Organized Drag Racing and Autocross Drag racing and autocross discussions and questions. Techniques, tips, suggestions, and "what will I run?" questions.
How to drive better?
Old Feb 13, 2004 | 11:28 PM
stupid4901's Avatar
This may be a stupid question but I'm kind of confused as to what would make a driver better or worse when dragging. Is there a special method to floor the gas and go?
Old Feb 14, 2004 | 12:01 AM
FbodTrek's Avatar
Car: 86 Berlinetta 84 MonteCL
Engine: 3.4 MPFI 3.8 229
Transmission: 700r4 T350
Ummmm............
That's NOT how you race..... Roll into the accelerator or spin tires to pattern baldness. If it's an auto, torque brake till the converter locks up and roll into it. If it's a stickshift, you can either drive or you can't...Learning how to launch without spinning while putting the right amount of power to the ground is one of the key factors to winning a race or "OUTDRIVING" someone.
Old Feb 14, 2004 | 01:25 AM
ChrisFormula355's Avatar
Car: Junk
Engine: Junk with nitrous
Transmission: Junk with gears
well, no offense now...but with a car running 15.6 at 86mph, there really isn't any way for the driver to be far superior to another driver unless you have REALLY REALLY dry rotted tires and a peg leg. Just put it in drive and floor the beatch, make sure its shifting at the right points.
Old Feb 14, 2004 | 02:07 AM
ksrammstein's Avatar
Car: 1984 Pontiac Trans Am WS6
Engine: H.O. 305 5.0L;L69
Transmission: T-5; Axle Ratio 3.73
Very true....however when you got 400+HP it can get real tough to do it well....
Old Feb 14, 2004 | 10:27 AM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
For the slower cars a better driver doesn't mean much once the car is actually moving. The better driver part comes in when you're bracket racing since you need to understand your car. You need to get a good reaction time and be able to know how fast the car will run without breaking out. There's no skill in just mashing the gas to the floor and driving to the end of the 1/4 mile. If you're in a competition you need to be aware of where your opponent is by the time you get to the end. You need to cross the finish line first but without going faster than you dialed in at. That's where the skill is involved.
Old Feb 14, 2004 | 10:59 AM
RebelTillDeath3's Avatar
Car: 92 Camaro
There's lots of driver skill that affects a drag race:
-Reaction time, plain and simple, you will win or lose at the tree
-Ability to keep it straight and in the groove
-Ability to control tire spin
But most of all, reaction time really is the key to winning a race.
Old Feb 18, 2004 | 10:39 PM
stupid4901's Avatar
Thanx for the replies it helps to clear things up. I have the reaction thing covered, and keeping it straight is never a problem (yet(, but how to get the tire to not spin. It just spins a little but that little bit could be a tenth or so.
Old Feb 18, 2004 | 10:41 PM
25thmustang's Avatar
Car: Mustang
Engine: Bolt Ons
Transmission: Stock
Autos are really easy to be a great driver... with traction just floor it...
With a stick good and bad drivers are EASY to spot. If you dont launch hard and power shift, there are tons of improvements to be made!
No remorse, drive the car!
Vintageracer
Jan 10, 2020 05:33 PM
gta90
Sep 15, 2015 04:00 PM
86IROC112
Aug 21, 2015 12:39 PM
IroczFan
Carburetors
Aug 18, 2015 05:19 AM
