.23 @ 84 granny shifting and not double clutching like i should.
Old Oct 29, 2003 | 04:39 PM
zupmanZ28's Avatar
Car: 86' Z28
Engine: 355
LOL... i live my life a 1/4 mile at a time...and i'm a dumbass
Old Oct 29, 2003 | 05:07 PM
fast86z28's Avatar
Car: 91 Z28
Engine: LB9
Transmission: WC T5
why would you wanna double clutch? you need to powershift that ****.
Old Oct 29, 2003 | 05:27 PM
Kandied91z's Avatar
so true.....so true........
Old Oct 29, 2003 | 08:09 PM
25THRSS's Avatar
That's prolly a high 12. I ran 8.5 at 85 mph in the 1/8 with a 2.1 60. That turned out to net me a 13.2 at 106 mph in the 1/4, so with your much better 60, but less mph, you should be about high 12's.
Old Oct 29, 2003 | 09:05 PM
Kandied91z's Avatar
actually the two passes i made at 1/4 were low 12's. the car has incredible top end. thanks for the guess though.
Old Oct 29, 2003 | 09:07 PM
25THRSS's Avatar
quit the bull**** and just post your #'s. What were your trap speeds on both runs?
Old Oct 29, 2003 | 09:17 PM
DannyT's Avatar
Car: 89 Iroc
Engine: 383
Axle/Gears: 3.45
Yeah I don't see low 12s out of an 8.2 1/8 @ 84MPH with a 1.7 60ft either
My best 1/8 runs are 8.169 @ 85.1 MPH (1.89 60ft) & 8.179 @ 85.3 MPH (1.86 60ft). They both yielded 12.70 in the 1/4 @ 109 MPH. This is with the stock stall converter and I have more top end than you I'm pretty sure
Either way I just want to know what size DRs you are running
Old Oct 29, 2003 | 09:19 PM
25THRSS's Avatar
I think he turned on the nitrous and isn't telling.
Old Oct 29, 2003 | 09:22 PM
DannyT's Avatar
Car: 89 Iroc
Engine: 383
Axle/Gears: 3.45
You're probably right.
Old Oct 30, 2003 | 01:11 PM
Kandied91z's Avatar
you guys are funny...........
i told you some of the times you can figure it out for yourself and the car doesn't have nitrous people. this post is on the 60 and they were 18 295/35/18's.
Old Nov 11, 2003 | 11:42 AM
SLP IROC-Z's Avatar
Car: 1999 Z28
Axle/Gears: 3.23 10 Bolt
Old Nov 11, 2003 | 12:21 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
It's still only a short 26" tall tire with very little sidewall..
Old Nov 11, 2003 | 03:24 PM
Kandied91z's Avatar
with y rated toyo proxies in the same size the best 60' was a 2.7 with the norm being a flat 3 so to drop that much is a pretty good indication that they work, wich is the point of the thread for anyone interested in knowing how they work....
spills
Apr 29, 2005 08:32 AM
mikeage2
Mar 25, 2005 01:49 PM
ME Leigh
Jun 25, 2003 11:05 PM
