Organized Drag Racing and Autocross Drag racing and autocross discussions and questions. Techniques, tips, suggestions, and "what will I run?" questions.
Ran the car on radials Friday night
Old May 23, 2004 | 07:38 PM
unknown_host's Avatar
Car: 1989 Iroc Z L98
Well I swapped a 750 speed demon in place of my 650 speed demon and ran the car on friday night on my 275/50/15 Radial T/A's. Car picked up significantly, I think on slicks it would have definately gone into the 12.teens.
RT: .036
60': 1.869
330: 5.133
1/8: 7.889
mph: 89.27
1000': 10.270
1/4: 12.284
mph: 111.85
This is in an 82 Camaro with:
350HO crate engine
XE274 camshaft, mild head porting, valvesprings and a compression bump.
New goal is to break into the 11's on the motor . Valve float is becoming an issue at the top end of the track, i am considering a valve spring swap pretty soon, but i am happy with the results.
Old May 23, 2004 | 08:38 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
You can always throw out those carb formulas on the drag strip. Carb CFM doesn't mean much to a drag engine running at WOT.
I ran an 850 DP Speed Demon on my old 383 stroker. I currently have an 850 DP alcohol carb on my 469 BBC and plan on using 2 850 DP alcohol carbs on my current 469 roller engine project. I'd go with 2-1050 Dominators if I could pick up a couple for cheap.
Right now I'm making about 600 HP and the new engine should make around 850 HP when I'm done. The old 383 made around 450-500 HP.
Slicks should easily get you into the 1.7's if not the 1.6's if you're doing 1.8's on street tires. Medford must have some really good track prep.
Old May 24, 2004 | 10:49 PM
camarojoe's Avatar
Car: 91 Z28
Engine: Forged 383
Transmission: Pro-built 700R4
what heads are you running? Those are some unbelievable times if they're even close to stock.
Old May 24, 2004 | 11:58 PM
They are vortecs that came with the 350HO. MILD port work done to them, stock valves and $40 k-motion valve springs. I am really pleased with the mph!
Old May 25, 2004 | 12:49 AM
xpndbl3's Avatar
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
what's the 350HO running in price these days?
Old May 25, 2004 | 01:13 AM
I think right at $2000.
Old May 25, 2004 | 12:51 PM
TexasLT1's Avatar
Car: '92 RS
what were you launching at and what PSI were the tires at?
Old May 25, 2004 | 02:34 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
http://www.sdpc2000.com/cart.asp?act...id=120&pid=115
Old May 25, 2004 | 09:04 PM
Launching at 1500 rpm'ish. I have a technique I use since the car has a lot of weight transfer, a little baby launch to get the front end up and rolling into it after that USUALLY will hook. Tires are at 25-30 PSI.
Old May 27, 2004 | 05:40 PM
Conv389drv's Avatar
Those are really amazing results out of a low-buck crate engine!!
Had a couple of questions:
Have you ever had it dyno tested to see what it puts out?
Did you port the Vortec heads yourself, or have it done by a shop?
What does the car weigh?
I want one of those engines for my next thirdgen!
Old May 27, 2004 | 05:51 PM
TexasLT1's Avatar
Car: '92 RS
Interesting. I was launching at 4000 at 24 psi with no spin.
Old May 27, 2004 | 09:45 PM
No dyno testing, by the current mph I would say it is doing 350 at the wheels with no altitude correcting. Car weighs 3025-3050'ish without driver. A friend of mine ported the heads for me .
Old May 27, 2004 | 09:46 PM
You do have nittos, I am on regular radials. I will be getting drag radials in the next few weeks .
Old May 27, 2004 | 10:11 PM
TexasLT1's Avatar
Car: '92 RS
Thats my point, you were cutting better 60's than I was and you were on street radials
Old May 27, 2004 | 10:57 PM
Ah ok I see. What kind of clutch do you have?
Old May 30, 2004 | 10:13 PM
Pony Killer's Avatar
Car: 1986 Z28
Engine: 355
Transmission: th400
Sounds a lot like a car i know....... that is in pieces now but for a good cause.
Hook some slicks up to em you'll get the 60ers down to the 1.6's and you'll be on the 11.9's or better like i was. hopefully without punching holes in your trans.
Lucky Bastard i wish my car wieghed 30xx without me
my car is slowly putting on wieght.. The TH400 is definitly more than the 700R was wieght wise.. and that 12 bolt... is much more girthy than the 10 bolt it's replacing...
racing seats will cut like 10lbs out.. but i'm just about out of crap to take out, there's Nothing in it!
guess i'll have to deal with a 3400 race wieght
Old May 31, 2004 | 08:13 PM
camarojoe's Avatar
Car: 91 Z28
Engine: Forged 383
Less than 3100 lb curb weight, Wow, no wonder that thing is so fast...and traps so well.
Old May 31, 2004 | 08:35 PM
Even when the car weighed significantly more it still put down excellent numbers.
The car will soon be trapping 112+, even if you add two or 3 hundred pounds, thatd still put the car at mid 12's around 109-110 mph.
Kinda dispells the myth that it takes a lot of $$$ to lighten up a 3rdgen tho...
Old May 31, 2004 | 11:38 PM
TexasLT1's Avatar
Car: '92 RS
I'm running a Centerforce Dual Friction with....about 20K miles on it. I think....
colton_carlson
Mar 8, 2019 12:21 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
87iroctheo
Wheels and Tires
Aug 29, 2015 09:44 PM
Dan Hubbard
Aug 12, 2015 09:05 PM
