Organized Drag Racing and Autocross Drag racing and autocross discussions and questions. Techniques, tips, suggestions, and "what will I run?" questions.
Need help: What does a gutted 3rd Gen weigh with engine & drivetrain?
Old Apr 26, 2004 | 09:44 PM
Speedfreaks101's Avatar
What does a gutted 3rd Gen weigh with engine & drivetrain? I know that there will be varation from year to year and between models but please post your experience.
Thank you,
Bart
Old Apr 26, 2004 | 10:54 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Should be around the 3000 pound mark for just the car with a SBC. 2900 bare minimum.
Last year when I weighed mine, the race weight (including driver and fuel) was under 3200 pounds. I also have a BBC, 6 point roll bar, powerglide tranny and Ford 9". I need to get across the scales again after the winter projects.
It really depends on how "gutted" it is. One persons gutted might not be as much as someone elses.
My front and rear bumpers are removed. The crash bars inside the doors are cut out. The entire heater/ac system is gone. There's absolutely no interior or molding. The steering column is just the shaft.
The winter projects included removing the 6 point roll bar and installing a 10 point cage and removing the rear hatch and installing a sheet of Lexan so I've added and removed weight.
Old Apr 27, 2004 | 02:07 PM
unknown_host's Avatar
Car: 1989 Iroc Z L98
My car is as follows:
1982 Camaro Berly w/ partial gfx
small block 350 w/ iron heads
aluminum intake
aluminum radiator
Weld Pro Star 15x8"Wheels in back, 15x5" wheels up front
7.5" 10 bolt rear
Competition Engineering 10 point roll cage
Summit Racing Plastic Race Seats w/ RCI harnesses
Stock glass
Fiberglass 4" cowl hood
Car weighs 3025 without me in it.
Old May 21, 2014 | 03:49 PM
BrianChevy's Avatar
Car: 1987 IROC Z/28
Engine: 5.0L TPI. Custom Tune
Transmission: 5 Speed/ Pro5.0 short /hurst stick
Axle/Gears: 1LE 10 bolt Rear/T2R 3.45 PBR/disc
Re: Need help: What does a gutted 3rd Gen weigh with engine & drivetrain?
I weighed last weekend at SCCA National Tour Atlanta
1987 IROC Z/28
Harwood lift off hood, no hinges
Real Racing wheels with P275/45ZR-16 Hoosier A6
Chromoly 8 point cage
gutted interior only 2 kirkey seats
gutted doors
Lexan side windows
stock drivetrain weights (LB9 and T5)
2995 with a full tank of gas, NO DRIVER
My class says i can be 2750 so I will be pulling the crash bars front and rear and weighing them. need to pull 200 pounds off the car.
here are my mod's just so you can get the full picture.
Aftermarket Upgrades
Torsen T2R Differential
Earl’s Hyperfirm Stainless Steel Braid Brake lines
ARP wheel studs and Nuts
BS Racing Products Chrome-moly 8 Point Roll Cage
35MM Front Sway Bar
24MM Rear Sway Bar
Energy Suspension Bushing Kit and end links, front and rear
Hotchkis 2 point strut tower brace
Hotchkis rear pan-hard bar
Koni Sport Adjustable Racing Shocks
Kirkey Aluminum Racing seats
AutoMeter Tach with memory recall
Grant Quick release steering wheel
GForce 5 point racing harnesses
Sun Gauge Aftermarket Mechanical Oil Pressure Gauge
Rear mount battery Kit - aluminum vented box
External Longacre safety shutoff switch.
RedLine diff Fluids
Castrol Syntec Synthetic engine oil
Real 16x10 Racing rims wrapped with Hoosier 275 45r16
Edlebrock Short Tube Headers into true duals
K&N Air Filters
2, 4’ PVC Velocity Stacks (SCCA Allowed RAM-AIR)
HotParts Camber plates.
Polyurthene front control bushings
Ground Control Weight Jackers front and Rear
SSS Springs 1100 front, 225 rear
Howe Racing Performance 3/4inch lower ball joint
Harwood 2” cowl hood with Summit Pin kit
Custom ¼ inch lexan rear spoiler 10x60 adjustable heim joints
Doors gutted, door bars removed.
Lexan side windows removable
BMR lower control arms
Summit aluminum radiator
160 degree thermostat
MSD 6AL-2 with launch control and rev limiters
MSD blaster coil
Pro5.0 Short Throw Shifter
Classic Hurst Stick and 5 speed ****
Custom Headlight lexan covers
Converted to hardtop model with permanent mounted Lexan T-Tops from 91 Z28
Custom BS Racing rear Lexan Spoiler, adjustable brackets with Heim joints
Old May 21, 2014 | 06:27 PM
Fast355's Avatar
Car: 1983 G20 Chevy
Transmission: 4L60
I had a 90 RS down to 2,700 + driver with an aluminum head 305 and 4L60E in it. Many parts were removed, some were fiberglass and some were removed with a sawzall. Basically trying to make a 305 move a trashed out car as fast as possible. After we got kicked off the track for lack of a cage, we pulled the drivetrain out and someone setup the car with a basic holley carbed vortec 350 and a TH-350 and ran mid 12s all day long in that car.
Old May 27, 2014 | 01:01 PM
KWIK84's Avatar
Car: 1984 Z28
Engine: Alky 360
Transmission: TH400, Freakshow 9.5"
Axle/Gears: 9" 4.71
My car is a freak....84 t-top car 10 pt cage, vfn glass hood, sbc with iron heads, th400, and 9" weighs 2950 with my 185 in the seat....
That weight is according to the scales at my track that they use for stock and super stock classes.....
Old May 27, 2014 | 05:26 PM
quik88's Avatar
Engine: 406 sbc, dart iron ea
weighed my car yesterday and it weighed 2667 without me in it. i don't have a cage. i don't have a aftermarket rearend. 406 sbc. stripped to the max other than floor pans and fire wall.
Old May 29, 2014 | 09:21 AM
mw66nova's Avatar
Car: camaro sportcoupe
Engine: 7.0L
Transmission: G-Force GF5R
Axle/Gears: Moser 9"
mine is 3260 with me in it. 2980 without. iron 6.0 with heavy t56, nodular iron center in a 9", and a 5pt roll bar. still has a lot of the interior as i'm not yet willing to do without carpet and nice dash, etc. gutted underneath the dash though.
Old May 29, 2014 | 11:21 AM
Beeman's Avatar
Mine weighs 2705 without me. Still has stock k member and back glass. Iron headed sbc, turbo 350, full ms cage, lexan ws and door glasses.
Old Jun 28, 2014 | 10:10 AM
tsfso59's Avatar
Car: 82 Z-28 (Cert 8.50)
Engine: 416 LS3 / 1050cfm
Transmission: Powerglide w/brake
Axle/Gears: 9" 4.86, 4-link
Back halved 1982 with a LS motor and powerglide, 9", 4 link. Fiberglass doors, hood and rear deck.....lexan on all windows. If it didn't serve a purpose, it was taken out.....gutted......yes....not even close to street legal
2215 w/o me......2485 pulling into the beams
eightsixseven
Dec 16, 2024 01:50 PM
Jeremys87
Jul 14, 2022 09:08 PM
reiderz iroc
Aug 13, 2015 04:57 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
