Organized Drag Racing and Autocross Drag racing and autocross discussions and questions. Techniques, tips, suggestions, and "what will I run?" questions.
Is this a high 14s car?
Old Feb 23, 2004 | 07:38 PM
pre's Avatar
pre
Car: 87 Firebird
Engine: 305 LG4
Transmission: THM700R4
I was wondering with the following mods that I'm going to do this summer to my already moded car if it can break into the 14s for the 1/4?
Mods will be Spohn sub frames, Edelbrock Strut Tower,LCA Relocation, MSD 6A box and Blaster 2 coil, new plug wires, 3.42 gears, 2000RPM torque convertor, lockup convertor, tires.
I know alot of these time questions are asked but I was looking for some input besides my own biased one.
Old Feb 23, 2004 | 07:51 PM
92camaro's Avatar
I hope so. If not sale it
Old Feb 23, 2004 | 10:45 PM
MdFormula350's Avatar
those mods should help with the 60 foot some which will help lower ur et.
Old Feb 23, 2004 | 11:03 PM
DauntlessZ28's Avatar
Car: 1984 Z-28
Engine: L69
Transmission: 700-R4
Good point.
What times did you pull before the mods?
Old Feb 24, 2004 | 08:15 PM
pre's Avatar
pre
Car: 87 Firebird
Engine: 305 LG4
Never ran it but I got the dyno results in my sig if that helps.
Once it clears up I'll get it weighed and probably run it this summer.
Old Feb 24, 2004 | 10:23 PM
Car: 1984 Z-28
Engine: L69
i'd almost be inclined to say that with the mods in the sig, you'd probably be at low 15s. with the new mods you're planning on, you'd probably get into the 14s. maybe mid-high 14s? after a few practice runs with the new torque converter, you'd probably get it into the mid 14s. only one way to find out for sure --->
Old Feb 24, 2004 | 11:06 PM
pre's Avatar
pre
Car: 87 Firebird
Engine: 305 LG4
Those seem like the numbers I was thinking I just got to start to practice my shifting and starting.
Old Mar 2, 2004 | 07:49 PM
TPI-Formula350-'s Avatar
Car: 89 Formula 350
Engine: Forged 385 H/C/I
Transmission: 700R4-4300 Stall-lockup
Axle/Gears: BW 9 Bolt 3:70
i'm thinking your more likly going to be running low 16's in it current form . I'd like to tell you you'll get into the 15 but i dont see it with an LG4 and your mods...
Old Mar 2, 2004 | 10:09 PM
Car: 1984 Z-28
Engine: L69
With all my sig info I ran a best of 15.4. But I'm also running at 519ft
Old Mar 3, 2004 | 03:52 AM
ChrisFormula355's Avatar
Car: Junk
Engine: Junk with nitrous
Transmission: Junk with gears
Re: Is this a high 14s car?
alright, I hate to be the one to break it to you.....but a strut tower brace, msd box, coil, plug wires, and sub frames dont' do ANYTHING for your 1/4 mile times. I'd guess mid 16's since you are basically stock.
Old Mar 3, 2004 | 11:26 AM
unknown_host's Avatar
Car: 1989 Iroc Z L98
Go with a steeper rear gear and some more converter.
Old Mar 3, 2004 | 01:01 PM
Jgolden314's Avatar
Car: 1999 Z28
Transmission: A4
i am going to say mid 15s. I ran 16.5@84 with only advanced timing..........nothing else. i have peg leg and 3.23's, and i barely spun off of the line. So I am sure you will be faster than I was.
goodluck and report back
Old Mar 3, 2004 | 01:09 PM
mw66nova's Avatar
Car: camaro sportcoupe
Engine: 7.0L
Transmission: G-Force GF5R
Axle/Gears: Moser 9"
he's not basically stock guys, read his sig. however, we need to know the specs on that cam and what heads you have, ect....probably high 14/low15...what elevation are you at as well...?
Old Mar 4, 2004 | 11:20 PM
pre's Avatar
pre
Car: 87 Firebird
Engine: 305 LG4
From what I got from a map the elevation would be around 800ft.
I never got the cam number when it got installed this summer(I will find out soon), but I think it is either a
Magnum 260 specs 260 ad intake 260 ad exhaust - @.05 206 intake 206 exhaust .500 lift 110 lobe
Extreme Energy 258 specs 258ad intake 264ad exhaust - @.05 206 intake 212 exhaust .480 lift intake .487 lift exhaust 110 lobe
The stock I believe is .350 intake lift .384 exhaust lift 179 intake dur. 194 exhaust dur. 109 lobe
The heads are stock and nothing has been done to them
Old Mar 5, 2004 | 10:55 PM
Hawk92z-TDZ's Avatar
Car: 92Z28, 99SS, 83Z28 & 86GTA
Engine: 421, LS1, 327Turbo & 383
Transmission: T-56, 4L60E, T5 & 4L60
Axle/Gears: 4:10, 3:42, 2:73 & 3:27
mid 15's if your lucky
customblackbird
Aug 15, 2021 10:16 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
Exxon Limited
Camaros Wanted
22
Dec 21, 2015 10:36 PM
Linson
Aug 21, 2015 02:12 PM
IROCThe5.7L
Aug 10, 2015 11:24 AM
