Organized Drag Racing and Autocross Drag racing and autocross discussions and questions. Techniques, tips, suggestions, and "what will I run?" questions.
what will this setup run???
Old Sep 10, 2004 | 08:57 AM
camaro_doc's Avatar
I have a 86 iroc w/ a 79 350 in it. the compresion is 9.5:1 it also has the ****ty 305 smogger heads. and a holley 600cfm 4bbl. i have a 125 shot of nitrous. The trans is a stock 700r4 w/ a 2500 stall. the rear is a 3.42's posi. there are no wieght reductions.
Thanks guys
Matt
Old Sep 10, 2004 | 11:35 AM
Trevor86TA's Avatar
Car: 86 Trans Am
Engine: 406
Transmission: TH350, 4200
Axle/Gears: Moser 9", 3.89
Stock exhaust? Normal street tires? Maybe high 14s/low 15s on the motor and high 13s/low 14s on the 125 shot.
Old Sep 10, 2004 | 11:51 AM
camaro_doc's Avatar
it is 2.5 pipe off of the headers going to a victor muffler. the tires are normal 16" street tires goodyear eagle's.
Old Sep 10, 2004 | 06:30 PM
383firebird's Avatar
Car: 1984 firebird
Engine: 383
Transmission: th350
I think Trevor is right on the money.
Old Sep 10, 2004 | 08:04 PM
IHI's Avatar
IHI
Car: 86 firebird with 98 firebird interi
Engine: pump gas 427sbc Dart Lil M 13.5:1
Transmission: Oldani TH400 w/ BTE 9" convertor
Axle/Gears: 31 spline Moser/full spool/4.11Rich
Re: what will this setup run???
Thanks guys
Matt
I used to have the same thing only 9.3:1, recam it, bigger carb, LT headers and dual exhaust-SLICKS you'll run high-mid 13's NA then mid/low 12's on juice. Back then I was runing the Lunati Bracket Master II cam the 292/292 .480/.480 lift cam, either use a 750cfm carb or I was running a 830 DP.
As is depending on you altitude over there would think low 14's to low 15's
Old Sep 11, 2004 | 11:32 AM
camaro_doc's Avatar
thanks guys
Old Sep 11, 2004 | 07:15 PM
Trevor86TA's Avatar
Car: 86 Trans Am
Engine: 406
To follow up on IHI's post, I don't know what size the stock cam is in your engine but its likely pretty lame. A better cam, some decent cylinder heads and an intake could really wake that engine up.
You'd lose about half a point of compression if you switch to 64cc heads, but you can more than make up for it with the added flow.
customblackbird
Aug 15, 2021 10:16 PM
pimp2303
Jul 27, 2017 02:03 PM
86White_T/A305
Aug 17, 2015 12:16 AM
Street Lethal
Aug 13, 2015 08:28 PM
squiggy2
Aug 9, 2015 09:30 PM
