dart iron egale heads
Car: 92 z28
Engine: carb'd small block
Transmission: th400
Axle/Gears: 10+2 bolt
im running those heads....
200cc runners
64cc chamber
202/160 valves
and i ran a 12.50 running a 406 with a small hydraulic cam and a performer rpm intake... i reall havent used them to full potential yet so when i change the cam and intake ill let u know...i was told by many ppl they are really good heads for the money....
200cc runners
64cc chamber
202/160 valves
cool what plug are you running, and heat range,im running 215 cc dart heads with rpm intake and comp extrem 274 230 236 @.50 and 488 490 lift,1.6 roller rockers,the motor is a 355ci with holley 650 dp,best et in the 1/8 is 8.2 at 90,i was hoping for a better time,get back with me on those plugs thanks
Car: 92 z28
Transmission: th400
just a regular temp plug ngk 6s i think??
my cam has a .515 lift 300* of duration.. with 1.6 rockers and a holley 750 dp...
my 1/8 mile was 8.0@86... so u get an idea where u are at....
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
chad.....why are you running such huge heads on a 355(small motor) with such a small cam??? that combo can't possibly run as well as it's potential. I'm running a similar cam in my 305....because I needed a big cam for it. Now i'm not running huge heads and it works for what i'm doing
you need to up the cam, or do something to help it out there. plus a bigger carb would probably help you out on the track as well.
my .02
my .02
Car: 1984 Z28
do you think that going with the larger 215 CC compared to 200cc is costing you HP at all?
Car: camaro sportcoupe
Engine: 7.0L
Transmission: G-Force GF5R
Axle/Gears: Moser 9"
your losing alot of low end torque that the cam and intake want to produce by using that big of a runner head. we are running the 200cc heads with a holley street dominator intake, a 525" lift solid cam, we should be running 11's this year. haven't gotten the motor totally back together yet...
Car: 1992 RS Camaro bracket car
Transmission: TH-350
I am running stock 305 heads (mild porting) with a 750 VS, Torker 2 and Summit 234 duration/.488 lift cam w/1.6 roller rockers on a 305. We have currently run a best of 8.11 @ 85.75 in 1/8th mile.
To improve, we are going to try a 230 duration/.465 lift cam from Crane w/performer RPM air-gap manifold.
Our best 60' time is 1.84. With current set up, it does not appear that there is enough low end to improve 60' time. We have no traction issues, car now hooks well. We had the choice of changing converter to raise stall speed or look for more low end. Since we will be installing a 350 or 383 we elected to try and improve initial torque.
What are your 60' times?
Engine: 7.0L
fix your traction problems, then come talk to us...
get a set of the new M/T Drag Radials and some good suspension(like spohn). the new tires will be released in April...
Car: 87 IROC (low 12's)
Engine: 400 sbc .040 over
Transmission: 700r mod
Originally posted by chad89ta
the cam is good for 1500 to 6000 rpm,intake 1500 to 6000 and the heads are good to 7000
cam total lift to the max flow of the heads for peak performance.
on the other hand most street cars spend very little time in the max flow area.Mid flow since the valves cross this point twice(rising and return) I think has the most influence as far as drivability and useable hp and torque..
Car: 1984 Z28
i'd go bigger cam to help you out....i like the .525 lift suggestion from mw66nova, although you could go bigger with that 1.6 ratio.
Car: 1984 Z28
get some traction and that cam.....i think you'll be much much happier. I know i would be.
Engine: 7.0L
well, i have heard nothing but great things about these heads from all of the hardcore engine builders that i have talked to. if your not making lots of power, then you have something miss-matched. before you go and do another head swap, put in a cam that is suited for the heads. what gears/stall are you running? with those heads i would suggest at least a 3500 stall converter and a 3.73 gear. (assuming you have a 700r4) call comp cams and ask about a custom cam for your combo. spend the money on the phone, then spend your money on your combo once.
Car: 84 Z28 Camaro
Engine: 350ci
90 mph in the 1/8 is really good, I would put more money in the
traction area first. Improve your 60 ft targeting about a 1.8 and
then make a decision after that.
Car: 1989 C4
Axle/Gears: 307
Actually I'm running those heads on my firebird. I'm using a Melling O.E. LT1 grind from 70+ corvettes. 13.03 @ 102.40 with a 1.88 60ft. Not bad for a action+ manifold with a 600 CFM vs holley.
ambainb
Apr 25, 2016 09:21 PM
C409
Sep 23, 2015 04:30 PM
